8th March 2007, 19:23 | #181 | Link |
retired developer
I had that problem a few times.
close bencos, clean "%TEMP%\bencos\*.*" then retry it.
Detritus Software |
9th March 2007, 20:10 | #183 | Link |
retired developer
send me your source I'll see what I can do.
Detritus Software |
10th March 2007, 17:34 | #185 | Link |
retired developer
I am currently recoding one piece and I have no problems what so ever. I'm at ep 083.
Detritus Software |
10th March 2007, 18:51 | #186 | Link |
Maybe the "no other" part was wrong. It seems it's doing to every source now...
Or at least other sources. Some old ones are unaffected, some old ones are affected. If I had to guess, this seems to be mencoder's problem. All these problems with mencoder and RA5 doesn't work... great. Last edited by Eretria-chan; 10th March 2007 at 18:55. |
10th March 2007, 22:57 | #187 | Link |
retired developer
If you find why it's doing that I'll fix in bencos, else I can't do much...
Detritus Software |
14th March 2007, 13:45 | #190 | Link |
retired developer
So you get Access Violation from mencoder on second pass? You are so unclear sometimes...
Detritus Software |
14th March 2007, 14:10 | #192 | Link |
retired developer
Sharktooth is working on DVD input, but I think currently you can add VOB files directly, but it will output one mp4 per vob file.
Detritus Software |
14th March 2007, 14:35 | #193 | Link | |
Looking forward to testing subtitles and troublesome sound sources in your next build when it's ready! Take your time! |
14th March 2007, 15:34 | #194 | Link |
retired developer
Detritus Software |
14th March 2007, 18:16 | #196 | Link |
retired developer
Can you provide me a build that works on CoreDuo? I'll add it to the sticky.
Detritus Software |
14th March 2007, 23:57 | #198 | Link |
retired developer
Not sure this build uses pthread (multiple CPU)...
Detritus Software |
15th March 2007, 01:49 | #199 | Link |
Well, I get identical speed on both versions of Mencoder, so it's all good and well. The Core Duo is clocked at 1.83 GHz and the Athlon 64 X2 is clocked at 2.01 GHz, so unless I should be getting more speed out of the Core Duo, this build works...
Of course, if there are any other builds, I'd be happy to test. |
15th March 2007, 12:08 | #200 | Link |
retired developer
look in task manager to see if both core are used.
Detritus Software |
aac, bencos, gui, webm, x264 |
