#19222 | Link | |
100% understand your thinking about unverified software. But Iīd say itīs beyond alpha state....even beyond beta state thanks to SEt. More like a RC. SEt fixed a lot of glitches and errors. But I canīt speak for the whole community of video encoders since I donīt use many filters. |
#19223 | Link |
I am also surprised to find sometimes the generated menu background clip -- the default stars picture -- included as an "Extra" in the Quick-Menu list (titles.inf), although the thresholds are set to 10 or higher. I have to deselect it and save again to remove it from the Quick Menu. It does not happen every time though.
#19224 | Link |
I have never seen BDRB as a tool backup BDs to BD5/9 as a AVCHD.
Most probably because I was using "BDtoAVCHD" befor knowing of BDRB. So I like a lot about BDRB which makes me think of BDRB replacing the other tool for BD5/9 Discs. But BD-RB seems to be very wasterful with the possible disc space. BDtoAVCHD makes a special run though the bitrates to be able to make a better encode-bitrate prediction. So it is able to ALWAYS stay over 7,9GB in size making the best of the space available on BD9. My first attempt with BDRB is 6,86GB. Over 1GB wasted. So Iīd like to know/find out is it my fault...do I need to learn how to tweak BDRB to use the space available better. |
#19225 | Link |
BD Rebuilder 0.46.11 ignores blanking in batch mode
An easy to reproduce bug: select some streams to be blanked and add the project to the batch queue. There is an entry about blanking attached to each queue entry (a bit vector I suppose), but the batch processor ignores all blanking requests...
#19226 | Link | |
Also Jdobbs has reserved some space, however not as much you are seeing.
If you fail to plan; you plan to fail, would you not agree? Think about it. |
#19227 | Link | |
![]() Join Date: Oct 2001
BD5_SIZE=4469 BD9_SIZE=8032 BD25_SIZE=23500 BD50_SIZE=47366 (Actual output target size in bytes would be this number * 1024 * 1024 using true binary numbers). So a perfectly sized BD-9 output would be 8,422,162,432 bytes in size. A DVD+R DL will hold 8,547,991,552 bytes. So in true GB size, a BD-9 will only hold 7.96GB. When getting sizes as small as you are reporting there is usually one of two things happening. 1. The original was small enough to fit without reencoding so it is keeping it's original size (you can never reencode to a better picture than the original). 2. The bitrate required to hit the target size (when adding in the audio/subtitle requirements) would be higher than the maximum transfer rate allowable under the BD-5/9 standard. There's really no 100% accurate way to predict output size, because the muxing in BD format is fairly unpredictable. Each audio type, for example has different percentages of muxing overhead. Also, there is no perfect encoder that will always hit exactly. You can also set a custom size.
jdobbs.softworks@gmail.com Last edited by jdobbs; 16th February 2014 at 07:32. |
#19229 | Link |
Don't know much about it -- and I think it requires a special burner. So obviously I haven't tested it.
jdobbs.softworks@gmail.com Last edited by jdobbs; 16th February 2014 at 07:37. |
#19230 | Link | |
Just for info this is how disc looks, notice how transparent are they.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 16th February 2014 at 08:13. |
#19231 | Link | |
#19232 | Link |
I couldn't have said any better myself. So for me donation payment is by 2x.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 16th February 2014 at 09:48. |
#19234 | Link |
Thanks for the info.
So I changed "hiddenopts.txt" as following: BD5_SIZE=n n = Change the output size (in one megabyte units) for BD-5 writes -- default = 4480 BD9_SIZE=n n = Change the output size (in one megabyte units) for BD-9 writes -- default = 8125 BD25_SIZE=n n = Change the output size (in one megabyte units) for BD-25 writes -- default = 24500 ALWAYS use Verbatim is what I only can say. I copy the experience of jdobbs and admire him for thinking of what many users donīt know or think. The only brand to expect stable results is verbatim. Tried so many others and always got disappointed. TDK has/had decent ones too...but too expensive not to directly use the reference from verbatim. And STAY AWAY from LTH types!!! Some burnerse donīt like them at all, others burn them with degraded write speeds. I donīt even fully trust the ones from verbatim. I have burned and played them all without a single loss but time will tell if they can live up the the expectations I have with verbatim medias. MY burners are PIONEER BDR-206 and PIONEER BDR-S08 Watch out for the media codes: BD9 = MCC03RG20 DVD-R DL / MKM-003-00 DVD+R DL BD25 = VERBAT-IMu-000 = LTY Type / CMCMAG-BA5-000 = Normal Type Last edited by Rodger; 16th February 2014 at 15:15. |
#19236 | Link |
Wow. What can I say? It is appreciated very much.
jdobbs.softworks@gmail.com |
#19237 | Link | |
By the way, Verbatims are very good discs and I have a stack of them in front of me -- but they (the DVD+-R discs) are prone to errors on the outside tracks as well. It's probably less-likely than cheap discs, but it's still there. The same is true for BD-R, errors are more likely in the outer tracks -- but the issue seems much less pronounced than on DVD (I really don't know why).
jdobbs.softworks@gmail.com Last edited by jdobbs; 16th February 2014 at 15:41. |
#19238 | Link |
I'll look at it.
#19240 | Link |
I will do just that. Thanks for the support (again).
| Thread Tools | |
| Display Modes | |
