#19161 | Link |
Sure, but it did not work, no resizing. .
![]() Code:
[02/10/14] BD Rebuilder v0.46.11 (beta) [11:35:01] Source: CHRIS_ISAAK_00003 - Input BD size: 14,99 GB - Approximate total content: [00:54:57.193] - Target BD size: 4,38 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - RESIZE 1080p to 720p enabled - Quality: Highest (Very Slow), Two Pass - Output folder: E:\VIDEOS\ - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448 [11:35:01] PHASE ONE, Encoding - [11:35:01] Processing: VID_00004 (1 of 1) - [11:35:01] Extracting A/V streams [VID_00004] - [11:37:27] Reencoding video [VID_00004] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 98.817 frames - Bitrate: 10.097 Kbs - [11:37:27] Reencoding: VID_00004, Pass 1 of 2 - [11:53:08] Reencoding: VID_00004, Pass 2 of 2 - [13:21:55] Video Encode complete - [13:21:55] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [13:23:16]PHASE ONE complete [13:23:16]PHASE TWO - Rebuild Started - [13:23:16] Rebuilding AVCHD file Structure [13:25:15] - Encode and Rebuild complete - WORKFILES folder removed. [13:25:16] JOB: CHRIS_ISAAK finished. Code:
Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : 27 Duration : 54mn 57s Bit rate mode : Variable Bit rate : 10.0 Mbps Maximum bit rate : 15.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.161 Stream size : 3.84 GiB (90%) Last edited by soneca; 10th February 2014 at 18:06. |
#19162 | Link | |
![]() Join Date: Oct 2001
I'll dig up a 1080i source and run a test. Can you post the AVS file from the WORKFILES folder?
jdobbs.softworks@gmail.com |
#19164 | Link |
I do notice something... the log should say "Convert: 1280x720, 59.940fps..." right after "- Rate/Length: 29,970fps, 98.817 frames" -- or at least it does on the job I'm currently running. I wonder if BD-RB's analysis is flagging that source as a menu? That could disable resizing.
[Edit] Nope... I just looked at the code and the menu check is only done on a full backup...
jdobbs.softworks@gmail.com Last edited by jdobbs; 10th February 2014 at 19:26. |
#19165 | Link |
AVS file
#Created by BD Rebuilder - v0.46.11 (beta)
LoadPlugin("C:\Programas\DGDenNV 2046\DGDecodeNV.dll")
DGSource("E:\BDREBUILDER_TEMP\WORKFILES\VID_00004.DGI", fieldop=0)
ConvertToYV12()
LoadPlugin("C:\Programas\BD_Rebuilder\tools\decomb521.dll")
FieldDeinterlace(blend=true)
ConvertToYV12().AssumeFPS(30000,1001)
#19166 | Link | |
#Created by BD Rebuilder - v0.46.12 (beta)
DirectshowSource("N:\BD\SOURCE_BD\BDMV\STREAM\00002.m2ts", fps=29.97, framecount=93557, audio=false)
ConvertToYV12()
LoadPlugin("D:\BD_Rebuilder\tools\decomb521.dll")
FieldDeinterlace(blend=false)
BicubicResize(1280,720)
Here's what it says when I have PULLDOWN_720=0 (the default): Code:
ConvertToYV12()
BicubicResize(1280,720).ChangeFPS(60000,1001)
ConvertToYV12().AssumeFPS(60000,1001)
jdobbs.softworks@gmail.com Last edited by jdobbs; 10th February 2014 at 20:05. |
#19167 | Link |
Do you ever have to click the "Backup" button more than once? 3rd time's a charm just now :S But I was centered on the button. I wouldn't think that would matter. Perhaps even though the import completed, it was still doing something. No HDD activity though. It's done this a few times before too. Not really a big deal, just curious if anyone else noticed it.
Only one rooster, need be in the hen house... |
#19168 | Link | |
#19172 | Link | |
#19173 | Link | |
but I can not resize anything interlaced.
#19175 | Link |
Post the contents of your CONFIG/INI file and I'll run a job using your settings.
#19177 | Link |
I'll try it first thing tomorrow.
#19179 | Link |
I ran "The Wire S1, Disc 1" again only with your settings this time. It still came out perfectly in sync. Sorry -- but it appears to be something on your system that is interfering with the decoding.
#19180 | Link | |
It seems to only be when BDRB has to reencode the episodes that they get out of sync. When the total content is less than 25 GB and it keeps the original content I don't have any issues (This happened with The Simpsons Season 4). In any event, I can wipe my machine over the weekend and try fresh... |
| Display Modes | |
