Old 16th February 2011, 02:36   #11261  |  Link
jdobbs
Originally Posted by big_moviefreak View Post
@jdobbs Can you please take a look?
Has anyone made backup of LET_ME_IN?
My backup failed here is my logs.
[17:28:35] BD Rebuilder v0.37.04 (beta)
- Source: LET_ME_IN
- Input BD size: 28.86 GB
- Approximate total content: [01:55:47.940]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7600]
- MOVIE-ONLY mode enabled
- Quality: High Quality (Default), ABR
[17:28:35] PHASE ONE, Encoding
- [17:28:35] Extracting A/V streams [VID_00001]
- Error in attempt to extract audio/subs.
[18:24:36] - Failed to retrieve audio, aborted
Sorry, I haven't tried that one yet. Vampire movie, right? Ugghh I hate vampire movies. I'm more of a zombie man, myself.
jdobbs.softworks@gmail.com
Old 16th February 2011, 02:45   #11262  |  Link
Capsbackup
- Source: LET_ME_IN
This type of error is usually a set up issue. Post the inspect log.
Uninstall haali, ffdshow and avisynth, delete the program folder for haali, and then reboot. Then download and install those three programs from page one of this thread.
Also, delete the BD-RB.ini and start fresh as is posted on page one for the initial install of BD-RB for Win 7.
Capsbackup is offline   Reply With Quote
Old 16th February 2011, 03:00   #11263  |  Link
big_moviefreak
Capsbackup would this error appear on everybackup, I have done several first one with this error? Before doing Let Me In I completed good back up of Take My Soul.
big_moviefreak is offline   Reply With Quote
Old 16th February 2011, 03:19   #11264  |  Link
jdobbs
Are you sure it is a good rip?
Old 16th February 2011, 03:59   #11265  |  Link
Capsbackup
Different Blu-rays use different authoring methods, VC-1, AVC, MPEG2, etc... Decoding requires the correct setup for each.
My guess is that the single most reported errors/problems for jdobbs is having BD-RB setup incorrectly, not having the proper haali and ffdshow installed. Also, other codec packs installed can cause issues as well.
Also, if this is not an original Blu-ray, ripped preferably with AnyDVD HD, it is most likely to have problems.
Old 16th February 2011, 16:18   #11266  |  Link
jdobbs
BD Rebuilder v0.37.05
I have updated the first post of this thread with a link to the newest release of BD Rebuilder (v0.37.05). Changes for this release:
- Corrected an issue in which a scan of the
  source material might miss an audio/video time
  delta when PTS/DTS values were very large.
- Corrected an error that could cause error 2904
  while outputting to ALTERNATE/DVD when the audio
  track has an offset detected.
- Updated DVD output so it exits completely rather
  than pausing at the end of play.
- Improved the methodology for prevention of sleep
  mode. It is now set/reset at the beginning/end of
  each full job rather than at the start/stop of
  each encode.  Also changed settings so the video
  monitor sleep will not be blocked and it will act
  as set in the POWER options during encoding.
- Added a hidden setting (DISABLE_SLEEP=0) that
  can be used to prevent the sleep blocking
  function from executing.
- Corrected an issue in which a "too small" target
  size for MKV output could result in illegal or
  nonsensical bitrates.
- Corrected an error in which a large target size
  for MKV output could result in an overflow
  condition: PredictAndEncode() 00006 2820.
- Reversed the decision to make LAVF the default
  frame server.  It appears to be slower on some
  systems.  It can still be selected if desired
  from the SETUP dialog.
- Corrected a problem in which starting a job with
  "Keep HD Audio", and then stopping/resetting and
  restarting with that parameter changed (after
  audio extraction) could result in a failed audio
  encode.  An improbable but possible scenario.
- Updated the included version of X264-64.EXE to
  the latest release (r1900).
- Other minor corrections and cosmetic fixes.
Old 16th February 2011, 17:09   #11267  |  Link
Blackwalker
Blackwalker's Avatar
thx for this update!
PS:
sorry for my english
There'll be in the next future a full version that i can buy (with support and no expire date)?
I hope "yes", cause this is one of the best program for bly-ray encoding!
thx
Blackwalker is offline   Reply With Quote
Old 16th February 2011, 17:38   #11268  |  Link
jdobbs
PS:
thx
My plan is to never make anyone have to "buy" it. I would like to keep BD Rebuilder going based on voluntary donations. The only way that would change is if the donations stopped or got too small to make it worth my time. Frankly the donations have never been very much -- but I'd have to draw the line at nothing. So I recommend you donate now. All donations are logged, and donators will receive free updates for the life fo the product no matter what happens.
The expiration date will stay until I decide to pull the software out of beta status. The purpose of the expiration is to save me (and all the others who help on this thread) the trouble of having to respond to trouble reports on bugs that have already been fixed. I also don't like old versions with known bugs (that have been fixed) floating around forever.
You'll see the expiration date go away with v1.00.
Old 16th February 2011, 18:43   #11269  |  Link
qcdsmtsi
When trying to do a movie only backup (25)gb, all the video has the commentary audio in the preview. I have tried all of the video sources and they are all the same.
:Note the screenshot was from last week, I just tried this again today with the latest version and the same result.
I have never seen this before, and have done almost 50 rips with the same settings.
Last edited by qcdsmtsi; 16th February 2011 at 18:46. Reason: better explain issue
qcdsmtsi is offline   Reply With Quote
Old 16th February 2011, 19:01   #11270  |  Link
Yordan5
I've had only positive and problem free results with this program. A small donation has been made. Thank you for your efforts jdobbs.
Yordan5 is offline   Reply With Quote
Old 16th February 2011, 19:03   #11271  |  Link
HatchetMan
Love the program, donation made
HatchetMan is offline   Reply With Quote
Old 16th February 2011, 21:02   #11272  |  Link
sonate
JD, sometimes I miss a target size by a few hundred MB on a 25gBD downsizing.
I then try to reduce the output size by the approx number of MB the compression was oversized by. What gives better results quality wise, using the original rip to compress or trying to compress the one further which slightly missed the target?
sonate is offline   Reply With Quote
Old 17th February 2011, 01:00   #11273  |  Link
dfsooner
Oversized result when using High-Speed Option [BD-25] and One-Pass CRF encoding
Tried to speed up creation of bd-25 sized rebuilds by using these settings, but final result was 29.4 GB which is unusable for burning to single layer disc. Source was AnyDVD rip of Chuck Season 2, Disc 2 (37.8 GB).
Log:
[12:03:30] BD Rebuilder v0.37.04 (beta)
  - Source:  CHUCK_S2_D2
  - Input BD size: 37.86 GB
  - Approximate total content: [04:35:36.720]
  - Quality: High-Speed Option (BD-25), CRF
[12:03:30] PHASE ONE, Encoding
 - [12:03:30] Extracting A/V streams [VID_00027]
 - [12:03:32] Reencoding: VID_00027 (1 of 19)
 - [12:03:32] Collecting video information
   - Source Video: VC-1, 720x480
   - Rate/Length: 29.970fps, 340 frames
 - [12:03:32] Reencoding: VID_00027, Pass 1 of 1
 - [12:03:39] Video Encode complete
 - [12:03:39] Reencoding audio tracks (if req'd)
 - [12:03:39] Multiplexing M2TS
 - [12:03:39] Extracting A/V streams [VID_00030]
 - [12:03:41] Reencoding: VID_00030 (2 of 19)
 - [12:03:41] Collecting video information
   - Rate/Length: 29.970fps, 508 frames
 - [12:03:41] Reencoding: VID_00030, Pass 1 of 1
 - [12:03:46] Video Encode complete
 - [12:03:46] Reencoding audio tracks (if req'd)
 - [12:03:46] Multiplexing M2TS
 - [12:03:47] Extracting A/V streams [VID_00026]
 - [12:03:47] Reencoding: VID_00026 (3 of 19)
 - [12:03:47] Collecting video information
   - Rate/Length: 29.970fps, 465 frames
 - [12:03:48] Reencoding: VID_00026, Pass 1 of 1
 - [12:03:53] Video Encode complete
 - [12:03:53] Reencoding audio tracks (if req'd)
 - [12:03:53] Multiplexing M2TS
 - [12:03:53] Extracting A/V streams [VID_00031]
 - [12:03:55] Reencoding: VID_00031 (4 of 19)
 - [12:03:55] Collecting video information
   - Rate/Length: 29.970fps, 840 frames
 - [12:03:55] Reencoding: VID_00031, Pass 1 of 1
 - [12:04:03] Video Encode complete
 - [12:04:03] Reencoding audio tracks (if req'd)
 - [12:04:03] Multiplexing M2TS
 - [12:04:04] Extracting A/V streams [VID_00029]
 - [12:04:05] Reencoding: VID_00029 (5 of 19)
 - [12:04:05] Collecting video information
   - Rate/Length: 29.970fps, 745 frames
 - [12:04:05] Reencoding: VID_00029, Pass 1 of 1
 - [12:04:13] Video Encode complete
 - [12:04:13] Reencoding audio tracks (if req'd)
 - [12:04:13] Multiplexing M2TS
 - [12:04:14] Extracting A/V streams [VID_00024]
 - [12:04:15] Reencoding: VID_00024 (6 of 19)
 - [12:04:15] Collecting video information
   - Rate/Length: 29.970fps, 750 frames
 - [12:04:15] Reencoding: VID_00024, Pass 1 of 1
 - [12:04:22] Video Encode complete
 - [12:04:22] Reencoding audio tracks (if req'd)
 - [12:04:23] Multiplexing M2TS
 - [12:04:23] Extracting A/V streams [VID_00028]
 - [12:04:24] Reencoding: VID_00028 (7 of 19)
 - [12:04:24] Collecting video information
   - Rate/Length: 29.970fps, 710 frames
 - [12:04:24] Reencoding: VID_00028, Pass 1 of 1
 - [12:04:32] Video Encode complete
 - [12:04:32] Reencoding audio tracks (if req'd)
 - [12:04:32] Multiplexing M2TS
 - [12:04:32] Extracting A/V streams [VID_00023]
 - [12:04:34] Reencoding: VID_00023 (8 of 19)
 - [12:04:34] Collecting video information
   - Rate/Length: 29.970fps, 1,615 frames
 - [12:04:34] Reencoding: VID_00023, Pass 1 of 1
 - [12:04:49] Video Encode complete
 - [12:04:49] Reencoding audio tracks (if req'd)
 - [12:04:49] Multiplexing M2TS
 - [12:04:50] Extracting A/V streams [VID_00022]
 - [12:04:51] Reencoding: VID_00022 (9 of 19)
 - [12:04:51] Collecting video information
   - Rate/Length: 29.970fps, 1,935 frames
 - [12:04:51] Reencoding: VID_00022, Pass 1 of 1
 - [12:05:10] Video Encode complete
 - [12:05:10] Reencoding audio tracks (if req'd)
 - [12:05:10] Multiplexing M2TS
 - [12:05:11] Extracting A/V streams [VID_00025]
 - [12:05:14] Reencoding: VID_00025 (10 of 19)
 - [12:05:14] Collecting video information
   - Rate/Length: 29.970fps, 3,370 frames
 - [12:05:14] Reencoding: VID_00025, Pass 1 of 1
 - [12:05:44] Video Encode complete
 - [12:05:44] Reencoding audio tracks (if req'd)
 - [12:05:44] Multiplexing M2TS
 - [12:05:45] Extracting A/V streams [VID_00010]
 - [12:05:47] Reencoding: VID_00010 (11 of 19)
 - [12:05:47] Collecting video information
   - Rate/Length: 29.970fps, 4,595 frames
 - [12:05:47] Reencoding: VID_00010, Pass 1 of 1
 - [12:06:29] Video Encode complete
 - [12:06:29] Reencoding audio tracks (if req'd)
 - [12:06:29] Multiplexing M2TS
 - [12:06:30] Extracting A/V streams [VID_00011]
 - [12:06:32] Reencoding: VID_00011 (12 of 19)
 - [12:06:32] Collecting video information
   - Rate/Length: 29.970fps, 4,467 frames
 - [12:06:32] Reencoding: VID_00011, Pass 1 of 1
 - [12:07:12] Video Encode complete
 - [12:07:12] Reencoding audio tracks (if req'd)
 - [12:07:12] Multiplexing M2TS
 - [12:07:13] Extracting A/V streams [VID_00015]
 - [12:07:16] Reencoding: VID_00015 (13 of 19)
 - [12:07:16] Collecting video information
   - Source Video: VC-1, 1920x1080
   - Rate/Length: 23.976fps, 8,160 frames
 - [12:07:16] Reencoding: VID_00015, Pass 1 of 1
 - [12:09:03] Video Encode complete
 - [12:09:03] Reencoding audio tracks (if req'd)
 - [12:09:03] Multiplexing M2TS
 - [12:09:04] Extracting A/V streams [VID_00016]
 - [12:10:27] Reencoding: VID_00016 (14 of 19)
 - [12:10:27] Collecting video information
   - Rate/Length: 23.976fps, 60,447 frames
 - [12:10:28] Performing CRF Prediction...
   - Analyzing 23.58 16.79 23.20 [23.07]
 - [12:12:07] Encoding using constant rate factor.
 - [12:40:28] Video Encode complete
 - [12:40:29] Reencoding audio tracks (if req'd)
 - [12:40:29] Multiplexing M2TS
 - [12:41:40] Extracting A/V streams [VID_00006]
 - [12:43:08] Reencoding: VID_00006 (15 of 19)
 - [12:43:08] Collecting video information
   - Rate/Length: 23.976fps, 61,599 frames
 - [12:43:08] Performing CRF Prediction...
   - Analyzing 23.92 16.96 19.97 19.24 [19.17]
 - [12:45:21] Encoding using constant rate factor.
 - [13:13:37] Video Encode complete
 - [13:13:37] Reencoding audio tracks (if req'd)
 - [13:13:37] Multiplexing M2TS
 - [13:14:50] Extracting A/V streams [VID_00007]
 - [13:16:14] Reencoding: VID_00007 (16 of 19)
 - [13:16:14] Collecting video information
   - Rate/Length: 23.976fps, 61,825 frames
 - [13:16:15] Performing CRF Prediction...
   - Analyzing 24.00 17.00 22.70 22.30 [22.23]
 - [13:18:54] Encoding using constant rate factor.
 - [13:48:09] Video Encode complete
 - [13:48:10] Reencoding audio tracks (if req'd)
 - [13:48:10] Multiplexing M2TS
 - [13:49:35] Extracting A/V streams [VID_00001]
 - [13:50:55] Reencoding: VID_00001 (17 of 19)
 - [13:50:55] Collecting video information
   - Rate/Length: 23.976fps, 61,869 frames
 - [13:50:55] Performing CRF Prediction...
   - Analyzing 22.11 16.06 21.86 [21.80]
 - [13:52:56] Encoding using constant rate factor.
 - [14:22:54] Video Encode complete
 - [14:22:55] Reencoding audio tracks (if req'd)
 - [14:22:55] Multiplexing M2TS
 - [14:24:48] Extracting A/V streams [VID_00018]
 - [14:26:15] Reencoding: VID_00018 (18 of 19)
 - [14:26:16] Collecting video information
   - Rate/Length: 23.976fps, 61,948 frames
 - [14:26:16] Performing CRF Prediction...
   - Analyzing 23.99 17.00 22.21 21.75 [21.68]
 - [14:28:43] Encoding using constant rate factor.
 - [14:58:21] Video Encode complete
 - [14:58:22] Reencoding audio tracks (if req'd)
 - [14:58:22] Multiplexing M2TS
 - [15:00:07] Extracting A/V streams [VID_00008]
 - [15:01:38] Reencoding: VID_00008 (19 of 19)
 - [15:01:38] Collecting video information
   - Rate/Length: 23.976fps, 61,914 frames
 - [15:01:38] Performing CRF Prediction...
   - Analyzing 23.13 [16.56]
 - [15:02:15] Encoding using constant rate factor.
 - [15:33:53] Video Encode complete
 - [15:33:53] Reencoding audio tracks (if req'd)
 - [15:33:53] Multiplexing M2TS
[15:39:23]PHASE ONE complete
[15:39:23]PHASE TWO - Rebuild Started
 - [15:39:23] Rebuilding BD file Structure
 - [15:39:34] CopyDirStructure() 00075  1200
[15:39:39] - Encode and Rebuild complete
[15:39:39]JOB: CHUCK_S2_D2 finished.
Any suggestions?
dfsooner is offline   Reply With Quote
Old 17th February 2011, 01:05   #11274  |  Link
KiwiKid
Don't know if this has been mentioned or if is just my system but I cannot run BD-RB to completion until I set tsremuxer to run in XP compatibility mode.
Awesome program by the way
KiwiKid is offline   Reply With Quote
Old 17th February 2011, 01:25   #11275  |  Link
Capsbackup
Any suggestions?
Try 1 pass ABR at High Quality(Default), or forget about the speed up and use two pass encode , but set it to Better(Faster), or Good(Very Fast).
CRF is not as size accurate as two pass encode, and I have been having excellent results and pretty accurate sizes with 1 pass ABR.
Old 17th February 2011, 01:59   #11276  |  Link
SquallMX
Special SeeD
Always use the original BD-50.
A third option: Use MultiAVCHD to remove some trailers/FBI warnings.
SquallMX is offline   Reply With Quote
Old 17th February 2011, 03:31   #11277  |  Link
sonate
Thanks for alerting me to MultiAVCHD. Just spent some time checking it out. But a question, doesn't that require different versions of ffdshow and Haali splitter which are incompatible with BD RB.
I'm wondering, if all I am trying to do is blank intros or trailers, that shouldn't matter.
Is there an easy guide you can recommend detailing the installation and operation?
Old 17th February 2011, 04:00   #11278  |  Link
dfsooner
Thanks for the reply. I'm trying to use the BD-25 rebuild as my 'gold standard' and am therefore reluctant to use Better or Good settings. Highest was taking about 18 hours (which is excruciating) and High about 12. I have a backlog and was just trying to speed things up. I might try 1-pass ABR to see if it sizes more accurately.
Old 17th February 2011, 04:04   #11279  |  Link
Capsbackup
The same versions BD-RB uses of haali and ffdshow will work fine for multiAVCHD.
Be aware that the use of multiAVCHD is either pre-processing or post-processing if used with BD-RB, and that is done at your own discretion. Do not report in this thread any problems that may occur.
There is a guide on the first page of that thread, the one for Re-Author.
Old 17th February 2011, 04:06   #11280  |  Link
Capsbackup
If you like CRF, just set / lower the custom output size by 500MB to 750MB, you will not notice any change in quality.
