#9242 | Link |
![]() Join Date: Oct 2001
@ebjones
That's a strike for failing to follow the instructions of Neuron2. I'll be happy to give more for rules 3, 4 & 8 if you wish to continue this nonsense. Read the rules and comply, or go elsewhere. Frankly it's really getting annoying.
jdobbs.softworks@gmail.com Last edited by jdobbs; 15th August 2010 at 22:54. |
#9243 | Link |
My bad... I am in error as I did not read the forum rules. I figure they were just the usual "do not use profanity, do not belittle other's ideas/comments", etc... I thought you ran this site. I didn't realize there was a moderator team in place and that Neuron2 was part of such and giving me a directive. I thought he was just one of the software users putting in his "two-cents" worth. I also did not realize that the rules state that moderators will not answer topic discussions via pm. In any event, I have now thoroughly read the rules and will endeavor to comply in the future. Thank you.
#9244 | Link | |
Weird. |
#9246 | Link | |
Special SeeD
#9248 | Link | |
TOS S3D1 Problem
I tried to do a full backup of Star Trek TOS season 3 disk 1 using BDR v3407 and have a really strange result. When I play the recorded disk on my Panasonic BD60, the disk fails when I select an episode from the TOP or POPUP menus. The machine tries to play something, then returns to the same menu. However, strangely enough, when I use a software player (PowerDVD10), everything seems to work fine. Any ideas? The log and ini files are attached. Thanks so much for the assistance and your generosity.
#9249 | Link | |
Excuse my ignorance, but I don't follow. MKV container, RAW output...these things would come into play when ripping from disc to the hard drive? |
#9250 | Link | |
None are necessary, as BD-RB will perform just fine with the default settings. However, for some, be it more experienced users, or just user experience, some options may provide improvements or perceived visual enhancements, or maybe work arounds for certain conditions. ![]() You can also open the CHANGES text file located in the same folder to read about the bug fixes and updates from BD-RB's inception, and what these hidden options stand for. Last edited by Capsbackup; 16th August 2010 at 23:43. |
#9251 | Link |
cnote
Here is an interesting problem I have noticed very recently. I have over done 50 successful " movie only dvd- 9" backups dating back to April 10. During that time I may have experienced 2-3 errors when trying to burn to a DL dvd 9. I have used IMG burn and Memorex DVD+R dl this whole time. But since the last two releases 06 and 07 I run into an error every single time I have tried to burn my backups. It occurs when the disk is between 97-99% completed. I thought it was a bad batch of disks, bought another with the same results. I really want to blame it on my burner but I successfully burn my backups going back to version 05 and prior. Any advice? I thought maybe the output size had increased but it is not listed in the latest changes. Thank you.
#9252 | Link | |
July 8th, 2010 - v0.34.03 - Increased the default output size for BD-5 and BD-9 encodes to use more of the available disc space.
jdobbs.softworks@gmail.com Last edited by jdobbs; 17th August 2010 at 01:23. |
#9253 | Link |
@cnote;
If the output size is too big for the DVD5/9, you should get a warning stating that before you burn the disc. What is the size of some of these BD-RB backups? What speed do you try to burn at? What media are you using. How old is your burner? Have you tried to use a DVD Cleaning disc in your burner ?( per setarip_old )So many questions...
#9254 | Link |
cnote
Thank you both for your prompt responses. Posting about that issue was my last resort. I always use IMGburn's auto settings. I believe it runs at max speed. I am going look for a new brand of dual layer dvd 9's, and get one of those disc cleaners. My LG blu ray burner is just under 5 months old. I have ruled that out as the issue. I am sorry about bringing up issues that are not solely about BD RB, but I thought I had replicated this enough to identify what might have been wrong. I'm sure I'll get back to using this successfully again! Thanks
#9255 | Link | |
You mentioned the problem started in April, and your burner is under 5 months old in August... did you replace the burner about the time the problem started?
jdobbs.softworks@gmail.com |
#9256 | Link |
cnote
Just the opposite..... I started using your program in April. Never once had a single issue until the beginning of August. I believe this I/O error that occurs right at the end of the burn has to be the media. Its just so strange that it would happen after keeping everything so consistent this whole time. Maybe there was a firmware upgrade that doesn't agree with the media I was using.
#9257 | Link | |
The size now are: BD5_SIZE = 4469 BD9_SIZE = 8032 BD25_SIZE = 23200 prior to the change they were: BD5_SIZE = 4369 BD9_SIZE = 7910 BD25_SIZE = 23200
#9258 | Link | |
![]() Of course when use BD-R/RE, 2X is the max for my burner. |
#9260 | Link | |
I used a lot of good brand media and all the time i burned and know friends burned over last 10 years burned at maximum speed, they have a huge defective reads, crashed, after writing or in burning process. Personnally, i burn in 4X and having less then 1-2 empty discs on a pack of 25. On BD empty disc, i burn at 2X and get no errors. I lost 1 on 30 burned. When i lost more than 5 disc on 10 empty one, it's the burner the problem. They are cheep made now. I remember use many nec drives before Sony purchase them. I was using a burner for 4 years and they still last. More the price comes down, cheep they are! We live in a cheep market right now. So, try to burn all your medias to 2X in BD-R, 4X in DVD-R and DL medias.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 17th August 2010 at 07:16. |
| Thread Tools | |
| Display Modes | |
