#31242 | Link |
If my suspicions are half right tsMuxeR got it right
If there is no info to input, it can't set the info Don't forget, in BD Dolby vision is "usually" a two track thing, standard 4K HDR track + DV track The "failure" might be in the remuxing to MKV |
#31243 | Link | |
![]() Join Date: Oct 2001
jdobbs.softworks@gmail.com |
#31244 | Link |
If I read the spec correctly, if a video stream exists -- the frame rate has to be set (in the video entry).
jdobbs.softworks@gmail.com Last edited by jdobbs; 6th May 2022 at 20:47. |
#31245 | Link |
@jdobbs
I did two remuxes of a DV movie, one with MakeMKV and the second with MKVtoolNIX mediainfo reports makemkv Code:
General Unique ID : 51054395928025620456322350733546145217 (0x2668B80FCBF508D87377603C94BAC5C1) Complete name : J:\No Time to Die\makemkv.mkv Format : Matroska Format version : Version 2 File size : 66.2 GiB Duration : 2 h 43 min Overall bit rate : 58.0 Mb/s Movie name : No Time to Die Encoded date : UTC 2022-04-23 23:51:01 Writing application : MakeMKV v1.16.7 win(x64-release) Writing library : libmakemkv v1.16.7 (1.3.10/1.5.2) win(x64-release) Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 43 min Bit rate : 58.0 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.292 Stream size : 66.2 GiB (100%) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 902 cd/m2 Original source medium : Blu-ray Code:
General
Unique ID : 332274804988886377338244567194467391288 (0xF9F9CCB72174D9811EC018C8BF995738)
Complete name : G:\mkvtoolnix.mkv
Format : Matroska
Format version : Version 4
Encoded date : UTC 2022-04-24 00:01:17
Writing application : mkvmerge v65.0.0 ('Too Much') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Cover : Yes
Attachments : cover.jpg
Video #1
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Color space : YUV
Bit depth : 10 bits
Default : Yes
Forced : No
Video #2
Format : HEVC
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Default : Yes
Forced : No
The makemkv report shows one track, a DV layer I also remuxed to BD with tsMuxeR and the mkvtoolnix version shows all the info in BDedit while the makemkv version only shows the DV data |
#31248 | Link |
Thinking about it, I didn't think that DV could be done with only one video track. I prefer not to have DV video as it is not displayable via projectors. If it is all I have, then the projector will just ignore it.
Now I know what to look out for. Maybe BDRB can put out a warning that these videos are not valid DV videos. Learn something new every day. |
#31249 | Link | |
Maybe not valid for BDs but is valid for mp4 and mkv Problem is playing back these DV mp4 and mkv files |
#31250 | Link | |
Because BDRB is being used for BD/UHD creation, then they would be invalid.
#31251 | Link |
Players will do all kinds of things that they weren't supposed to
...until they don't.
#31253 | Link |
I'm looking at making a change so that if the video entry is empty, BD-RB will gather info from the DV entry. It shouldn't have to... but this wouldn't be the first time BD-RB did something it shouldn't have to.
[edit] Ughh... I just looked at the code and this isn't going to be as easy as I'd hoped. Oh well...
#31256 | Link |
I suspect it is something that I did. Hover is my domain name holder. I seriously doubt that they got hacked. Plus, only 2 of the 5 entries was incorrect. And, it wasn't a random IP address pointing to a nefarious location.
#31257 | Link |
@MrVideo
Can you tell me how you create a structure that will cause the error you mentioned (DV has an entry but VID doesn't)? Here's what I did: 1. Use MKVMERGE to create an MKV file from an M2TS that has DV. 2. Use TSMUXER (UHD Version) to create a UHD/BD structure from the MKV file. When I do it, it seems to create the structure fine, and I don't get the error.
#31259 | Link |
Oh. I see. It requires that the MKV be created by MakeMKV. Interesting. If I use MKVMERGE, it creates an MKV with two video tracks which imports fine into an UHD-BD structure.
jdobbs.softworks@gmail.com Last edited by jdobbs; 8th May 2022 at 23:51. |
#31260 | Link | |
1. Use MAKEMKV to decrypt/create an MKV from the original disc. 2. Use TSMUXER to create a BD structure from the MKV. 3. Use BD-Rebuilder to create a Movie-Only version that is smaller. Why not just: 1. Use MAKEMKV to decrypt/copy the BD structure to your hard drive. 2. Use BD-Rebuilder to create a Movie-Only version that is smaller. If you also want an MKV, BD Rebuilder can do that for you too. Am I missing something?
| Thread Tools | |
| Display Modes | |
