Old 16th January 2020, 19:18   #29181  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by ROB271 View Post
@michi
Im talking about standard hdr10
my player (Panasonic DPUB450) & tv (Panasonic TX50GX800B) both supports hdr10+ & dolby vision but I havnt tested any hdr10+ discs yet, besides I don't think you don't get any notification of hdr10+ like the nice big dolby vision logo that pops up on the tv
is hdr10+ an extra stream like dolby vision or does it replace the standard hdr10 in the video file ?
I have a few hdr10+ discs if you want me to test
Thanks
I'm confused... Given that you have some HDR10+ discs, why haven't you tested any yet?
Old 16th January 2020, 20:13   #29182  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Interesting to see that DGIndexNV 2053.0.0.119 X32 sees this:
FPS 80000 / 1600
LowDead, is your source 50p?
You cannot have 1980x1080x50p on a blu-ray.
If 50p, then 1280x720 only.
Old 16th January 2020, 20:25   #29183  |  Link
FilipeAmadeuO
Can anyone try last BdRebuilder version with FF or RW 2x ou more to see if image shutters ?
In my case it shutters at least on Dolby Vision titles.
FilipeAmadeuO is offline   Reply With Quote
Old 16th January 2020, 21:46   #29184  |  Link
Michi
Muxing error on Angel_Heart:
[01.16.20] BD Rebuilder v0.61.04
[17:19:11] Source:  ANGEL_HEART
  - Input BD size: 82,08 GB
  - Approximate total content: [03:52:38.137]
  - Target BD size: 46,26 GB
  - Windows Version: 6.2 [9200]
  - Quality: Good (Fastest, BD-25+), ABR
  - Decoding/Frame serving: FFMPEG
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
- Resuming from previously started job.
[17:19:12] PHASE ONE, Encoding
 - [17:19:12] Processing: VID_00002 (3 of 15)
 - [17:19:14] Reencoding video [VID_00002]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 24,000fps, 163.002 frames
   - Bitrate: 35.000 Kbs
 - [17:19:14] Reencoding: VID_00002, Pass 1 of 1
 - [21:38:06] Video Encode complete
 - [21:38:06] Processing audio tracks
   - Track 4354 (deu): Keeping original audio
 - [21:38:06] Multiplexing M2TS
    - Bitstream exception. Adjusting...
 - Error in attempt to multiplex: MUX_00002.meta
 - Bitstream exception std::exception. It does not have to be! Please contact application support team for more information.
[21:40:39] - Failed to build structure, aborted
Michi is offline   Reply With Quote
Old 16th January 2020, 21:46   #29185  |  Link
LowDead
Elit Amans
It looks like the source is 25i and I'm aiming for a 8.5GB(6 episodes in total) AVCHD disc.
//LD
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L4
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 33 min 16 s
Bit rate                                 : 8 286 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 25.000 FPS
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan type, store method                  : Separated fields
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.160
Stream size                              : 1.93 GiB (94%)
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
LowDead is offline   Reply With Quote
Old 17th January 2020, 01:18   #29186  |  Link
zamengo
Originally Posted by FilipeAmadeuO View Post
I know that
Any chance to demux all m2ts at once -> stop -> i replace subtitles manually -> remux all m2ts ?
Or even better implement subtitle/dudio replacement directly on GUI
Any way to check extraction errors ? On the log there is no error reported
Why you don't use tsmuxer gui?
zamengo is offline   Reply With Quote
Old 17th January 2020, 02:45   #29187  |  Link
LowDead
Elit Amans
Adding to this.. Thought of changing frameserver and this happens...
Anyway, result is the same.
//LD
Old 17th January 2020, 15:05   #29188  |  Link
Emulgator
Emulgator's Avatar
Wrong signalling in .mkv container ?
A sample would tell more, I am guessing blindly here.
Old 17th January 2020, 15:13   #29189  |  Link
jdobbs
//LD
Format                                   : AVC
Bit depth                                : 8 bits
Default                                  : Yes
Forced                                   : No
I'm confused. The scan for variable bitrate only applies to files that say "Frame rate mode: Variable". Is this a different file? You don't force it by having IMPORT_VFR_SCAN=1 set in your INI, do you?
jdobbs.softworks@gmail.com
Old 17th January 2020, 16:01   #29190  |  Link
LowDead
Elit Amans
This is the same file. Used Mediainfo 19.04 (and latest version 19.09) to check it. And I don't have IMPORT_VFR_SCAN at all in my INI.
//LD
Old 17th January 2020, 16:35   #29191  |  Link
prologic
Today I did the 4k movie Gemini Man ,
Just rebuilt it, taking some sound and subtitle streams out, without shrinking anything else ..
Report is , DOLBY VISION and (60 FRAME RATE) (DOLBY ATMOS) all worked great ..
This just get`s better , with every new release ..
prologic is offline   Reply With Quote
Old 17th January 2020, 22:14   #29192  |  Link
TobiMan
Yes, that would be no problem at all..
//LD
TobiMan is offline   Reply With Quote
Old 18th January 2020, 04:01   #29193  |  Link
jdobbs
//LD
Does it report differently if you use the version of MEDIAINFO that is included in BD-RB's tools folder?
Old 18th January 2020, 04:49   #29194  |  Link
LowDead
Elit Amans
This is what I get with the included mediainfo (changed filename for ease of use):
General
Unique ID                                : 0 (0x0)
Complete name                            : 1.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 2.06 GiB
Overall bit rate                         : 8 846 kb/s
Encoded date                             : UTC 2010-02-22 21:41:29
Writing application                      : no_variable_data
Writing library                          : no_variable_data
Video
Format                                   : AVC
Format settings, ReFrames                : 4 frames
Bit depth                                : 8 bits
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 384 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Stream size                              : 91.4 MiB (4%)
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
Old 19th January 2020, 22:59   #29195  |  Link
cartman0208
Jdobbs: I was wondering ... do you plan on implementing GPU encoding in the future?
I was able to do some testing recently with my new graphics card and the results look awesome.
Additionally the encoding time on a UHD 2hr movie decreased from 30 hours to 40 minutes
cartman0208 is offline   Reply With Quote
Old 20th January 2020, 01:47   #29196  |  Link
zamengo
Encoding with cuda cores have a issues, the final result is a 2176p file, not 2160p.
Old 20th January 2020, 14:42   #29197  |  Link
jdobbs
Really? That's disappointing. I was actually thinking about (eventually) buying an NVIDIA card in the Turing family (for B-Frame support) and doing some testing.
Good to know.
Old 20th January 2020, 15:22   #29198  |  Link
Ch3vr0n
@jdobbs Thats because it's obsolete. CUDA has been replaced by NVEnc https://avidemux.org/smif/index.php?topic=16389.0, https://steamcommunity.com/app/33007...4045360096302/, https://en.wikipedia.org/wiki/Nvidia_NVENC
Ch3vr0n is offline   Reply With Quote
Old 20th January 2020, 15:49   #29199  |  Link
jdobbs
Originally Posted by Ch3vr0n View Post
NVENC is what I was taking about... so the issue he mentioned isn't related to NVENC? I guess I didn't understand that CUDA and NVENC were mutually exclusive.
If I understand it correctly, in FFMPEG NVENC and NVDEC are still called CUDA, but, honestly, I have spend a whole lot of time researching it. My (still unresearched) plan was to use FFMPEG for NVENC encoding.
Old 20th January 2020, 16:41   #29200  |  Link
videoh
Useful n00b
CUDA refers to the GPU multiprocessors (cores) and the infrastructure to utilize them. NVDec (previously called CUVID) and NVEnc are separate engines on the GPU that implement video decoding and encoding, respectively. CUDA is certainly not obsolete. And CUVID was not replaced, merely renamed.
