Old 2nd May 2020, 13:21   #1  |  Link
ProWo
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
For all those who are looking for a simple x264 encoder for their Qtgmc scripts or want to deinterlace their videos with Qtgmc, I present my Qtgmc-GUI here.
You can load your own Avisynth script or any video file; in this case an AVS script will be created.
You can edit the script with Notepad (I'm using Notepad++) and check it with Virtualdub. Then just click Encode and the video will be encoded.
You can find the requirements in the enclosed How to Text file. An example script is also included.
Have fun with it.
9 November 2021 update to v1.0.8.
Fixed: small bugs
Changed: Cosmetics (Main back color, new icon), new routine for checking the needed paths/executables.
Download: https://files.videohelp.com/u/292773/Qtgmc-GUI_108.7z
Info:
ProWo is offline   Reply With Quote
Old 2nd May 2020, 17:20   #2  |  Link
jlw_4049
I'll take a look at this
jlw_4049 is offline   Reply With Quote
Old 5th May 2020, 17:02   #3  |  Link
ReinerSchweinlin
Thanx, this might come in handy
Old 7th May 2020, 14:14   #4  |  Link
ProWo
05 May 2020 update to v1.0.5.
You can now also load a video file, then the program will create a simple script that you can also modify.
Old 7th May 2020, 19:46   #5  |  Link
ProWo
05 May 2020 update to v1.0.6.
Some small bugs fixed
Old 27th December 2022, 18:38   #6  |  Link
ProWo
27 December 2022, update to v.2.0.0
bugs fixed, improved handling, drag & drop.
You find it here: https://files.videohelp.com/u/292773/Qtgmc-GUI_200.zip
