Old 28th August 2020, 20:50   #201  |  Link
l33tmeatwad
l33tmeatwad's Avatar
Originally Posted by ChaosKing View Post
Sangnom is probably used in 80% of all antialiasing scripts and not just for deinterlacing
So in this case it makes sense to support higher bit depth, but is does not mean every plugin should support it by default.
That's fair, that said, we're getting a bit off topic.
Github | AviSynth 101 | VapourSynth 101
l33tmeatwad is offline   Reply With Quote
Old 28th August 2020, 20:56   #202  |  Link
shph
Yep, 8 bit plug-ins are OK for DVD and for native DV tape sources restoration because it is usually 8 bit 4:2:0. All those very specific tools like Bifrost, DeCross are 8 bit only
But for analogue sources 8 bit is not a limit. More-less professional capture cards and codecs do native 10-bit 4:2:2 from VHS, Hi8 and any other tape source and it is totally different level of quality and color correction flexibility.
But anyway, why limit things with 8 bit from start? It is not convenient. Soon or late someone need some tool for 10 but capture restoration and oops, it transforms everything to 8 bit. Also (same as in audio) bit depth upscale for processing have advantages.
shph is offline   Reply With Quote
Old 28th August 2020, 21:15   #203  |  Link
l33tmeatwad
Again, this is way off topic. If you have major issues with plugins being 8 bit I'm sure the developer(s) would appreciate it if you were to fork the project, update it, and push a pull request.
Old 29th August 2020, 11:51   #204  |  Link
shph
Problem found in macOS version TimeCubes. Windows version works well.
https://forum.selur.net/showthread.p...d=8759#pid8759
https://forum.selur.net/showthread.p...d=8791#pid8791
Selur comment that it is possible that "problem with the compilation" Can you check it?
Old 29th August 2020, 12:57   #205  |  Link
l33tmeatwad
A problem with the compile would mean it won't load. The issue is most likely with the code and the difference in OpenCL on the different platforms.
Old 30th August 2020, 04:25   #206  |  Link
l33tmeatwad
Added VapourSynth Editor 2, it requires macOS 10.13+.
Old 31st August 2020, 01:04   #207  |  Link
l33tmeatwad
Added DPID & JincResize. DPID has not been tested and JincResize works, but causes VapourSynth Editor to crash when closing the preview window.
Old 31st August 2020, 22:16   #208  |  Link
l33tmeatwad
Added Bwdif & the test version for TimeCube.
Old 1st September 2020, 20:49   #209  |  Link
l33tmeatwad
Added Focus (uses TemporalSoften namespace), TempLinearApproximate, & add new TimeCube test.
Old 1st September 2020, 21:10   #210  |  Link
shph
LibFocus-r4.tar.gz archive is corrupted.
TimeCube is finally fixed for real and WORKS WELL!
Old 1st September 2020, 21:25   #211  |  Link
l33tmeatwad
Added ReadMpls, RemoveDirt, reuploaded Focus, & updated Yadifmod.
Old 2nd September 2020, 19:41   #212  |  Link
l33tmeatwad
Added vcmod, vcmove,& vctrans, the other vc filters are proving to be a bit more difficult to adapt by working around Windows only functions that were used.
Old 4th September 2020, 05:04   #213  |  Link
l33tmeatwad
Updated DotKill, SangNom, TComb, & TimeCube.
Old 4th September 2020, 07:18   #214  |  Link
AdamCarter
Thanks meatwad
AdamCarter is offline   Reply With Quote
Old 4th September 2020, 21:15   #215  |  Link
l33tmeatwad
Added Anime4KCPP, it seems to work okay, but GPUMode previews are not correct, have not tried encoding with it.
Old 4th September 2020, 23:32   #216  |  Link
AdamCarter
Thanks meatwad.
Old 5th September 2020, 00:18   #217  |  Link
shph
So Focus (uses TemporalSoften namespace) is a updated and renamed version of TemporalSoften? or it is a separate filter with namespace conflict similar to SangNom vs SangNomMod namespace confusion?
Old 5th September 2020, 01:01   #218  |  Link
l33tmeatwad
Much like EdgeFixer vs ContinuityFixer, it's a different developer's implementation of TemporalSoften. It's actually older, but I decided to compile it for archival purposes and in case someone wants it.
Old 5th September 2020, 04:38   #219  |  Link
l33tmeatwad
Updated FFMS2 & LSMASHSource to their latest version with FFmpeg 4.3.1 and recompiled D2VSource with FFmpeg 4.3.1 as well. Also ffmsindex included with FFMS2 is a static build so it does not matter where it is placed for it to work.
Old 5th September 2020, 05:21   #220  |  Link
AdamCarter
Nice it’s going to be like using a whole new app.
meatwadismagical, meatwadthegreat
