28th February 2010, 16:44 | #12061 | Link |
The issue without DXVA is a fixable bug, one that I have also reported already long ago. This is one of the reasons why ffdshow is superior to the basic internal decoder.
MPC-HC 2.1.7.2 |
28th February 2010, 19:22 | #12064 | Link | |
MPC-HC Project Manager
http://sourceforge.net/apps/trac/mpc-hc/ticket/77 If so can you guys add comments to update the available information as described here: http://sourceforge.net/apps/trac/mpc..._Report_Issues
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
28th February 2010, 20:27 | #12065 | Link | |
2 somy
Pls, post your settings of CCC profiles and MPC-HC in my private. I'll try reproduce. But it will take same time. I have another TODOs (see below) and not enough time. Quote:
--------------------------------------------- TODO in FIFO order. 1. Customizable OSD size 2. "File not found" when double click on the file in the playlist after "search in folder" and programm restart. (MPC-HC's path adds to file's net path, for example "C:\Users\X-Dron\Desktop\//MMC/Films/mults/Barbi.2009.avi") 3. Customizable switch off for "search in folder" 4. somy's issue |
28th February 2010, 20:27 | #12066 | Link |
You need to install Haali splitter in order to use its renderer. Frame time correction is in Renderer Settings-->Presentation. You should only enable this for this video and not leave it enabled all the time.
28th February 2010, 20:30 | #12067 | Link | ||
1st March 2010, 08:20 | #12068 | Link |
Has anyone here more than 1 video card in system, different video card ???
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
1st March 2010, 08:56 | #12070 | Link |
1st March 2010, 10:40 | #12071 | Link |
X-Dron,
Thanks for your help! The image below shows monitor settings in CCC, and as you can see both my TV and PC monitor are connected, but I only enable the PC monitor: Then go to display proerties, it shows my PC monitor only support 59HZ and 60HZ at 1920*1200: When I open MPC-HC and try to configure auto refresh changer, the list contains all the modes from my TV with resolution 1920*1080 and 24HZ, 25HZ, 50HZ etc: I used the following to CCC profile to switch between TV mode and PC mode: http://www.maimuzi.com/HTPC/pc.xml http://www.maimuzi.com/HTPC/tv.xml Let me know if you need more information, thanks a lot in advance!! |
1st March 2010, 11:32 | #12072 | Link | |
By the way ar-jar, I think this is the reason why Reclock can use vsync correction with PDVD Blu-ray, not because it is using some fancy triple buffered EVR without D3D as I had suspected - its final surface is an overlay, so can be controlled independently in the way Reclock vsync was originally intended. Last edited by Jong; 1st March 2010 at 12:23. |
1st March 2010, 17:59 | #12073 | Link | |
[Later edit] I did one myself (based on some foobar icons). Hope to see some better ones.... Last edited by Phaser; 1st March 2010 at 19:55. |
1st March 2010, 18:22 | #12075 | Link |
Hello guys. Up until some days ago, I was using a 1400something SVN build of MPC-HC and changed to one of the latest builds (1701, to be exact). I noticed that when MPC-HC reaches the end of playback, the OSD message "Pause" no longer appears. Can anyone confirm that or could it be a glitch in my setup? Thanks!
My hardware: +5 Holy Avenger 4.5ft overclocked@5.5ft, +2 mithril chainmail. |
1st March 2010, 19:41 | #12077 | Link | |
ffdshow/AviSynth wrangler
Why do you ask? np: Thomas Meinecke & Move D - Track 01 (Work)
now playing: [artist] - [track] ([album]) |
1st March 2010, 19:47 | #12078 | Link | |
>>^^__^^<<
1st March 2010, 20:03 | #12079 | Link |
Also to mention the supurior 16bits scaling algorithms provided by MadVR.
Jong, with HD4XXX I believe Overlay behaves the same as commercial players(both output untouched YUV 0-255). I tried with my old HD4850, and it produces exactly the same result as PowerDVD, so I'm suggesting this can be a hardware or driver issue. I've mentioned this several times in this forum, but nobody believes me. Please see my posts: http://forum.doom9.org/showthread.ph...29#post1371829 http://forum.doom9.org/showthread.ph...42#post1372642 |
1st March 2010, 20:47 | #12080 | Link | |
This options solved the problem!! Why can t I use it for all my video? It seems to work fine..... And any thoughts anyone about the other issue I have (ati ccc related): when switching to my Projector profile (1920x1080@23,976Hz) I always have to manually go to the ati CCC and choose 23Hz and apply this. Tried to save the profile at that moment but it doesn t get remembered by the CCC. Switching to my monitor and than back to my Projector profile again displays 24Hz. So I always have to go to the CCC and choose 23Hz and apply before running my HD movies. Is there a workaround for this or am I doing something wrong here? |
