28th October 2009, 08:26 | #10261 | Link |
Done a quick test yesterday, compilation didn't works with VS2010. I suspect some troubles during project migration (especially on the output lib path for dependent projects)
Tired of tearing? Try this Media Player Classic mod : http://mpc-hc.sourceforge.net |
28th October 2009, 08:29 | #10262 | Link |
Alright... the linking issues I experienced might have to do w/ the fact I'm compiling w/ Visual Studio 2010 Beta 2. I got the same messages using both komisar's 4.3.4 AND the 4.3.3 custom install you guys linked to in the Compilation.txt. I might try the workaround people suggest on Google (modifying the libmingwex.a lib) later on today.
28th October 2009, 09:42 | #10263 | Link |
Hi, guys. What is the minimum requirements to reproduce "error LNK2019: unresolved external symbol __imp____lc_codepage referenced in function _wcsrtombs"?
Enough simple "configure && make"? I will try to fix my mingw toolchain... Last edited by komisar; 28th October 2009 at 09:52. |
28th October 2009, 10:00 | #10264 | Link | |||
Greetings Casimir. I guess you did not get to read my earlier post, so here it is.
28th October 2009, 11:20 | #10266 | Link | |
MPC-HC Project Manager
VS2010 changes some include files, and the existing .rc is pointing to a function that changed names More information here: http://msdn.microsoft.com/en-us/libr...2z(VS.80).aspx http://msdn.microsoft.com/en-us/libr...1z(VS.80).aspx
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
28th October 2009, 12:38 | #10267 | Link |
MPC-BE DEV
Don't pay attention to the VS2010 until no status RC, because much could change during this time.
p.s. To work with VS2010, requires serious reconfiguration project MPC-HC.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. Last edited by alexins; 28th October 2009 at 12:41. |
28th October 2009, 12:40 | #10268 | Link | |
The licence even states "Ready for production use" Microsoft will only be working on further performance improvements and bugs found in Beta 2 for RTM (there will not be an RC)
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 28th October 2009 at 12:43. |
28th October 2009, 14:02 | #10269 | Link |
when i change language from english to polish the submenu Audio and Subtitles (from right mouse button menu) does not work
in top menu everything is ok http://img408.imageshack.us/img408/2996/nowy9.jpg Last edited by mrtemp; 28th October 2009 at 14:04. |
28th October 2009, 14:27 | #10270 | Link | ||
Anyway, I ran the vs linker with the /VERBOSE flag so you'll get a log: http://www.sendspace.com/file/0burs2 Quote:
I didn't even touch/compile the resource languages projects. It's not required for basic mpc-hc.exe compilation. After a LOT of work on project settings and such, I got mpc-hc to compile, but not link (2 link errors left). I noticed VS2010Beta2 has some strange bugs where it freezes during compilation. Very annoying. Might actually have to wait for the RC (for it to be stable). Last edited by avivahl; 28th October 2009 at 14:31. |
28th October 2009, 14:39 | #10271 | Link | |
i read an MS thread about those linker errors when we tested BETA1 (no longer have the link) and MS staff said that if you recreate the rc files from vs2010 then the error would go away. Also there are no plans for an RC, microsoft says VS2010 is finished, next release will be RTM When you say compile but not link, does that mean you removed the file that was giving the error and have a working .exe? EDIT: Make sure you report all those problems to Microsoft(they have a site dedicated to vs2010 bugs) they think its stable. If you wait untill RTM to report these bugs they are unlikely to (ever) fix them.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 28th October 2009 at 14:50. |
28th October 2009, 15:05 | #10272 | Link | |
http://ffmpeg.arrozcru.org/forum/vie....php?f=1&t=891 I've not got 2010 installed yet, so can't test, but it looks like it may be of some use... regards Spec |
28th October 2009, 15:06 | #10273 | Link |
@ Compilers:
We should work on getting MPC-HC and FFdshow compiling under VS2010 beta2 as soon as possible. Microsoft thinks VS2010 is stable and ready for production use, from what i'm reading on the thread this is far from the truth. We need to report every problem encountered to microsoft now, after RTM chances of getting them fixed are slim at best.
28th October 2009, 15:38 | #10274 | Link | ||
28th October 2009, 19:38 | #10275 | Link | |
When external filter are set to prefered it's normal they are use instead of internal filter (they are prefered ) I have answer for other questions. Your VC1 file is on my disk, but don't know when I'll have time to look for it.
28th October 2009, 21:00 | #10276 | Link | |
{0A68C3B5-9164-4A54-AFAF-995B2FF0E0D4} I don't know about the MPC-HC one though since I don't use it as an external filter. |
28th October 2009, 21:52 | #10277 | Link |
Perhaps they 'borrowed' Gabest's code and forgot to change the value.
MPC-HC 2.1.7.2 |
28th October 2009, 22:38 | #10278 | Link | |
StringFileInfo Comments.http://gabest.org/ CompanyName..Gabest FileDescription..Matroska Splitter FileVersion..1.0.0.4 InternalName.Matroska Splitter LegalCopyright.Copyright (C) 2003-2006 Gabest OriginalFilename.MatroskaSplitter.ax ProductName..Matroska Splitter.4..ProductVersion.1.0.0.4 |
29th October 2009, 00:50 | #10279 | Link | |
Good to see beliyaal back,
but the change to TryLock instead of CCritSec does not work for me. Now i got tearing, before i had none with my config: WIN 7, EVR CP, VSYNC On, Alternate Vsync On, Desktop compositon disabled, everything else off, DXVA, Radeon 2600 Pro AGP, Catalyst 9.5. Trylock does not seem neccessary and locks the device for too long. Pre 1312 versions work perfectly! thanks, Casshern P.S.: If trylock fixes something for somebody else, maybe it should be made optional Quote:
29th October 2009, 13:46 | #10280 | Link |
@komisar: after checking some of the sources of mingwex online, I found the following file:
http://cygwin.com/cgi-bin/cvsweb.cgi...up&cvsroot=src It is included and used from mbrtowc.c and wcrtomb.c. The question is: where is __lc_codepage implemented? |
