Old 17th September 2016, 19:30   #39461  |  Link
P.J
Δ
Any real-world difference between madVR and EVR? found no good topic about it =T
P.J is offline   Reply With Quote
Old 17th September 2016, 20:02   #39462  |  Link
CarlosCaco
Just give a try and see with your eyes...
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC
Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500
Windows 8.1 Pro x64
CarlosCaco is offline   Reply With Quote
Old 17th September 2016, 21:26   #39463  |  Link
Asmodian
Originally Posted by chros View Post
What is Power in % anyway?
Can you use graphs of nvidiainspector with that card?
100% should be ~250W for this card.
It shows the same pattern with nvidiaInspector as well:
madVR options explained
Old 17th September 2016, 21:35   #39464  |  Link
DragonQ
Big differences for me are smooth motion and much nicer SD -> HD upscaling. Even if you can't tell the difference between chroma upscaling methods these make obvious improvements.
Old 17th September 2016, 21:56   #39465  |  Link
leeperry
Kid for Today
All placebo, really.
Old 17th September 2016, 22:23   #39466  |  Link
ryrynz
ryrynz's Avatar
This is literally the last thing I'd ever expect you to say.
@P.J Seriously though, read the OP.
Old 18th September 2016, 11:11   #39467  |  Link
chros
chros's Avatar
Hmm... Does the "Voltage" graph working for that card?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 18th September 2016, 11:55   #39468  |  Link
ashlar42
Quick, somebody call an exorcist. An entity has taken hold of leeperry's body!
Old 18th September 2016, 13:58   #39469  |  Link
Asmodian
nvidiaInspector's doesn't but Afterburner's does:
Edit: I found the cause, it was a polling issue, simply the sampling interval drifting in and out of phase with a very spiky instantaneous power usage.
Increasing the sample rate 10x, to once every 100ms, makes what is going on obvious:
Titan X (Pascal) with: madVR 1000msec, madVR 100ms.
Sorry for all the images.
I think the Titan X (Pascal) actually powers down after every frame is rendered, in my case it only takes 19ms to render each frame so it is using a lot less power for 22.7ms out of every 41.7.
Old 18th September 2016, 15:48   #39470  |  Link
aufkrawall
Can confirm this:
Old 18th September 2016, 16:01   #39471  |  Link
Asmodian
Originally Posted by aufkrawall View Post
Can confirm this:
Very nice! Thanks.
C1E For GPUs.
Old 18th September 2016, 16:09   #39472  |  Link
Betroz
Is this for real?
Betroz's Avatar
C1E For GPUs.
Maybe nVidia have made some adjustments to their Turbo Boost 3.0 technology or something. So this could be by design.
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 18th September 2016, 16:20   #39473  |  Link
Asmodian
Yes, I am sure it is by design. It isn't turbo boost though, that changes the clock speeds based on power use and temperature. This is more like the enhanced halt states in CPUs; parts of the core turn off and on over very small timescales, but the overall clock speed doesn't change.
Old 18th September 2016, 16:44   #39474  |  Link
e-t172
Public service announcement: if you're experiencing A/V sync issues (specifically, video lags behind audio) in windowed mode (full screen or otherwise), you might want to take a look at http://bugs.madshi.net/view.php?id=434. I believe I have seen related problems being reported in this thread at some point, with people suspecting Windows 10 to have something to do with it.
e-t172 is offline   Reply With Quote
Old 18th September 2016, 17:34   #39475  |  Link
Asmodian
Hmm, quite interesting, have you checked windowed overlay? Another data point to try to isolate it would be good.
(it seems likely that it is OK as well as it is similar to DX9 Old Path)
edit: Another question, how big is your present queue?
Old 18th September 2016, 17:50   #39476  |  Link
e-t172
Good idea. I just did the test for D3D fullscreen overlay (everything else reset to defaults), and as you suspected there is no delay in this mode.
Old 18th September 2016, 18:20   #39477  |  Link
Sunset1982
wrong composition rate with Win10 build 1611 / FSE
I did some further investigations regarding the wrong composition rate.
I found out, that since the Win10 Anniversary Update the composition rate of 23,976 movies is shown as 24hz instead of the correct 23,976hz.
I don't know what the composition rate exactly means and if this bug leads to any kind of playback problems or framedrops, but with the 1511 build the composition rate is always shown as the correct 23,976 hz. With Windows 10 build 1607, in D3D11 / 10 bit / FSE mode and in 3D mode (D3D11 /8 bit / FSE) the composition rate is shown as 24hz instead of 23,976 hz. I reinstalled Win10 with 1511 build and it worked as it should. Updated to 1607 and it's broken again. So this is clearly an issue with Win10 anniversary update and madvr's FSE D3D11 mode. This happens with my RX480 and my GTX1060 too.
Used latest crimson 16.9.1 drivers, latest mpc-hc, lav, madvr and xysubfilter builds.
@madshi: Is this a known bug? Do I have to expect any kind of playback problems?
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 18th September 2016, 18:38   #39478  |  Link
e-t172
I can see why you would ask that As mentioned in the bug report, all tests were done with the default settings, i.e. 8 frames to present in advance. I know for a fact that the same issue (with the same amount of delay - it's not correlated) occurs with a queue size of 4 because that's the setting I normally use.
I tried to test 16 frames to present in advance but, amazingly, the GPU driver crashes instantly as soon as I try to go full screen with that setting in place. Interesting bug. I suspect that has something to do with the fact that full screen in my setup means 2160p (4K), maybe 16 times 2160p is asking for too large a buffer, i.e. it triggers an overflow bug somewhere in the GPU driver or something.
Old 18th September 2016, 20:13   #39479  |  Link
Asmodian
Thanks for the extra info, a truly annoying issue. This makes me glad I am using Overlay again.
I can confirm the crash when presenting 16 frame in advance, the Nvidia driver doesn't like it at all. I am only on 2560x1440 too and 14 frames works properly. I remember this setting used to only go up to 15?
Edit: DX11 will only use 15 when set to 16, but DX9 Full Screen Exclusive is happy even with 16 frames in advance.
Old 18th September 2016, 20:34   #39480  |  Link
aufkrawall
What exactly do you do to reproduce the crash? I don't seem to be able to reproduce it.
