17th April 2005, 00:44 | #201 | Link | |
PgcEdit daemon
BTW, I have verified the way I have implemented the Open DVD Folder function: I was unable to call the start function. For an unknown reason, it doesn't work from Tcl/Tk. So, I've made a direct call to explorer.exe. Sorry. As I said, use the Tools menu...
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 17th April 2005 at 00:47. |
17th April 2005, 00:47 | #202 | Link |
Country Member
How to add a PGC (basically make a VMGM) if only FP PGC is present?
Right now, the Utility -- New dummy PGC doesn't work if there's only a FP PGC. So, I can't add VMGM 1 etc.
Is this intentional? BTW: The remove commands and links works great!!! Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
17th April 2005, 00:50 | #203 | Link |
PgcEdit daemon
No, it's not intentional. I've already noticed this problem, but since you will add some VTS anyway, I haven't fixed it.
[EDIT] Wrong! The new Dummy PGC can't work on the FP-PGC, but you may add a VMGM PGC 1 with the New Menu function.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 17th April 2005 at 00:55. |
17th April 2005, 01:45 | #205 | Link | |
i have never seen 'start' used otherwise |
17th April 2005, 04:22 | #206 | Link | |
Regular User
i've seen 'start' used to shutdown windows btw, r0lZ, thx a 1000000 for the new release w/ option to remove the VM commands of the unreferenced cells. regards t |
17th April 2005, 07:49 | #209 | Link |
Country Member
Just thinking here:
If we find a menu that is unreffed and can take its VM commands out, why can't we make it a dummy at the same time (if it has video in it), letting the user know he has to do a menu strip. Once the menu buttons (if any) are out of the way, this could lead to more unreffed material being stripped clean. I have actually been able to trim a 7 VTS disk down to 1 doing this (ultimately needing, of course to play with things like VMGM_MAT, VMG_PTT_SRPT and VMG_VTS_ATRT), but that is not hard. There was a guy the other day who actually wanted to do this on his backups to keep things "neat" IIRC. Regards
17th April 2005, 09:19 | #210 | Link |
PgcEdit daemon
Good idea, blu.
I'll add it soon...
17th April 2005, 10:34 | #212 | Link |
PgcEdit daemon
Bug in 0.5.2 final and 0.5.3 beta 1 !
WARNING! I've found a bug in 0.5.2 (final release only) and 0.5.3 beta 1.
If you create a new button or BOV in a cell originally without buttons, the new button(s) will be saved only in the first nav pack of the cell, while it should be saved also in all subsequent nav packs. Your button will be shown only for a verry short time, and then disappear. This bug is fixed now. I will release a nev version soon... Thanks to Pil who submitted this bug via private email.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 17th April 2005 at 10:36. |
17th April 2005, 11:25 | #214 | Link |
PgcEdit daemon
It's already the case, no?
Normally, the commands jumping inside the same PGC are ignored (unless there is a bug somewhere).
17th April 2005, 12:17 | #215 | Link |
PgcEdit daemon
PgcEdit 0.5.3 beta 2
PgcEdit 0.5.3 beta 2 is here. (Third release in two days! Sorry.)
It fixes the important bug with the new buttons on cells originally without buttons. This bug was introduced because I wanted to keep the original highlight status whenever possible, so that animated highlights are not lost after a save cell with edited menu buttons. But I kept the original status of 0 when a new button was created on a cell w/o buttons. In this case, the HL status is now 1 in the first nav pack of the cell, and 2 in all subsequent packs, as it should be. I have also added the option to convert unreferenced menu PGCs to dummies when using the Info -> Calls Cross References function. Note that the GUI will be visible only if there are unreferenced menu PGCs with video, and if you accept the 'delete commands' option. Take care: cells with menu buttons will be converted to dummies as well.
17th April 2005, 14:39 | #216 | Link | |
Regular User
but obviously it was pinta to delete those commands from 50+ PGCs... regards t |
17th April 2005, 15:33 | #217 | Link |
PgcEdit daemon
I've just tried with a PGC with a LinkTailPGC in post commands, and another one as cell command 1. It is correctly marked as unreferenced.
Don't forget that a PGC may be referenced if there are Next/Prev/GoUpPGC links pointing to it in another PGC, or if it's a PGC callable with the remote (ie root, title, subpic menu entry...) If you still encounter a bug, please send me the Call Cross Refeerences output.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 17th April 2005 at 15:37. |
17th April 2005, 15:36 | #218 | Link |
Country Member
Thanks for the fix r0lZ and the enhancement to the unreferenced material "wipe". One final thought about wiping unreffed material.
If a GPRM is used only once I think it can be safely deleted. Oftentimes, you see authoring remnants that say someting like If gprm(7) <> 0 then jump to a PGC which is otherwise unreferenced and usually has no commands in it. This command, of course, can never be executed as it is the only time gprm(7) is used. So, can PgcEdit find GPRMs that are only used once and delete the commands, too? Regards
17th April 2005, 15:40 | #219 | Link |
PgcEdit daemon
That's a totally different method. I need to inspect every command in the DVD (including in menu buttons) before calling the actual Call Cross Refs function. It's a big work. Please remind me later...
For now, I want to implement the preview for Linux.
17th April 2005, 15:40 | #220 | Link |
Country Member
Final Q then off to bed:
If I have done an incremental backup, how does one restore from the old backup (the original one now marked with the date and time)? This is a manual job, yes? Regards
