21st December 2019, 18:04 | #1 | Link |
10 hours for 21.8 GiB.
Hi guys,
I would like to reduce the size of this file: 10 hours for 21.8 GiB. The audio part (AAC) will be copied with ffmpeg. This file is a live event recorded with youtube-dl. Can anyone give me some settings for x265? Thanks Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 21,8 GiB Duration : 10 o 8 min Overall bit rate : 5.135 kb/s Writing application : Lavf58.33.100 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.2 Format settings : CABAC / 1 Ref Frames Format settings, CABAC : Si Format settings, RefFrames : 1 frame Format settings, GOP : M=1, N=30 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 10 o 8 min Bit rate : 5.034 kb/s Width : 1.920 pixel Height : 1.080 pixel Display aspect ratio : 16:9 Frame rate mode : Variabile Frame rate : 42,547 FPS Minimum frame rate : 0,016 FPS Maximum frame rate : 62,500 FPS Original frame rate : 60,000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bit Scan type : Progressive Bits/(Pixel*Frame) : 0.057 Stream size : 21,4 GiB (98%) Codec configuration box : avcC |
22nd December 2019, 01:35 | #2 | Link |
Herr
If you got a fast CPU, then this x265-setting is good,
--profile main10 --output-depth 10 --preset slower --crf 18 --no-sao --aq-mode 3 --rdoq-level 0 --psy-rdoq 0 Use the --crf 18 for high-quality, but if you want to compromise video-quality over file-size, then change to a higher crf-value, like 20. Also, maybe use you should the Avisynth-script TemporalDegrain2 if the video-source is too grainy for your taste. That video-source got variable frame-rate, I hope that it will cause no problem. Last edited by Forteen88; 22nd December 2019 at 15:58. Reason: included 10-bits setting. |
22nd December 2019, 06:18 | #4 | Link | |
ffx264/ffhevc author
But to each his own... PS: i do 10 bits encodes only so this has an effect too |
22nd December 2019, 11:40 | #5 | Link |
Angel of Night
To save anything at all, since YouTube 1080p is already a fairly low 5mbps, you'd have to start with a crf of at least 25 and go up from there if it still isn't enough. (5mpbs will generally be between 18 and 24, though YMMV by video.) You're already working with mediocre Youtube-quality source, and the only way you have to really save bits is to murder quality even further. How far do you want to go?
Dropping it to 720p might actually help significantly, though. I'd probably just put some time into editing the 10 hour video down, to save whole swaths of bits that don't need to be encoded at all. |
22nd December 2019, 15:57 | #6 | Link |
Herr
True, 10 bits is the way to go with x265. Weird, I thought that 10 bits was the default --output-depth value in x265, but I just looked it up, and saw that it's not (at least not in the x265-build I use), default is 8!
You might want to add: --frame-threads 1 in the commandline for better picture-quality, but if you got many cores on your CPU, then it will take longer time to encode (since x265 don't use all cores then). UPDATE: froggy1, OK, --frame-threads 2 might be a better value to set, for more CPU-core usage. Last edited by Forteen88; 30th December 2019 at 13:50. |
22nd December 2019, 16:43 | #7 | Link | |
22nd December 2019, 17:55 | #8 | Link | |
Lost my old account :(
22nd December 2019, 18:43 | #9 | Link | |
Herr
He could just encode something else (maybe even 3-4 encodes), simultaneously, if he wants 100% CPU-core use. Bitrate on the video-source is only 5k, so it seems very compressible, not a high detail source... TC (mindphasar) should probably better use 2-pass instead of CRF, to get the file-size he wants. Last edited by Forteen88; 22nd December 2019 at 19:25. Reason: 2-pass instead of CRF... |
22nd December 2019, 19:26 | #10 | Link | |
You really need to re-think your strategy. Encoding is all about compromise between how much speed you can or want to give up and how much quality you want to get. The trick is to find the right balance between the two If you don't mind encoding at 0.1 fps and wait a whole month for a single (or a few encodes if you use others simultaniously to saturate the CPU in case of 1 frame thread) and think this will somehow improve quality so much that it's obvious from an average distance from the TV/monitor, you're only deluding yourself |
22nd December 2019, 20:09 | #11 | Link |
Herr
froggy1. Personally (with my 6-core CPU), I like setting --frame-threads 1
because if I use all cores, then the computer gets quite unusable (laggy) for anything else. Setting --frame-threads 1 makes x265 take like 60-70% of my CPU. I don't encode a lot though, and I've never tried x265-encoding on a 12+ core CPU. EDIT: froggy1, yeah, thanks, I know about priority (crappy Windows10 that I use got that too), but I just don't bother with that (because I'm in no hurry when I encode, and then I don't need to stress out my CPU). Last edited by Forteen88; 22nd December 2019 at 20:30. Reason: priority-reply |
22nd December 2019, 20:21 | #12 | Link | |
I do encodes all the time (previously on an i7-7700K, now on a Ryzen 7 3700X) and spent a few days comparing different options and tweaking things in order to come up with something that improves quality (compared to the i7-7700K) and doesn't sacrifice too much speed on my new Ryzen 7 system. Using 1 frame threads wasn't even a consideration as there's no point in getting a Ryzen 7 for this As for sluggishness, you can make the encode run at the lowest possible priority and still have a responsive system. Sure, it'll take a bit longer if you do other stuff that uses most or all threads, but it's worth it. As you might guessed from my avatar, I'm on Linux and always run encodes at nice priority of 19 (lowest possible). There is absolutely no sluggishness here. Windows might be different so I can't comment on that |
22nd December 2019, 20:34 | #13 | Link |
Pig on the wing
On Windows, I use the command start /belownormal encode.bat to run the batch file which contains my job list. Works nicely, no sluggishness and wins over any stuff that is set for idle priority but goes to the background when something more urgent comes up. I just add stuff to the end of the file so my computer is basically encoding 24/7.
22nd December 2019, 23:28 | #14 | Link |
Herr
By the way, not everyone here at Doom9 have high --frame-threads,
https://forum.doom9.org/showthread.p...04#post1852904 TC, you can also set --ctu 32 if you want more CPU-usage, --ctu 64 (default for --slower) should be set for UHD-video though. Last edited by Forteen88; 23rd December 2019 at 11:18. |
29th December 2019, 22:45 | #16 | Link |
thank you so much for the great suggestions guys. I don't know which settings are recommended for this huge file. I use debian 10.with ffmpeg, x265 and mkvmerge.
where i find a examples of 2pass with x265?. if I add --no-sao with CRF 19, it is not passed 19 but CRF-28.0 Why? x265 [info]: Main 10 profile, Level-3 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 2 / wpp(8 rows) x265 [warning]: Source height < 720p; disabling lookahead-slices x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3 x265 [info]: Keyframe min / max / scenecut / bias: 25 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 25 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 0 / 0 x265 [info]: References / ref-limit cu / depth : 4 / on / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-28.0 / 0.60 x265 [info]: tools: rect limit-modes rd=4 psy-rd=2.00 rdoq=2 psy-rdoq=1.00 x265 [info]: tools: rskip signhide tmvp strong-intra-smoothing my goal is to reduce the size of this file, if it is convenient to do a similar action, obviously I have an asus Bluray 16x recorder. this script is ok? #!/bin/bash ffmpeg -i "10 hours.mp4" -pix_fmt yuv420p10 -s 720x408 -aspect 16:9 -strict -1 -an -f yuv4mpegpipe - | x265 --y4m - --preset slow --tune fastdecode --no-high-tier --ref 3 --rc-lookahead 5 -b 3 --profile main10 --crf 19 --deblock -4:-4 --output-depth 10 --dither --wpp -o "raw_video.hevc" |
30th December 2019, 03:54 | #17 | Link |
If you have a bluray burner, just burn the file to disc as I suggested. Or even use any of the free authoring programs to create an actual bluray. It will take 1 single layer bluray to keep the file as it is, which typically cost $0.50 when they are bought in a 50 pack. You will waste more money in electricity converting this than the price of a bluray.
30th December 2019, 13:38 | #18 | Link | |
Herr
And you should rather set --deblock -3:-3 or as high as you accept (I usually set it to --deblock -2:-2), since the compression gets better then. You can use an encoding-GUI like "Simple x264/x265-launcher" (available here at Doom9) to encode 2-pass, but don't forget to update x265 in that package, because that developer doesn't update that program often. EDIT: Although you didn't really apply any of my advice, so IDC. Last edited by Forteen88; 30th December 2019 at 13:57. |
30th December 2019, 18:41 | #19 | Link |
結城有紀
10 hours live event 1920x1080 60fps at 5034kbps is fairly low.
I have been encoding some live events from TV broadcasting (source is at much higher bitrate -- less artifacts), and 10-bit 1440x1080 60fps CRF24 costs 7500kbps, and that's after a heavy denoising (which saves a good portion). So a good chance is you'd come back at a much worse, terrible quality for an even bigger file. EDIT: Just saw you're re-encoding it to 400p. That would make it small but still it would be at much worse quality.
Projects x265 - Yuuki-Asuna-mod Download / GitHub TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median Last edited by MeteorRain; 30th December 2019 at 18:44. |
30th December 2019, 19:43 | #20 | Link | |
As for rc-lookahead, the more you increase it, the more efficient adaptive quantization will be. rc-lookahead cannot be greater than the max keyframe. I use a value of 100 here (max-keyframe set to 240). Also rc-lookahead has an impact on latency. Lower values provide better latency at the expense of less effectiveness of adaptive quant (and less accurate scenecut decision) Last edited by microchip8; 30th December 2019 at 19:46. |
x265 |
