27th April 2017, 13:13 | #1301 | Link |
With the great help of real.finder:
New release: TIVTC 1.0.7 (x86/x64) Please, still treat it as beta (due to moving all inline asm parts to simd intrinsics, plus new SSE2 parts), but of course feedback is appreciated. Code:
**v1.0.7 (20170427)** - fix crash in FieldDiff (in new SIMD SSE2 rewrite) **v1.0.6 (20170421) - pinterf** - project migrated to VS 2015 - AVS 2.6 interface, no Avisynth 2.5.x support - some fixes - x64 port and readability: move all inline asm to simd intrinsics or C - supports and requires SSE2 - MMX and ISSE is not supported, but kept in the source code for reference - source code cleanups **v1.0.5 (2008) - tritical** - see old readmes |
27th April 2017, 17:08 | #1302 | Link |
Tested four versions:
1.0.5 original 1.0.5 vc10 rebuild 1.0.7 with inline asm (my internal test build) 1.0.7 with simd intrinsics (release) All 32 bits for comparison The latter two is bit identical which is good news. Speedwise: all same, vc10 build is slower by 4-5%. The two 1.0.5 builds gave slightly different result. 1.0.7 build is showing differences to 1.0.5 on frame by frame comparison, they are almost the same, but it general 1.0.7 gave less false combed frames. Tested on an interlaced anime clip, that I was given once in PM. Last edited by pinterf; 28th April 2017 at 06:52. Reason: typos |
30th April 2017, 07:34 | #1303 | Link |
New TIVTC build.
TIVTC 1.08 (beta) (simd intrinsics rewrite fix) Thanks to mizumanju for the report. Code:
**v1.0.8 (20170429)** - Fix: TFM PP=2 and PP=5 (Blend deint) |
5th June 2017, 15:18 | #1304 | Link |
When using with QTGMC with presets Medium to Very Fast it just crashes for me.
QTGMC with presets Slow+ works fine. Regardless QTGMC preset works fine using http://www.mediafire.com/file/i2qtli..._3-13-2010.rar . |
5th June 2017, 23:26 | #1307 | Link |
Preview on Avspmod trows a generic error "%d format: a number is required, not float." but it previews anyway.
Launching x264 on cli just makes process stop responding without any error msg. I'm available to debug it, but i need some help on what to do. |
6th June 2017, 07:05 | #1308 | Link | ||
6th June 2017, 13:10 | #1309 | Link | |
6th June 2017, 13:13 | #1310 | Link | |
6th June 2017, 13:49 | #1311 | Link |
Yes,
AVSMeter -avsinfo would definitely help. And that would answer some other questions, too, such as Avs version, 32 or 64 bits, etc. My 1.08 build is SSE2 only, requires it and does not use higher processor features than that. |
6th June 2017, 15:25 | #1312 | Link | ||
Last edited by downloaded; 6th June 2017 at 15:27. Reason: remove sensitive info |
6th June 2017, 15:57 | #1313 | Link |
@downloaded
Hard to say why it crashes with x264 but it doesn't seem to be a problem in the filter chain since it works with AVSMeter. As for the missing plugin directory references - How exactly did you install Avisynth+ and how did you update to the latest version? You should do a clean install as I suggested here. |
6th June 2017, 16:06 | #1314 | Link |
I suppose you are using 64 bit x264. Still, since you have no autoloaded plugins, I cannot tell from this avsinfo the DLL versions you are exactly using.
I tried to encode a qtgmc'd clip with similar frame dimensions and frame rate, but no crash at all. x264 x64 version of r2665 |
6th June 2017, 16:54 | #1315 | Link | ||
SetFilterMTMode("DEFAULT_MT_MODE", 2) AddAutoloadDir("C:/xxxxxxxxxxxxxxxxxxxx") ffvideosource("C:\xxxxxxxxxxxxxxxxxxx.mkv") ConvertToYV12() AddBorders(0, 2, 0, 0) QTGMC(Preset="Very Fast",EdiThreads=2).selecteven() tdecimate(cycleR=1,cycle=5) Crop(2,2,-4,-2) Prefetch(4) |
6th June 2017, 19:46 | #1316 | Link | ||
7th June 2017, 07:31 | #1318 | Link |
Ok, now I know your script, I will run tests with those parameters
EDIT: successfully crashed after changing x264 version to r2762. EDIT 2: Exception thrown at 0x000000014001D63F in x264_64.exe: 0xC0000005: Access violation reading location 0x00000000C101AD62. EDIT 3: latest Komisar build x264.2833.x86_64.exe is working again, please try that one. Last edited by pinterf; 7th June 2017 at 08:33. Reason: new test result |
7th June 2017, 09:30 | #1319 | Link |
This is the one i was using and crashing:
x264 0.150.2833 df79067 (libswscale 4.7.101) (libavformat 57.72.101) (ffmpegsource 2.23.0.0) built by Komisar on May 26 2017, gcc: 4.9.2 (multilib.generic.Komisar) x264 configuration: --bit-depth=8 --chroma-format=all libx264 configuration: --bit-depth=8 --chroma-format=all x264 license: GPL version 2 or later libswscale/libavformat/ffmpegsource license: GPL version 2 or later Code:
x264 0.150.2833kMod df79067 (libswscale 4.7.101) (libavformat 57.72.101) (ffmpegsource 2.23.0.0) built by Komisar on May 26 2017, gcc: 4.9.2 (multilib.generic.Komisar) x264 configuration: --bit-depth=8 --chroma-format=all libx264 configuration: --bit-depth=8 --chroma-format=all x264 license: GPL version 2 or later libswscale/libavformat/ffmpegsource license: GPL version 2 or later |
7th June 2017, 18:44 | #1320 | Link |
If TIVTC is updated again sometime in the future, the version numbers it writes to the output files it creates (2 pass or VFR mode) could do with an update too.
The TFM metrics file starts like this: #TFM v1.0.4 by tritical field = top crc32 = 385d356e 0 h + [256] The TDecimate output file looks like this: #TDecimate v1.0.3 by tritical crc32 = f76ebc82, blockx = 32, blocky = 32, chroma = T 21885 12119 361525 And the timecodes file created by TDecimate: # timecode format v1 Assume 29.970030 # TDecimate v1.0.3 by tritical # Mode 5 - Auto-generated mkv timecodes file |
tdeint, tivtc |
