12th September 2009, 03:27 | #5723 | Link |
I am currently useing windows 7 32 bit version and RipBot 1.14.3 and i was wondering if you have a fix for an issue i am having. It stops at the stage "Please Wait... Gathering Information..." i was just wondering if you knew how to fix this issue. Thanks in advance.
12th September 2009, 03:36 | #5724 | Link | |
http://jeeb.fiveforty.jp/x264/1235/x264.exe |
12th September 2009, 05:17 | #5725 | Link | ||
12th September 2009, 17:21 | #5728 | Link |
other people are having issues going from blu-ray to avchd (bd-r size output) with transcoded video/lpcm (stream copy from dolby truehd)? i ALWAYS get an error when tsmuxer tries to mux the transcoded video/lcpm audio (lpcm bad frame detected).
clownbd works fine created a lcpm .wav from truehd that tsmuxer will accept. here are logs from clownbd (can we get the same lpcm audio handling in ripbot264)? eac3to v3.16 command line: "C:\Program Files\Clown_BD_v0.66\eac3to\eac3to.exe" "C:\Tasks\TRANSFORMERS" -LOG="C:\Users\Administrator\Desktop\Conversion\eac3to_PASS1_LOG.LOG" ------------------------------------------------------------------------------ 1) FEATURE_1.EVO+FEATURE_2.EVO, 2:23:19 "Main Movie" - h264/AVC, 1080p (16:9) - VC-1, 480p (16:9) - E-AC3, English, 5.1, 48khz - E-AC3, French, 5.1, 48khz - E-AC3, Spanish, 5.1, 48khz - E-AC3, English, 2.0, 48khz, "Director Commentary" 2) TRAILER_IRONMAN.EVO, 0:02:28 "IronMan" - h264/AVC, 1080p (16:9) - E-AC3, English, 5.1, 48khz 3) TRAILER_TEASER.EVO, 0:01:53 "Teaser Trailer" - h264/AVC, 1080p (16:9) - E-AC3, English, 5.1, 48khz 4) TRAILER_AUTOBOTS.EVO, 0:01:14 "Trailer3" - h264/AVC, 1080p (16:9) - E-AC3, English, 2.0, 48khz eac3to v3.16 command line: "C:\Program Files\Clown_BD_v0.66\eac3to\eac3to.exe" "C:\Tasks\TRANSFORMERS" 1) -LOG="C:\Users\Administrator\Desktop\Conversion\eac3to_PASS2_LOG.LOG" ------------------------------------------------------------------------------ EVO, 2 video tracks, 5 audio tracks, 8 subtitle tracks, 2:23:26 1: Joined EVO file 2: Chapters, 23 chapters with names 3: h264/AVC, 1080p24 /1.001 (16:9) with pulldown flags 4: VC-1, 480p30 /1.001 (3:2), -84ms 5: E-AC3, English, 5.1 channels, 1536kbps, 48khz, dialnorm: -27dB, -84ms 6: E-AC3, French, 5.1 channels, 768kbps, 48khz, dialnorm: -27dB, -84ms 7: E-AC3, Spanish, 5.1 channels, 768kbps, 48khz, dialnorm: -27dB, -84ms 8: E-AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -84ms "Director Commentary" 9: E-AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -111ms 10: Subtitle (DVD), English 11: Subtitle (DVD), English, "SDH" 12: Subtitle (DVD), French 13: Subtitle (DVD), Spanish 14: Subtitle (DVD), Portuguese 15: Subtitle (DVD), French, "Forced" 16: Subtitle (DVD), Spanish, "Forced" 17: Subtitle (DVD), English, "HUD Trivia Track" eac3to v3.16 command line: "C:\Program Files\Clown_BD_v0.66\eac3to\eac3to.exe" "C:\Tasks\TRANSFORMERS" 1) 2: "C:\Users\Administrator\Desktop\Conversion\Chapters_2.txt" 3: "C:\Users\Administrator\Desktop\Conversion\Video_3.*" 5: "C:\Users\Administrator\Desktop\Conversion\Audio_5_English.WAV" -LOG="C:\Users\Administrator\Desktop\Conversion\eac3to_PASS3_LOG.LOG" ------------------------------------------------------------------------------ EVO, 2 video tracks, 5 audio tracks, 8 subtitle tracks, 2:23:26 1: Joined EVO file 2: Chapters, 23 chapters with names 3: h264/AVC, 1080p24 /1.001 (16:9) with pulldown flags 4: VC-1, 480p30 /1.001 (3:2), -84ms 5: E-AC3, English, 5.1 channels, 1536kbps, 48khz, dialnorm: -27dB, -84ms 6: E-AC3, French, 5.1 channels, 768kbps, 48khz, dialnorm: -27dB, -84ms 7: E-AC3, Spanish, 5.1 channels, 768kbps, 48khz, dialnorm: -27dB, -84ms 8: E-AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -84ms "Director Commentary" 9: E-AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -111ms 10: Subtitle (DVD), English 11: Subtitle (DVD), English, "SDH" 12: Subtitle (DVD), French 13: Subtitle (DVD), Spanish 14: Subtitle (DVD), Portuguese 15: Subtitle (DVD), French, "Forced" 16: Subtitle (DVD), Spanish, "Forced" 17: Subtitle (DVD), English, "HUD Trivia Track" Creating file "C:\Users\Administrator\Desktop\Conversion\Chapters_2.txt"... [a05] The Nero decoder doesn't seem to work, will use libav instead. [v03] Extracting video track number 3... [a05] Extracting audio track number 5... [v03] Removing h264 pulldown... [a05] Removing E-AC3 dialog normalization... [a05] Decoding with libav/ffmpeg... [a05] Remapping channels... [a05] Applying RAW/PCM delay... [a05] Reducing depth from 64 to 24 bits... [a05] Writing WAV... [a05] Creating file "C:\Users\Administrator\Desktop\Conversion\Audio_5_English.WAV"... [v03] Creating file "C:\Users\Administrator\Desktop\Conversion\Video_3.h264"... [a05] Clipping detected, a 2nd pass will be necessary. <WARNING> [a05] Caution: The WAV file is bigger than 4GB. <WARNING> [a05] Some WAV readers might not be able to handle this file correctly. <WARNING> [a05] Starting 2nd pass... [a05] Extracting audio track number 5... [a05] Removing E-AC3 dialog normalization... [a05] Decoding with libav/ffmpeg... [a05] Remapping channels... [a05] Applying RAW/PCM delay... [a05] Reducing depth from 64 to 24 bits... [a05] Writing WAV... [a05] Creating file "C:\Users\Administrator\Desktop\Conversion\Audio_5_English.WAV"... [a05] Caution: The WAV file is bigger than 4GB. <WARNING> [a05] Some WAV readers might not be able to handle this file correctly. <WARNING> Video track 3 contains 206368 frames. Video track 4 contains 243564 frames. eac3to processing took 29 minutes, 13 seconds. Done. eac3to v3.16 command line: "C:\Program Files\Clown_BD_v0.66\eac3to\eac3to.exe" "C:\Users\Administrator\Desktop\Conversion\Audio_5_English.WAV" "C:\Users\Administrator\Desktop\Conversion\Audio_5_English.W64" -LOG="C:\Users\Administrator\Desktop\Conversion\eac3to_(Stream_5_English_.WAV_to_.W64_Conversion)_LOG.LOG" ------------------------------------------------------------------------------ WAV, 5.1 channels, 2:23:27, 24 bits, 6912kbps, 48khz Reading WAV... Writing W64... Creating file "C:\Users\Administrator\Desktop\Conversion\Audio_5_English.W64"... The original audio track has a constant bit depth of 24 bits. eac3to processing took 5 minutes, 4 seconds. Done. "conversion.meta" MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 V_MPEG4/ISO/AVC, "C:\Users\Administrator\Desktop\Conversion\Video_3.h264", insertSEI, contSPS A_LPCM, "C:\Users\Administrator\Desktop\Conversion\Audio_5_English.W64", lang=eng Command Line="C:\Program Files\Clown_BD_v0.66\tsMuxeR\tsMuxeR.exe" "C:\Users\Administrator\Desktop\Conversion\Conversion.meta" "C:\Users\Administrator\Desktop\Output\Conversion.M2TS" SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1920:1080p Frame H.264 muxing fps not set. Get fps from stream. H.264 stream does not contain fps field. Muxing fps=23.976 0.0% complete Decoding LPCM stream (track 2): Bitrate: 6912Kbps Sample Rate: 48KHz Channels: 100.0% complete Processed 206368 video frames 100.0% complete Mux successful complete. Muxing time: 15 min 25 sec Last edited by slow4mula; 12th September 2009 at 17:31. |
12th September 2009, 18:18 | #5729 | Link |
it just dawned upon me i can use clownbd to produce a tsmuxer compatible lpcm .wav and then launch ripbot, let it demux also, and then just feed it the .wav created from clownbd and stream copy while still having ripbot calc size and transcode video.
i'm doing transformers hd-dvd but i figure it should work, then i will do the dark knight blu-ray |
12th September 2009, 20:53 | #5731 | Link |
13th September 2009, 10:11 | #5736 | Link |
im about to convert the england V croatia HD game. Im going to stick with 1080p 50fps and i want to make it ps3/xbox 360 compatible.
i intend using mp4. anything i should be aware of, ie aac being an issue (only has 2 channel sound) or bit rates to keep below and such? |
13th September 2009, 11:53 | #5737 | Link | |
@slow4mula I will add extra conversion from.wav to .w64 later. At the moment I'm in Poland on holidays.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th September 2009 at 11:55. |
13th September 2009, 12:53 | #5738 | Link |
I've got 2 questions regarding ripbot264.
1. Batchconversions. When I have a couple of Videofiles who have all the same properties and I want to encode them all with exactly the same settings, is there any way to accomplish thatexcept for using "add" for each file individually? 2. I'm using Win7, the latest ripbot version and when I add a video ripbot never finishes the "Please wait... Gathering information step..." Any ideas? |
