Old 18th March 2016, 01:55   #14281  |  Link
howzz
here is the Virustotal.com scan result. looks like 3 out of 44 AV picked it up as malware.
SHA256: c3c81db9b9ecd2d6e30518d300e8f2f9a7cc08fa0eb26aaabf7bfc08646ebd5d
File name: RipBot264v1.19.2.7z
Detection ratio: 3 / 44
Analysis date: 2016-03-18 00:50:59 UTC ( 1 minute ago )
0 1
Analysis
Relationships
Additional information
Comments
Votes
Antivirus Result Update
AegisLab Possible.Virus.Gen!c 20160317
Avast Win32:Malware-gen 20160317
Jiangmin Worm/NetSky.ji 20160318
ALYac 20160317
AVG 20160318
AVware 20160318
Ad-Aware 20160317
Agnitum 20160316
AhnLab-V3 20160317
Alibaba 20160317
Antiy-AVL 20160317
Arcabit 20160317
Baidu 20160317
Baidu-International 20160317
BitDefender 20160318
Bkav 20160317
ByteHero 20160318
CAT-QuickHeal 20160317
CMC 20160316
ClamAV 20160317
Comodo 20160318
Cyren 20160318
DrWeb 20160318
ESET-NOD32 20160317
Emsisoft 20160318
F-Prot 20160318
F-Secure 20160318
Fortinet 20160317
GData 20160318
Ikarus 20160318
K7AntiVirus 20160317
K7GW 20160318
Kaspersky 20160317
Malwarebytes 20160317
McAfee 20160318
McAfee-GW-Edition 20160317
eScan 20160317
Microsoft 20160316
NANO-Antivirus 20160317
Panda 20160317
Qihoo-360 20160318
Rising 20160317
SUPERAntiSpyware 20160317
Sophos 20160317
Symantec 20160317
Tencent 20160318
TheHacker 20160315
TrendMicro 20160317
TrendMicro-HouseCall 20160317
VBA32 20160317
VIPRE 20160317
ViRobot 20160317
Zillya 20160317
Zoner 20160317
nProtect 20160317
howzz is offline   Reply With Quote
Old 19th March 2016, 06:50   #14282  |  Link
legend
While Updating I Found this
legend is offline   Reply With Quote
Old 19th March 2016, 12:55   #14283  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
open updater.ini in notepad and change that date to 2000-01-01 00:00:00
Old 19th March 2016, 14:02   #14284  |  Link
burt123
burt123's Avatar
Hey Atak, I've been thinking about the trouble some guys are having with updates & version numbers.
With all due respect, may I suggest that with the next update, you could post a full setup (like you used to) and with a build number of, say, 1.19.4, and then after that, the auto updates continue for the new version for a time, then release another full version.
It's just that if someone wants to start from stratch, they don't have to start with what is now a fairly old build of 1.19.2., and then have to get all the updates that were released since then.
burt123 is offline   Reply With Quote
Old 19th March 2016, 14:11   #14285  |  Link
Atak_Snajpera
yes I will do that today but it won't be 1.19.4 but 'official 1.19.3'
Old 19th March 2016, 21:54   #14286  |  Link
soneca
Atak, it would be good to be updated in VideoHelp too.
soneca is offline   Reply With Quote
Old 19th March 2016, 23:55   #14287  |  Link
burt123
burt123's Avatar
You've already done this ?!?!
OK, I see that you have also added an audio amplification option, and I hate to be a PITA, but could you also have it go negative, as well, for files that are too loud ???
And what unit of measure are the adjustments ??
Sorry, and
Old 20th March 2016, 12:51   #14288  |  Link
Atak_Snajpera
unit is multiplication.
negative number won't fix too loud sounds.
Old 20th March 2016, 13:01   #14289  |  Link
burt123
burt123's Avatar
OK, will experiment.
Thanks
Old 20th March 2016, 15:50   #14290  |  Link
soneca
After this latest update the PC that works with KNLMeansCL no longer works.
Old 20th March 2016, 16:04   #14291  |  Link
Atak_Snajpera
This is your friend
vc_redist.x86.exe
https://www.microsoft.com/en-us/down....aspx?id=48145
Old 20th March 2016, 16:09   #14292  |  Link
soneca
With the 2013 version of Visual C ++ does not work anymore?
Old 20th March 2016, 16:11   #14293  |  Link
Atak_Snajpera
nope -> http://forum.doom9.org/showthread.ph...97#post1699497
Old 20th March 2016, 16:13   #14294  |  Link
soneca
Okay, I'll install!
Old 20th March 2016, 16:17   #14295  |  Link
soneca
Started working again!
Old 20th March 2016, 16:19   #14296  |  Link
deanoboxer
Malware
Norton identified RipBot264 Encoding Client.exe as malware this morning. Anybody else get the same?
deanoboxer is offline   Reply With Quote
Old 20th March 2016, 16:25   #14297  |  Link
Atak_Snajpera
Yet another stupid complain from retarded anti-virus software. I'm losing patience to this...
https://www.virustotal.com/en/file/1...is/1458487433/
I'm starting to think that currently it is impossible to write a program without any false positive alarms.
Old 20th March 2016, 21:36   #14298  |  Link
MaistroX
Hi Atak_Snajpera!
Thx for the great work throu the years with development of RipBot264!
Have a question that you might be able to answer...
I have allways been able to use RipBot264 without any problems, but the recent 6 month my PC have started to freez so I have been forced to restart it fully to get it to work again.
The problem ONLY appears with RipBot264 and it does freez in the first pass or in the beginning of the second.
As it only affects RipBot264 and no other software I have, my thought is that it has something to do with that RipBot264 gets my processor to 100% on all cores.
Any chance in RipBot264 that I can set it to ONLY use a certain amout of the processors Power, like only 80% or simular?
Regards MaistroX
MaistroX is offline   Reply With Quote
Old 21st March 2016, 00:04   #14299  |  Link
burt123
burt123's Avatar
Originally Posted by MaistroX View Post
Hi Atak_Snajpera!
Regards MaistroX
A couple of questions for you :-
1st:- is your PC overclocked ???
Ripbot could be considered as a stress test, as it DOES run the CPU @ 100% most of the time.
2nd:- how clean is it inside your case & motherboard etc ??
Sounds like it might be overheating, check & clean the CPU fan(s), and video card(s) fan(s).
I'm pretty sure that Ripbot can't be "throttled".
Old 21st March 2016, 00:58   #14300  |  Link
soneca
It is also why I use Nod32 long ago.
