14th November 2021, 08:45 | #1 | Link |
BD Rebuilder: Video encoding fails always
trying to encode BDs using latest build of BD Rebuilder (0.61.25) and also older builds at the moment ALWAYS failed...(??), no matter what the BD is. (running of course in administrator mode, Windows 10 V2004 Build 19041.546) Here is one log (of several identical logs): - Input BD size: 25,81 GB - Approximate total content: [01:19:58.770] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [08:27:10] PHASE ONE, Encoding - [08:27:10] Processing: VID_00000 (1 of 2) - [08:27:10] Extracting A/V streams [VID_00000] - [08:31:22] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 111.094 frames - Bitrate: 23.998 Kbs - [08:31:22] Reencoding: VID_00000, Pass 1 of 2 - Encode failed. Aborting. - BD-Rebuilder v0.61.25 - Windows Version: 6.2 [9200] - Working Path Free Space: 957,46GB - AVISYNTH Version: 2.6.0.1, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3133, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [08:31:24] - Failed video encode, aborted Any idea...? Help would be much appreciated.... Thanks |
15th November 2021, 14:23 | #2 | Link |
Immediately after it fails, look in the BD Rebuilder installation folder for a file called LASTCMD.TXT. Copy the contents of that file and paste it into a COMMAND window. When it fails it should give you an idea of what is happening. If you can't make sense of it, cut-and-paste the result into this thread so we can see it.
I suspect you may have to reinstall the helper apps again. Sometimes other installs can overwrite settings/apps and cause this kind of issue. |
15th November 2021, 18:53 | #3 | Link |
@jdobbs
Thanks for your quick help ! I've done what you told me... in cmd I got this error : avs [error]: DirectShowSource: couldn't open file K:\XXXXX_DL\Video_source_name\BDMV\STREAM\00015.m2ts: Klasse nicht registriert (L:\_BD-REBUILDER_WORK_\WORKFILES\VID_00015.AVS, line 2) x264 [error]: could not open input file `L:\_BD-REBUILDER_WORK_\WORKFILES\VID_00015.AVS' Anything I can do about it ? |
15th November 2021, 22:07 | #4 | Link |
It looks like the source file "K:\XXXXX_DL\Video_source_name\BDMV\STREAM\00015.m2ts" doesn't exist anymore at the time of the encode. You haven't, by chance, unmounted that device have you?
The error seems to say that a class is not registered "Klasse nicht registriert". You may want to do a search for that error. I did a quick look and saw something about a DLL that may not be registered with the O/S. Also, you may want to try renaming your working folder so it doesn't begin with a special character ("_"). Last edited by jdobbs; 18th November 2021 at 14:23. |
16th November 2021, 17:10 | #5 | Link |
The source file 00015.m2ts of course does exist and I did not unmount any drive...
But then... I re-installed all the "helpers" as you recommended before, FFDSHOW and the Matroska Splitter as well as AVISYNTH, just as you described in the README.txt file which comes with BD-Rebuilder, taken from the links you enclosed. Then I registered MSCOMCTL.OCX (regsvr32 MSCOMCTL.OCX) manually in cmd (administrator). The result: Everything seems to work fine now !! Thanks again for your help ! |
