18th March 2021, 21:13 | #161 | Link | |
See My Avisynth Stuff |
18th March 2021, 21:45 | #162 | Link |
nnedi3_rpow2 splits and process the channels in "Y only", and after recomb using "YtoUV".
You can even if you want write an avs script using "PlaneToY", "nnedi3" and "YtoUV". So when "YtoUV" is used to "regroup" output data when inpiut data was checked Is420(), i think it's automaticaly tagged to YV12. The nnedi3_rpow2 function is like an avs script. I don't know if there is a function to put back original vi.pixel_type...
My github. |
19th March 2021, 08:11 | #163 | Link |
For Avisynth it is all the same, YV12 or I420.
That's why VideoInfo::IsSameColorspace has a second test for colorspace. Both formats report "true" on IsYV12(). https://github.com/AviSynth/AviSynth...rface.cpp#L332 |
19th March 2021, 12:41 | #164 | Link |
So, the proper way is not
if (vi.pixel_type!=vi2.pixel_type) Code:
if (!vi.IsSameColorspace(vi2)) I mean, if there is a IsSameColorspace function, using it is the proper way...
My github. Last edited by jpsdr; 19th March 2021 at 13:21. |
19th March 2021, 17:30 | #165 | Link |
It is sometimes nice to be able to see the Baked code in the original v2.58 header, to give a clue about what its gonna do.
I'm not suggesting that you use same as v2.58 header, just taking a peek into the black box is sometimes informative. Here is from v2.58 header Code:
// Test for same colorspace bool IsSameColorspace(const VideoInfo& vi) const { if (vi.pixel_type == pixel_type) return TRUE; if (IsYV12() && vi.IsYV12()) return TRUE; return FALSE; } Code:
bool IsYV12() const { return ((pixel_type & CS_YV12) == CS_YV12)||((pixel_type & CS_I420) == CS_I420); }
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th March 2021 at 17:43. |
29th March 2021, 18:55 | #166 | Link |
Begin to investigate.
First thought ChromaPlacement was the issue, but it seems not. cplace parameter has no effet. Put configuration to be on "C" codepath only (this is why "MPEG2"). This also has issue : Code:
SetMaxCPU("SSE2") ColorBars(width=640, height=480, pixel_type="yv24").PlaneToY("Y") convertbits(16) awarp4(Spline36Resize(640*4,480*4),asobel(thresh=255).ablur(),depth=6,threads=1,cplace="MPEG2") What is the unit of depth, how should it be changed (or not) accordinb bit depth... Still investigatig.
My github. |
1st May 2021, 07:14 | #168 | Link |
awarp4 bug with HBD seems fixed, thanks
2nd June 2021, 08:33 | #169 | Link |
I'll continue the aWarpsharp (well Sobel) issues here. I'll push something latter, i'll try to think at something a little different.
Edit I'm working on something different, having a specific code for the first and last pixel, but keeping alignment.
My github. Last edited by jpsdr; 2nd June 2021 at 10:59. |
22nd July 2023, 05:02 | #177 | Link |
As a reminder, awarp4 was fixed back then https://github.com/jpsdr/aWarpSharpM...f2990bf0a00cc9
