Old 23rd October 2022, 14:16   #601  |  Link
jpsdr
Ah, ok... If you where using the whole package AND several of my filters, you'll reach the user limit sooner as there is only one threadpool for everyone (but it's the purpose to avoid creating a lot of thread), and using the dll of each filter instead, each filter having its onw threadpool, the limit is reached leater because there is one threadpool/filter, and the limit is by threadpool, but it will produce more threads.
My github.
Old 23rd October 2022, 15:08   #602  |  Link
In DBSC script, I am usually quite happy to use Spline36Resize(), however for a particular case I wanted to use Nnedi3.
We find scene cuts and for each one, trim() and find current border and crop it, then resize that to input size (only a bit bigger).
However, for this job I also was wanting to resize to 1:1 SAR at some later point (after DBSC) so thought maybe best to do a single resize
inside of the DBSC script instead of having two upsize steps.
(Src = DVD PAL 4:3, resize wider for 1:1 SAR, eg 768x576)
Spline36Resize is ok for the smaller upsize, I guess a man on a galloping horse could not spot the difference.
Old 31st October 2022, 03:06   #603  |  Link
agressiv
Registered Loser
agressiv's Avatar
I'm having corruption using nnedi_rpow2 when any sort of Prefetch command is enabled on my 16-core Ryzen 5950x. My 6-core Intel never has a problem no matter what I set Prefetch to.
* Symptom: Stuttering/sync loss for an encode (first 30 frames or so - basically about 5-10 frames will "repeat" themselves
* Remove nnedi_rpow2, problem never occurs
* Tried removing all other filters
* Even setting AVS Prefetch to "2" has same behavior.
* Tried combinations of threads=1, prefetch=1 etc in the nnedi_rpow2 parameters
* Tried changing to MT_SERIALIZED, MT_NICE_FILTER, no effect
* If I remove Prefetch from the Avisynth script itself, it works fine (but obviously much slower because I'm using McDegrainSharp as well)
I'm not sure if it's the high core count or just AMD itself, anyone else ever see this?
Edit: AviSynth+ 3.7.2 64-bit
agressiv is offline   Reply With Quote
Old 31st October 2022, 06:32   #604  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I've seen similar things happen with MVTools functions. Try adding RequestLinear(clim=100) right after the source line and see if it helps. That one's in the TIVTC package I think.
Old 31st October 2022, 06:42   #605  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Just FYI, the whole point of having plugins_JPSDR.dll is for them to create their own optimised and multithreaded theadpool. TL;DR you guys don't really need Prefetch() with Jean Philippe's plugins. Heck, you'll get better performances without it than with it.
Old 31st October 2022, 14:20   #606  |  Link
agressiv
Registered Loser
agressiv's Avatar
Thanks! This RequestLinear() bit seems to fix it. I'll mess with it some more.
I'd love to not have to use Prefetch at all, but most of the MvTools (McDegrainSharp) stuff needs it or it's a huge performance hit - unless you know of a way around that?
Old 31st October 2022, 14:49   #607  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Unfortunately there's no way around MVTools.
There used to be a way with avstp.dll but it ended up being buggy and causing freezes, so now that it has been removed, MVTools will run single-threaded unless you use Prefetch, which is really a shame...
Ferenc is trying to fix it, but none of us seem to understand what is going on... (and if even the Supreme Grandmaster Ferenc Pinter can't properly get what's causing it, no one can).
Here: https://github.com/pinterf/mvtools/issues/46
Old 31st October 2022, 15:00   #608  |  Link
kedautinh12
Maybe next gen handsome FranceBB can
kedautinh12 is online now   Reply With Quote
Old 31st October 2022, 15:06   #609  |  Link
I dont have problems using nnedi_rpow2("Spline36Resize") and McDegrainSharp(). [maybe a bit stutter on start only in player <eg VD2>, not encode]
I do use SetMTMode.avsi in Plugins.
last few lines
# Filters from MVTools v2.6.0.5 (from http://forum.doom9.org/showthread.php?p=1386559#post1386559 ) Tested On 2016/03/06
SetFilterMTMode("MSuper",              MT_MULTI_INSTANCE)
SetFilterMTMode("MAnalyse",            MT_MULTI_INSTANCE)
SetFilterMTMode("MFlowFps",            MT_MULTI_INSTANCE)
SetFilterMTMode("MRecalculate",        MT_MULTI_INSTANCE)
#Filters from EEDI2 v0.9.2 (from http://forum.doom9.org/showthread.php?t=173238 ) Tested On 2016/03/06
SetFilterMTMode("EEDI2",               MT_MULTI_INSTANCE)
SetFilterMTMode("MPP_SharedMemoryClient", 2) # real.finder
SetFilterMTMode("MPP_SharedMemoryServer", 3) # real.finder
SetFilterMTMode("RoboCrop",   MT_SERIALIZED)    # ADDED by me (always used close to source filter)
SetFilterMTMode("AutoLevels", MT_SERIALIZED)
#keep it the last line please
if (FunctionExists("avstp_set_threads")) {
    # this isn't actually optimal, because it will also disable avstp threads if running
    # on a single-threaded filter chain
    avstp_set_threads(0, 1)   #disable threading in dither
However, in my usual render script I detect if upsize [where we would use nnedi_rpow2] and also McDegrainSharp, and if so then
I use McDegrainSharp before upsize and after Spline36Resize if downsizing.
EDIT:
In my SetMTMode.avsi there is this line below [but no entry for nnedi_rpow2()]
SetFilterMTMode("NNEDI3",               MT_MULTI_INSTANCE)
EDIT: "in my usual render script",
a BIG script function that takes a LOT of Global vars [with defaults if not existing] to configure the outcome.
We use Avisynthesizer_Mod / DGIndex / DGIndexNV templates to create scripts with default config Globals, and tweak
a few globals where required.
EDIT:
First few lines of a DGIndex / DGIndxNV template (can work Ok for both dgindex and dgindexNV)
#ASYNTHER Progressive_169_Robo
VideoFileName   ="__vid__"
AudioFileName   =LCase("__aud__")
AudioDelay      =Value("__del__")
vExt = GetFilenameExtension(VideoFileName)
If(vExt == ".dgi")  { DGSource(VideoFileName)    } # DGIndexNV
Else                { Mpeg2Source(VideoFileName).TFM(d2v=VideoFileName) } # DGIndex : Auto check via TFM illegal transitions
AudioExt = GetFilenameExtension(AudioFileName)
Audio=      (AudioExt==".ac3") ? NICAC3Source(AudioFileName,channels=2,DRC=0)
        \ : (AudioExt==".mpa"||AudioExt=="mp1"||AudioExt==".mp2"||AudioExt==".mp3") ? NicMPG123Source(AudioFileName,Normalize=False)
        \ : (AudioExt==".wav") ? RaWavSource(AudioFileName)
        \ : (AudioExt==".dts") ? NicDTSSource(AudioFileName)
        \ : (AudioExt==".w64") ? RaWavSource(AudioFileName,samplerate=6)
        \ : 0
Assert(!isInt(Audio),"NO AUDIO")
(!isInt(Audio)) ? AudioDub(Audio).DelayAudio(AudioDelay).Trim(0,0) : NOP    # Trim, chop/add audio to length
(!isInt(Audio) && AudioRate() <> 44100) ? ResampleAudio(44100) : NOP
#AssumeTFF                       # not needed, both DGIndexNV and DGIndex set field order
#ConvertToYV24(Interlaced=False) # Optional
#Return last
### Status
Global G_FILECOUNT=1
### Debugging
Global G_DEBUG=True
### DeBlock(G_DEBLOCK)
Global G_DEBLOCK=0                  # Debloock setting
### QueryBorderCrop AND AutoContrast
Global G_SAMPLES=40
### QueryBorderCrop
Global G_QBC=True                # Switch On Border Cropping
    Global G_QBC_THRESH=-40.0        Global G_QBC_IGNORE = 0.2
    Global G_QBC_LEFTADD=0           Global G_QBC_TOPADD=0          Global G_QBC_RIGHTADD=0            Global G_QBC_BOTADD=0    # Additional cropping if still some border
    Global G_QBC_WMOD=2              Global G_QBC_HMOD=2        # Width/height multiple of these
    Global G_QBC_RLBT=$F                                            # Bits left to right, R,L,B,T                               # Edges to crop
    Global G_QBC_LACED=False
    Global G_QBC_SHOW=false
### AutoLevels
Global G_AL_AUTOALEVELS=False
    Global G_AL_IGNORE_LO   = 100.0/512
    Global G_AL_IGNORE_HI   = G_AL_IGNORE_LO
    Global G_AL_RADIUS      = 30
    Global G_AL_SC2TH       = 8
    Global G_AL_SC2PERC     = 100.0/3
    Global G_AL_MINRNG      = 110
    Global G_AL_INPUTLO     = RT_UNDEFINED
    Global G_AL_INPUTHI     = RT_UNDEFINED
    Global G_AL_AUTOGAMMA   = 1                       # 1 = NO Change, 0=Auto, else Gamma
    Global G_AL_MIDPOINT    = 0.5
    Global G_AL_GAMMAX      = 1.5                     Global G_AL_GAMMIN=1.0/G_AL_GAMMAX
    Global G_AL_BORD_L      = 16                       Global G_AL_BORD_T=16                     Global G_AL_BORD_R=16                  Global G_AL_BORD_B=16
    Global G_AL_DEBUG       = False
    Global G_AL_PRELIMITER  = True
    Global G_AL_MERGE       = 0.3
Old 20th November 2022, 15:14   #610  |  Link
jpsdr
New version, see first post.
@StainlessS
Can you check if this new version still have the issue of "not being able to get UserId" on your "insane" script ?
My github.
Old 20th November 2022, 19:29   #611  |  Link
Thanks, will do but not right now, doin' significant re-write.
EDIT:
insane" script
The script is maybe a prototype to find something that works prior to conversion to C/CPP.
(I'm currently tryin' to figure out how it works - you get more stupid as you get older.)
[ SHUT-UP! FranceBB. ]
Old 26th February 2023, 12:35   #612  |  Link
jpsdr
My github.
Old 20th November 2023, 21:56   #613  |  Link
jpsdr
New version, see first post, but nothing big...
My github.
