Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Old 4th November 2012, 05:17   #1  |  Link
six13
Playing DVD+R DL in Blu Ray player
Just bought a Samsung BD E5900 blu-ray player and when I put a burnt Verbatim DVD+R DL in the player it says it isn't compatible, it plays fine in my DVD player and DVD is clean in great shape. Now when I burnt the DVD I book typed it as a DVD-ROM as it was the norm. My manual says the BD E5900 won't play DVD-ROM, is there any way to burn DL disks so my player will accept them, what about DVD-Video format? I use ImgBurn on all my DVD's.
thanks in advance.
six13 is offline   Reply With Quote
Old 4th November 2012, 07:24   #2  |  Link
setarip_old
setarip_old's Avatar
Hi!
I haven't heard that before about ANY standalone Blu-ray player - but I'd presume that if that's the case, it won't play burned DVDs either...
I just read the specs and it certainly DOES play DVD-ROMs:
http://www.samsung.com/hk_en/consume...-E5900/ZK-spec
Playable Disc Type
3D Blu-ray
Blu-ray Video
DVD-Video/DVD±R/DVD±RW
CD/CD-R/CD-RW
VCD 1.1
It should also play any of the burnable media formats listed at their site - unless it doesn't "like" the brand of burnable media you are using...
What is the content and format of the problematic disc you burned?
setarip_old is offline   Reply With Quote
Old 4th November 2012, 18:52   #3  |  Link
six13
NTSC model I have, but specs look the same.
http://www.samsung.com/ca/consumer/tv-video/blu-ray-players/blu-ray-players/BD-E5900/ZC
the Samusng manual says it WONT play DVD-ROM/PD/MV, etc
the Verbatim DVD+R DL is a mpeg2 movie made with DVD-RB and burnt with ImgBurn bitset to DVD-ROM. This same DVD DL playes fine in my DVD player but Blu ray doesn't accept it. The samsung will play my burnt DVD+R's or -R fine. I haven't tried and DVD+RW's yet.
Old 5th November 2012, 17:51   #4  |  Link
setarip_old
The following is from the link YOU have now provided - and it too indicates that your player CAN play burnable DVDs:
Playable Disc Type
3D Blu-Ray Playback Media available
Blu-ray Video
DVD-Video / DVD±R / DVD±RW Playback Media available
CD DA / CD-R / CD-RW Playback Media available
Old 6th November 2012, 01:12   #5  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Do you go into the Advanced Settings to play with the booktype in ImgBurn?
I've never done that before, all my devices are recent.
I've read that manually changing the booktype to DVD-ROM is help with compatibility on older devices.
Reset ImgBurn to default settings and create another disc without manually changing the booktype to DVD-ROM.
ImgBurn is able to tell if you want to burn a DVD movie disc and ask if you want to adjust settings if necessary.
The DVD+R DL should playback fine after that.
I've had no problems with +/- media on my BD machine before using just default settings and not playing with any advanced settings.
Have you tried updating the firmware to your BD machine?
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 6th November 2012, 01:40   #6  |  Link
six13
player is wireless and it did update when I set it up.
i don't use the advanced setting , I click on the little book then make the change. I have fould some Verbatim DVD-R that I burt won't play and others do. Seems to be real random.
@setarip_old
I know it says it will play the burnable DVD's but in reality it is quite random, some Verbatim -R's play others don't. All my Tayo +R's play and I bitset them all to DVD-ROM
Old 7th November 2012, 14:44   #7  |  Link
setarip_old
As I said before:
Chances are either your burner or player prefers DVD+Rs. Experiment with different brands of DVD+Rs...
Old 7th November 2012, 15:09   #8  |  Link
Ghitulescu
Ghitulescu's Avatar
No, Samsungs are the ones I said several times before they need to have the correct booktype. In that case not DVD-ROM but DVD+R DL.
Born in the USB (not USA)
Old 8th November 2012, 23:45   #9  |  Link
six13
@Ghitulescu
so when I put a Verbatim DVD+R DL in my burner I don't click on the book type icon, or I do click on the icon but select NORMAL rather than DVD-ROM.
My DVD burner is a ASUS and when i click on the book icon I don't see my brand. Previously I had a samsung burner which was one of the brands listed. Whct do I do since my brand isn't listed?
thanks
Old 9th November 2012, 00:09   #10  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Originally Posted by six13 View Post
@Ghitulescu
Try one disc without clicking on the book type icon.
Let it burn as DVD-Video (default if not setting booktype).
Old 18th November 2012, 21:31   #11  |  Link
bekar
Posts: n/a
Old 26th November 2012, 02:56   #12  |  Link
six13
still won't work
I made a Verbatim DVD+R DL disk as DVD-Video by not selecting the booktype icon. Bluray still won't read it, I guess all my DL's are trash unless I keep my DVD player hooked up to play them.
Old 26th November 2012, 04:38   #13  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Have you tried hooking your BD machine to the internet and finding out if there's an update?
How do you do the layerbreak? Seamless?
Do you get a notification about the chapters being in problematic places?
Sometimes you'll have to use something like PGCEdit to add a new chapter within valid sectors for it to be a fully compliant DL disc.
Old 29th November 2012, 22:14   #14  |  Link
six13
the blu ray has the latest updates as it is wireless and when I set it up it downloaded all the updates and I have gone back and asked it to check for updates. ImgBurn was giving me green stars so the layer break was OK, no errors or messages and I have never selected seamless layer break, I select what ImgBurn determines with the green stars. None of my DL DVD's will play, even some of my Verbatim DVD-R won't play soem some others will. I think I will go with DVD+R version fro DVD5 going forward.
