5th May 2023, 01:35 | #321 | Link | |
5th May 2023, 07:40 | #322 | Link |
Big Bit Savings Now !
BDInfo finds 00000.mpls pointing to 00000.m2ts containing IG.
BDEdit v0.56b7: 00000clpi -> contains BG in MPEG-2 + PID 1400 IG -> Menu Menu tab shows 6 BOGs 0000 is DEUTSCHLAND inactive 0001 is DEUTSCHLAND active 0002 is FRANCE inactive 0003 is FRANCE active 0004 is UK/AUS/NZ inactive 0005 is UK/AUS/NZ active
5th May 2023, 08:45 | #323 | Link |
Hello.
Yes, there are quite a few m2ts that contain IG. But they correspond to the pop-up menu and the initial country selection. There are also others that have nothing to do with the audio/subs selection. But there is none that corresponds to the main menu. Last edited by palestina; 5th May 2023 at 08:48. |
5th May 2023, 14:48 | #324 | Link |
If 00000 is not what you want:
00004..00040.m2ts contain all the different menu backgrounds in 3 languages for the pan/scan-zooming main menu selection 00043...00048.clpi is full of IGs for these menu BGs
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 5th May 2023 at 14:57. |
5th May 2023, 16:02 | #325 | Link |
Hi, yes Emulgator 00000.m2ts is multiplexed containing MPEG-2 + PID 1400 IG.
The main menu is divided into 3 languages: French, German and English. The problem is that the menus are movies that interact with button programming. Example 00040.m2ts movie: https://www.mediafire.com/file/c6yc3...0040.m2ts/file These are the BOGs with command buttons: Last edited by ocean; 5th May 2023 at 18:22. |
5th May 2023, 22:36 | #327 | Link |
Yep, its quite nifty. A good exercise.
28th May 2023, 06:15 | #328 | Link |
hi everyoane i have a problem with a JAR file...after i edit the JAR file (replacing the text with my languege)i try to fix it wit anydvd but anydvd is given this error and the movie is not starting! plese help !
8th September 2023, 02:02 | #334 | Link | |
Thanks! |
12th January 2024, 10:38 | #335 | Link |
HELOO! i have this problem with editing a menu whith png coordinates i dont undestand how to do it can anyoane help me! thnx
https://www.mediafire.com/file/ygz1u...p/JAR.rar/file |
13th February 2024, 20:54 | #338 | Link |
Hi!
I'm trying to modify my first menu, and after reading carefully the first post, I'm unable to determine which type of menu is the one I'm trying to modify first. It doesn't seem to belong to any of the types mentioned. Please help!! https://www.mediafire.com/folder/bwkf4pu4fx22h/JAR |
