9th August 2024, 16:00 | #20821 | Link |
The only issue I have found with an autocrop, and this only affects it when using SMdegrain (never an issue with just Mdegrain) is that occasionally the autocrop will come up with an aspect ratio that is just a bit off of a standard aspect ratio and when it goes to actually start the encode there will be an error saying something like info.txt could not be found. In this case usually just adjusting the aspect ratio by removing a few bits on top and bottom (or left and right) will clear that up. Over the last couple of years I have had maybe a half dozen encodes that whatever I did SMdegrain just would not work. In those few cases, i just ran them using regular old Mdegrain and called it a day.
In fact Strange New worlds is like this. When I do an autocrop, it detects 278 lines on the top and bottom and shows an aspect ratio of 2.394:1. This will fail the encode. I add 2 lines to the top and bottom, so it is 280 on both using the up arrows, and it will run just fine with SMdegrain. I know in the past it looks like if it comes up as 2.391 or 2.4 it is always good, but 2.394 might fail "sometimes". Just one of the quirks of using SMdegrain.... It happens too infrequently to be bothered by it Last edited by rlev11; 9th August 2024 at 16:08. |
9th August 2024, 17:42 | #20822 | Link |
I updated server 2 with Ripbot to the latest firmware. The same thing happened once again with Plex but I've encoded 5ish movies since and it hasn't done that again. Plex is showing Direct Play on the server end no matter what, technically nothing should be transcoding and I'm not out of HDD space. Only thing I can think of, just a random issue with Ripbot...I don't know.
9th August 2024, 18:21 | #20823 | Link | |
Lots of results on that space error on google for plex. Most results center around setting your transcoding directory in the settings menu. Are all the ones failing have subtitles? There was/is a bug in plex that caused this error due to having to transcode the subtitles for proper viewing |
14th August 2024, 01:14 | #20825 | Link | |
Friend of a friend..
However, you can demux those with tsmuxer to extract the mvp track, and then run the "normal" track thru RB if you need to do some filtering (but not much), then mux everything back together again with tsmuxer to create the 3D in .m2ts. And have to be encoded with x264 !!!
RipBot264 v1.27.3 (08-06-24) Last edited by FTLOY; 14th August 2024 at 15:39. |
14th August 2024, 14:45 | #20826 | Link |
MVC (Multi-View Coding) requires support for two parallel video streams. Right now x265 is being tested to support it, but that broke ffmpeg integration for now, and there are crashes in different circumstances.
15th August 2024, 12:06 | #20827 | Link | |
Also a complicated procedure to make the 9950X behave properly. So, I guess we'll have to wait another couple of years to the next generation, 10950X, or whatever. OR, "risk" a 14th Gen Intel, but maybe a recent microcode may "fix" that issue. OR, blow the budget completely, and go for a TR. (a 7960X would be good enough)
RipBot264 v1.27.3 (08-06-24) |
15th August 2024, 12:18 | #20828 | Link |
I think it is safe to say that this threading issues is most likely caused by avisynth code. Something wrong with caching? Too small memory allocation?
15th August 2024, 12:24 | #20829 | Link | |
What about Vapoursynth ??
15th August 2024, 12:29 | #20830 | Link |
Regarding number of prefetch threads which has to be reduced for 4k content to 12.
15th August 2024, 15:43 | #20831 | Link | |
Will they take the same time to complete ???
15th August 2024, 23:31 | #20832 | Link | |
With my 7950x So it looks like single mode uses the setting "use multiple processing threads" in the main settings window. Running GOT with Mdegrain3-200 in single mode with that set to it's default of 0 which I would take as All. After a couple minutes that settled into about 2.5 fps. If I change that setting from 0 to 12, bumped that up to 6fps after a couple minutes. The fact that it scales up where it should be when no avisynth filters are being thrown at it, I agree it is definitely something coming from Avisynth code with some buffer being overloaded especially with full frame 16x9 4k. If you are just doing a x265 encode everything runs as expected speed wise in comparison |
16th August 2024, 02:02 | #20833 | Link | |
It would be interesting to test a basic file with StaxRip, using similar filters, with Avisynth & Vapoursynth. Unfortunately, AFAIK, Atak hasn't got access to a high core count system, so he can't check the problems we have
16th August 2024, 05:49 | #20834 | Link |
Pig on the wing
In any multithreading related issues, I'd start the analysis by restricting the amount of prefetched frames. With 4K sources, the frame sizes are getting so big that the default 2*threads can easily cause Avisynth cache trashing if you have not raised the size of the cache. The Avisynth default cache amount has not been changed in a long time, and it's very low.
I have these on top of my mtmodes.avsi to make sure there's enough cache memory for all situations (I have 64GB of RAM). Also mode 1 works better on my use cases. SetMemoryMax(32000) SetCacheMode(1)
16th August 2024, 06:07 | #20835 | Link | |
I have had these settings in my scripts, but now that I also have 64Gb, I might up it to what you've suggested Code:
SetCacheMode() SetMemoryMax(20480)
16th August 2024, 06:12 | #20836 | Link |
Pig on the wing
It really doesn't matter, the highest amount of memory consumed has been around 23-24 gigabytes. Avisynth+ only uses the memory it needs for caching (based on what and how the plugins themselves request cache). It's good to take a look at Task Manager and see the memory consumption of the corresponding processes.
For Prefetch, I've used Prefetch(threads=32, frames=12) on my 5950X. Usually there's not much difference between frames 4-12.
16th August 2024, 06:35 | #20837 | Link | |
But there are options to customise certain settings, but when using the Distributed Encoding function you can customise each encoding server like so:- Code:
Server1CommandLine=/port 1000 /priority normal /restart-if-no-progress /avisynth-prefetch-threads 12 /x264-threads 32 /x265-threads 32 With x264 & x265 threads, not sure if those numbers make any significant difference.
16th August 2024, 06:42 | #20838 | Link |
Pig on the wing
What you would need to do is somehow restrict the amount of prefetched frames. With threads 12, Avisynth is prefetching 24 frames which is probably far from optimal and will consume a lot of memory.
16th August 2024, 06:52 | #20839 | Link | |
This is the only reference in the avs script to prefetch:- Code:
#MT #PREFETCH_LIMIT=12
RipBot264 v1.27.3 (08-06-24) Last edited by FTLOY; 16th August 2024 at 06:56. |
16th August 2024, 20:45 | #20840 | Link |
Just not sure where to set frames into the ripbot script or the proper syntax to use in the job script. Don't see a "/avisynth-prefetch-frames" setting in the help for the encoding server command line like threads. If it actually the frames and not threads that's killing it, once we figure out where and how to set the frames, we could set threads to 16 (or total physical cores), and just play with the threads to see where things go south and see if that same number works across different platforms. It may just end up that 1 proper frames count may be optimized for BOTH 4k and 1080p which would be perfect, or at the minimum very little difference between them. Set the frames once and be done with it.
Ideal test would be to set threads to logical cpu's, then find happy frame count doing a full frame 4k. The run 1080p and start increasing the frames and see if there is any appreciable performance gain. A buffer size increase might work as well, but could cause issues using distributed if you have servers with varying memory sizes. I would think the buffer size would get sent out to all the servers and if you have one with say 16gig instead of a setting optimized for 32 or 64, things could go crazy real fast. Just a quick initial test, On my 1080p test with Mdegrain3-200, I set avisynth prefetch threads to 32 on my 7950x, so 64 prefetch frames, and I saw about a 9% speed increase just on that alone. Last edited by rlev11; 16th August 2024 at 22:16. Reason: add quick test |
