Old 16th September 2018, 22:21   #21  |  Link
zorr
VDub has a much bigger overhead so that's to be expected.
Yes I was expecting that too. But data is always better than expectations.
No, I don't mind.
Cool, I will add it in the next version.
Where do you want to determine this? In the batch file? In your software?
In my software so that I could select automatically which version of avsr is going to end up in the runavs.bat. Otherwise user has to go and edit the runpath in the optimizer.ini.
An alternative would be to make a little setup program where the user could select the correct version from the two alternatives and .ini would be created based on that.
zorr is online now   Reply With Quote
Old 17th September 2018, 08:49   #22  |  Link
Groucho2004
Originally Posted by zorr View Post
It would be nice if I could determine automatically which Avisynth platform (x86 or x64) the user is running, then I could skip one manual step of the installation.
You also have to consider that a user can have both 32 and 64 bit Avisynth installed. So, the choice whether to test this with 32 or 64 bit Avisynth is up to the user.
Groucho's Avisynth Stuff
Old 17th September 2018, 21:33   #23  |  Link
zorr
That's a good point. I'm thinking the .ini defines the default but it can be overridden with a command line argument.
I also want to ask your opinion on the .bat files. It's not necessary to have them (batch can be run even without a file) but I thought it would make hacking the optimizer a bit easier (you can change what you want to run the scripts with). Removing them would make sense now that avsr does the job very well and is included. But should I still leave them in order to let others decide the script runner?
Old 17th September 2018, 22:02   #24  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
How about an argument in the script that tells it whether to use x64 or x86?
Some scripts might always require one or the other.
wonkey_monkey is online now   Reply With Quote
Old 17th September 2018, 22:27   #25  |  Link
zorr
That's a good point too. So it would go like this:
Use the platform defined in the .ini
EXCEPT if the platform is defined in the script, then use that instead
EXCEPT if the platform has been given as a command line argument, then use that
Old 18th September 2018, 08:05   #26  |  Link
And what if no ini file (or script or command arg, use native-ness).
Old 20th September 2018, 22:52   #27  |  Link
zorr
Great idea, except that I have no idea how to find "native-ness".
Besides whatever automatic method I can come up with it's still going to go wrong when people have both platforms installed. So I think I'm just going to ask the platform the first time the optimizer is run.
Old 21st September 2018, 00:07   #28  |  Link
Groucho2004
Can you elaborate on "ask the platform"? I'm not sure what you mean by that.
Old 21st September 2018, 09:54   #29  |  Link
wonkey_monkey
Ask the user what platform to use.
Old 21st September 2018, 10:05   #30  |  Link
Groucho2004
When I hear/read "platform" I naturally associate OS platform. In this context it's obviously about the "Avisynth platform" which sounds a bit odd but that's probably just me.
Old 21st September 2018, 22:36   #31  |  Link
zorr
Yes the idea is to ask the user which "Avisynth platform" should be the default. I'm open to suggestions on what to call that, I'm not native english speaker. Perhaps "version" would flow better but then again people might confuse that with version numbers. Architecture?
Perhaps I should present the question as "Are you using (mostly) 32bit or 64bit Avisynth?". But I still need a good name for the argument, right now it's -platform.
Old 22nd September 2018, 09:01   #32  |  Link
Boulder
Pig on the wing
Boulder's Avatar
This is an interesting concept, it could be quite useful in testing parameters for downscaling 4K to 1080p or 1080p to 720p (based on the fact that they will be upscaled to 4K upon playback). So, any chance this could be made Vapoursynth-compatible as well?
Old 22nd September 2018, 14:09   #33  |  Link
ChaosKing
It would be nice if the download links could be on the first page.
I think adapting it to VS could be achieved with the SSIM() function from muvsfunc. https://github.com/WolframRhodium/mu...sfunc.py#L3371
But I don't know for what the avstimer.dll is good for...
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 22nd September 2018, 17:40   #34  |  Link
Groucho2004
First you should determine which Avisynth versions are installed.
If only 32 bit Avisynth is installed, run the 32 bit process, if only 64 bit Avisynth is installed, run the 64 bit process.
If both are installed, ask the user something like "With which Avisynth version do you want to run the test?" and then present the two choices.
Old 22nd September 2018, 23:07   #35  |  Link
zorr
That certainly could be done. The only difficulty in this would be that Avisynth would have to simulate the upscaling of the playback device (or is it upscaled with Avisynth during the playback?).
I haven't looked at Vapoursynth so I can't tell for sure. But basically what's needed for the optimizer to work is:
1) a way to run a script programmatically from the optimizer
2) a way to specify which values the optimizer is changing in the script
3) the script has to calculate a result: quality / runtime / any other interesting value
4) the script has to write the result into a specific file
I'm very much interested in making this happen but hopefully someone who knows Vapoursynth can help me figure out the steps above.
Old 22nd September 2018, 23:13   #36  |  Link
zorr
Thanks for the suggestion, I added the download links there.
SSIM or any other means to measure quality will work.
AvsTimer is for measuring the runtime of the script. It's not absolutely necessary if you don't care how fast or slow the script is.
Old 22nd September 2018, 23:26   #37  |  Link
zorr
Is there an easy way to do that? I guess I could scan the registry for installed software. Can I determine the platform from the software's name?
[EDIT]
32bit Avisynth can be found at
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AviSynth
when installed on a 64bit system.
Is the 64bit version at
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Avisynth
What about if Windows is 32bit? I guess there can only be 32bit Avisynth but it will be at the same spot in the registry as 64bit Avisynth on a 64bit Windows.
Old 22nd September 2018, 23:31   #38  |  Link
wonkey_monkey
"Architecture" may be a better word than platform.
Old 23rd September 2018, 00:32   #39  |  Link
Groucho2004
Checking the registry is probably the best way. Here are the keys:
32 bit AVS on 32 bit Windows:
HKEY_LOCAL_MACHINE\SOFTWARE\Avisynth]
@="<avisynth install path>"
32 bit AVS on 64 bit Windows:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Avisynth]
64 bit AVS on 64 bit Windows:
[HKEY_LOCAL_MACHINE\SOFTWARE\Avisynth]
Old 23rd September 2018, 00:54   #40  |  Link
q) Is the registry always automatically cleared, upon uninstall ? (I doubt it)
