Old 1st September 2009, 15:47   #4541  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
VB ? huh, no thanks...
Old 1st September 2009, 15:57   #4542  |  Link
stax76
stax76's Avatar
http://codeconverter.sharpdevelop.ne...Converter.aspx
Old 1st September 2009, 16:09   #4543  |  Link
Kurtnoise
Kurtnoise's Avatar
Thanks...anyway, I think to switch to WPF asap to have a better UI.
Old 1st September 2009, 16:41   #4544  |  Link
stax76
stax76's Avatar
Are you sure you want to convert a complex form like your x264 form or mix WPF and WinForms in the same application? I've done some mixing too but only a small piece. I had a WinForms custom control with 350 lines code and replaced it with a WPF version achieving the same thing with only 50 lines code so I have smaller code and a little fun learning WPF. I'm looking forward to use WPF in the player I'm building.
Old 1st September 2009, 17:50   #4545  |  Link
Kurtnoise
Kurtnoise's Avatar
Honestly I don't know...I've some random ideas but I'm not sure that it's doable or not. If I jump to WPF and succeed, x264 form will change probably...In fact, all forms must be changed.
Old 1st September 2009, 22:28   #4546  |  Link
Theliel
żBug in 0.3.1.1055?
CABAC toggle dont work?
Theliel is offline   Reply With Quote
Old 2nd September 2009, 00:29   #4547  |  Link
Kurtnoise
Kurtnoise's Avatar
fixed...redownload or force to reinstall it.
Old 2nd September 2009, 19:27   #4548  |  Link
hajj_3
got a bug with latest megui, i get the following when closing megui after i manually replaced x264.exe v1235 32bit with x264.exe v1146 32bit:
also in "update" it shows the version as v1135 still instead of reading the x264.exe to see what build it is. Hopefully you can fix these 2 bugs shortly, many thanks
Old 2nd September 2009, 20:28   #4549  |  Link
stax76
stax76's Avatar
It's bad practice to show a stack trace to the user, it's bad practice to save to a system directory and it's bad practice to require elevated privileges in order to be able doing so.
Old 2nd September 2009, 20:31   #4550  |  Link
Kurtnoise
Kurtnoise's Avatar
this is not the right place to report this...
which is ?
what ? no, nothing is parsed to retrieve the version #.
Old 2nd September 2009, 20:37   #4551  |  Link
hajj_3
0.3.1.1055 is the version of megui i am using.
as you can see in the above screenshot it says that i have x264 v1135 installed but i actually have v1146 as i manually over-wrote the x264.exe in program files\megui\tools\x264. It should report the actual version i'm using.
Old 2nd September 2009, 20:46   #4552  |  Link
Kurtnoise
Kurtnoise's Avatar
this version # is read from the upgrade.xml on the server...whatever you do.
Old 4th September 2009, 06:32   #4553  |  Link
rtjnyoface
Constantly learning
rtjnyoface's Avatar
@kurtnoise
Post 4537
I like the first pic.
rtjnyoface is offline   Reply With Quote
Old 4th September 2009, 23:11   #4554  |  Link
morphinapg
ASXGui Developer
morphinapg's Avatar
Originally Posted by Kurtnoise View Post
Why use textboxes instead of labels?
ASXGui 2.5 / Installer
Thread / All Downloads
morphinapg is offline   Reply With Quote
Old 5th September 2009, 03:02   #4555  |  Link
stax76
stax76's Avatar
Because labels don't have a border unless you draw one or apply a style using pinvoke.
Old 5th September 2009, 23:09   #4556  |  Link
morphinapg
ASXGui Developer
morphinapg's Avatar
label.BorderStyle = BorderStyle.FixedSingle;
That's what I use in ASXGui
Old 6th September 2009, 00:01   #4557  |  Link
stax76
stax76's Avatar
I didn't notice it's that simple, last time I only saw and tested the FlatStyle property and didn't notice the BorderStyle property. Sometime the easiest things are hard to see.
Old 21st December 2009, 09:59   #4558  |  Link
Octo-puss
Is MeGUI dead? Just curious.
Octo-puss is offline   Reply With Quote
Old 21st December 2009, 10:06   #4559  |  Link
RyaNJ
RyanJ
Look here for a temporary thread until MeGUI is maintained fully again.
RyaNJ is offline   Reply With Quote
Old 21st December 2009, 10:08   #4560  |  Link
Octo-puss
What happened btw? I haven't been here for 3 months or something.
development, megui, not a help thread
