Old 18th April 2009, 09:07   #4361  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally Posted by UsedUser View Post
Also, I put the patch in pastebin for ease of access.
update your svn tree & remove trailing white space...
Old 18th April 2009, 14:00   #4362  |  Link
Kurtnoise
Kurtnoise's Avatar
@Sharktooth: New Aften presets to be in synced w/ rev 1154...
Old 21st April 2009, 02:45   #4363  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
    - (kurtnoise) [AaudioEncoderInterface] reflect the last changes for SamplingRate values in the script.
    - (kurtnoise) [AudioConfigurationPanel] add new SamplingRate values (8000Hz - 11025 Hz - 22050 Hz)
    - (kurtnoise) update MediaInfo library and its wrapper to the latest release (0.7.14)
    - (kurtnoise) [VideoUtil] add some tunings regarding audio Type for getSourceMediaInfo().
    - (kurtnoise) [DialogSettings] remove unused code.
    - (kurtnoise) [DialogManager] remove unused code.
    - (kurtnoise) [AVSCreator] apply runCUVIDServer() to the dga/dgm/dgv cases.
    - (kurtnoise) [DialogManager] add runCUVIDServer() function.
    - (kurtnoise) [AVSCreator] cosmetic.
    - (kurtnoise) [AVSCreator] gotoD2vCreator() - rewrite error message because TS files can contain AVC streams...
    - (kurtnoise) [AVSCreator] better avs script support for input file.
    - (kurtnoise) [HDStreamExtractor] add a checkbox to close the form after extraction.
Old 21st April 2009, 16:49   #4364  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
Originally Posted by Sharktooth View Post
have you some time to update the wiki? or, if you like, time to learn c#?
I can help with the former, I'll try to do some work over an upcoming weekend. The latter, sorry but no can do
check is offline   Reply With Quote
Old 26th April 2009, 08:15   #4365  |  Link
UsedUser
Updated patch on pastebin for the latest rev in svn, though no changes in this code.
Not sure what white space you are seeing... I see only <CR><LF> at the end of each line.
UsedUser is offline   Reply With Quote
Old 26th April 2009, 09:11   #4366  |  Link
UsedUser
[dgmcreator] DGM Indexer GUI patch
Patch in pastebin to remove redundant controls.
There appears to be a redundant set of controls in the DGM Indexer that overlay the actual controls used for the audio demux settings.
The following controls take user input as they are topmost in the GUI, but are not checked for their settings:
groupBox1
listBox1
radioButton1
radioButton2
The following controls do not take user input (they are concealed by the other controls) but are checked for their settings when creating the processing job:
groupBox3
AudioTracks
demuxAll
demuxNoAudiotracks
Old 26th April 2009, 10:28   #4367  |  Link
Kurtnoise
Kurtnoise's Avatar
I'll commit your patches tomorrow.
edit: done...
Old 27th April 2009, 15:45   #4368  |  Link
Kurtnoise
Kurtnoise's Avatar
@Sharktooth: could you update the dgavcindex package ? libavcodec.dll is missing...
Old 29th April 2009, 11:12   #4369  |  Link
Kurtnoise
Kurtnoise's Avatar
- (kurtnoise) [CodecManager] disable BD & AVCHD devices type. Not yet functional...
- (kurtnoise) [MainForm] register tsmuxer as JobProcessor & MuxerProvider.
- (kurtnoise) [MuxProvider] add tsmuxer.
- (kurtnoise) add tsMuxeR class.
- (kurtnoise) add tsmuxer in the project files.
- (kurtnoise) [SettingsForm] add tsmuxer components in the Muxer tab.
- (kurtnoise) [MeGUISettings] add TSMuxerPath
- (kurtnoise) [CodecManager] add M2TS as VideoType & ContainerType
- (kurtnoise) [MediaInfoFile] when VCodec is null, check the video format in this case.
- (kurtnoise) [JobUtil] use output name to create logfile instead of input. #2690832
- (kurtnoise) [FileSize] rounding values with 2 digits instead of 1. Feature Requests #2772018 & #2465440
- (kurtnoise) add Device Output Type to the One-Click Encoder. Available through Advanced Settings.
- (kurtnoise) [PrettyFormatting] fix an error with temporal substring...Note to myself : test external patches before to commit them like a dumb.
- (kurtnoise) [AutoEncodeTool] add Device Output Type.
- (kurtnoise) update the One Click & AutoEncode tools to the latest changes.
- (kurtnoise) [MP4BoxMuxer] apply device type to the command line.
- (kurtnoise) add Device Types to the Adaptive & Manual Muxers. Now, we can force either iPod, iPhone, ISMA or PSP output when we select MP4 Muxer.
- (kurtnoise) [VideoUtil] update GenerateJobSeries()
- (kurtnoise) [JobUtil] update GenerateMuxJobs()
- (kurtnoise) [IMuxing] add new List<DeviceType> & GetDeviceInputFilter() string.
- (kurtnoise) [MuxSettings] update settings with the DeviceType.
- (kurtnoise) [MuxProvider] add GetSupportedDevices(), GetSupportedDeviceTypes() & register the new device types.
- (kurtnoise) [CodecManager] add DeviceType as OutputType.
- (kurtnoise) [MainForm] move MeGUI size/position/windowstate settings in Shown Event instead of Load Event.
- (kurtnoise) [MainForm] add MeGUI size/position/windowstate settings in Load Event.
- (kurtnoise) [MuxProvider] add h264 file extension to the MKV & MP4 Muxers.
- (kurtnoise) [CodecManager] change EAC3 files extension & add a new AVC files extension.
- (kurtnoise) [AVSCreator] fix issue #2776469.
- (kurtnoise) [MkvMergeMuxer] add Warning handling to ProcessLine().
- (kurtnoise) [MkvMergeMuxer] better Error Handling in ProcessLine().
- (kurtnoise) [MkvMergeMuxer] update ProcessLine() to match the correct string.
- (kurtnoise) [DGMCreator] remove duplicate components. Patch by UsedUser from http://forum.doom9.org/showthread.php?p=1278274#post1278274
- (kurtnoise) [PrettyFormatting] simplify ExtractWorkingName(). Patch by UsedUser from http://forum.doom9.org/showthread.php?p=1278251#post1278251
- (kurtnoise) [Vobsubber] use getPGCnb() to retrieve max value.
- (kurtnoise) [IFOparser] add getPGCnb() function.
https://sourceforge.net/project/platformdownload.php?group_id=156112
Old 29th April 2009, 13:45   #4370  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
@Kurtnoise: i dont know how did you compile .1033... (MeGUI.core.util.IFOparser' does not contain a definition for 'getSubtitlesLanguage' G:\usr\projects\megui\megui\trunk\core\util\VideoUtil.cs 311 67 MeGUI)
maybe you missed to commit an updated IFOparser.cs file...
Old 29th April 2009, 14:15   #4371  |  Link
Kurtnoise
Kurtnoise's Avatar
sorry...should be better now w/ the last revision.
Old 30th April 2009, 13:12   #4372  |  Link
Buggle
Posts: n/a
Hi guys,
Thank you for a great program! I hope this is the right place to write this, but I was hoping you could implement an extra option to the 'after completion, do this or that':
I often use the automatic shutdown option to let it close automatically when I am away from home.
However, I just keep forgetting to turn it back off, so that the next time I for instance do a little muxing while playing music and going about doing other things (like the dishes), the computer suddenly shuts down. This has happened multiple times, also during important or time consuming businesses like writing reports (thank god I'm an Ctrl-S junky) or doing subs OCR (which doesn't auto save).
For this reason it would be great to have a choice if the shutdown option should be for 'always', where the setting is remembered, or for 'only this instance', where the next time you start MeGUI, the automatic shutdown is not selected anymore. This could be implemented in the settings, where the option is now, or in the progress window to illustrate it is only for this session. Your preference is of course to be chosen.
Old 30th April 2009, 14:06   #4373  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
please post feature requests here: http://sourceforge.net/tracker/?atid...12&func=browse
Old 5th May 2009, 15:50   #4374  |  Link
Kurtnoise
Kurtnoise's Avatar
Originally Posted by Romario View Post
I would try newest MeGUI build in Windows 7 build 7048 32-bit, and you can, guys, expect some notices from me. If it's work on Windows 7 pre-RC, of course.
w/ build 7100...no problem so far.
Old 5th May 2009, 16:19   #4375  |  Link
Dark Eiri
I can confirm that there's no issues at all with Windows 7 RC (7100). Have been using MeGUI on it for five days, quite a lot, and it works fine.
Dark Eiri is offline   Reply With Quote
Old 7th May 2009, 16:29   #4376  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
    - (ateeq) Add Job Control option to change after encoding setting for current session (2777417 & 2784396)
    - (kurtnoise) [baseMuxWindow] change output_FileSelected() to output_Click() event (#2786990)
    - (kurtnoise) [x264ConfigurationPanel] fix few issues with the quantizer value when qp < 1.
    - (kurtnoise) [DialogManager] fix DGVC1IndexNV path (#2784428)
    - (kurtnoise) [UpdateWindow] add tsmuxer case.
    - (kurtnoise) [TargetSizeSCBox] add BD FileSize Presets.
    - (kurtnoise) update MediaInfo library and its wrapper to the latest release (0.7.15)
    - (ateeq) [JobQueue] Up/Down buttons enabled = false to avoid crash on empty queue/selection
    - (kurtnoise) [VideoUtil] remove unused code...
    - (kurtnoise) add some enhancements to the nsis script.
Old 7th May 2009, 18:56   #4377  |  Link
b66pak
b66pak's Avatar
thanks...
_
Old 8th May 2009, 17:23   #4378  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Why you put tsmuxer 1.8.4 when there is 1.10.1 as lastest and its more stable than 1.8.4
shon3i is offline   Reply With Quote
Old 9th May 2009, 04:08   #4379  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
coz i downloaded it from the main post (which points to 1.8.4(b) as the latest version).
if you can kindly provide me a link for the latest one, ill update it tomorrow.
Old 9th May 2009, 04:31   #4380  |  Link
Inspector.Gadget
http://www.smlabs.net/tsMuxer/tsMuxeR_1.10.1(b).zip
As always with the smlabs site, better use a download manager
Inspector.Gadget is offline   Reply With Quote
development, megui, not a help thread
