Old 30th July 2013, 21:34   #1701  |  Link
Selur
Selur's Avatar
If I understand well, the culprits are --bluray-compat and --slices 4 and not --b-pyramid strict, --lookahead-threads 1 and --mvrange 511 ?
don't know for sure unless you try but I suspect the '--slices 4' is the problem. (lookahead-threads is definitely not the problem)
Old 30th July 2013, 21:39   #1702  |  Link
Music Fan
And --slices 4 is mandatory if --bluray-compat is there so I guess I coudn't have --bluray-compat without --slices 4.
I hope the BDP-83 can play also in AVCHD and not only in MKV the files encoded without --slices 4, otherwise it would mean that an encoding can't be used for both purposes.
Music Fan is offline   Reply With Quote
Old 30th July 2013, 21:41   #1703  |  Link
Selur
Selur's Avatar
you can, re-read my last few posts.
Old 30th July 2013, 22:33   #1704  |  Link
Music Fan
Ok, but I believed level 4.0 would also remove --bluray-compat. If this is not the case, --bluray-compat without --slices 4 isn't very useful, is it ?
Old 30th July 2013, 22:39   #1705  |  Link
Selur
Selur's Avatar
Using slices normally should lower the quality, so disabling sliced encoding normally is recommend.
-> Blu-ray compatibility without slices should be better than with slices.
Old 30th July 2013, 23:20   #1706  |  Link
Music Fan
Ok, I guess you mean the quality would be better, not the compatibility.
But I'm a little bit confused because you said earlier that "sliced encoding is needed for Blu-ray compatibility" and now you seem to say that removing --slices 4 is not really a problem.
How can it still be Blu-ray compliant without slices ?
Old 30th July 2013, 23:24   #1707  |  Link
Selur
Selur's Avatar
like I wrote: " sliced encoding is only mandatory for level 4.1 and not level 4.0."
so if you still with level 4.0 the encode still is inside the specification, so there should be no problem with compatibility.
Have you tried if '--slice 4' really is the problem?
Old 30th July 2013, 23:33   #1708  |  Link
Music Fan
Ok, I believed Blu-ray had to be in 4.1.
I'm gonna do that.
Old 30th July 2013, 23:35   #1709  |  Link
Selur
Selur's Avatar
Nope, everything Hybrid allows you to do while Hardware->Blu-ray compatibility is enabled should be standard conform.
Old 30th July 2013, 23:54   #1710  |  Link
Music Fan
Tried, you were right ; MKV don't pixelate in level 4.0 with --bluray-compat and without slices
Still have to try this encoding in an AVCHD structure but I guess it will work.
Thus I don't understand very well the utility of level 4.1 for Blu-ray.
Old 30th July 2013, 23:59   #1711  |  Link
Selur
Selur's Avatar
higher levels allow higher vbv values which potentially means more references&co, but since you are probably encoding to lower the data rate to begin with, I doubt it is a problem.
going to bed now
n8
Old 31st July 2013, 00:02   #1712  |  Link
Music Fan
Ok, bye, thanks for help.
I already wish you good luck for the next step : the support of H265 (HEVC)
Old 31st July 2013, 05:36   #1713  |  Link
Selur
Selur's Avatar
x265 is cq only and does only support direct file input (no pipe) atm. so not really interesting. (+ reading the requirements it needs a avx capable cpu, which my current machine doesn't support)
Other then that there are no free cli H.265 encoders out there, so I'm in no hurry in implementing that.
atm. I'm more looking into supporting avisynth through wine on linux and mac, but I'm struggling with it (a. don't have a preview with sound atm. for general preview avsViewer works okay; b. no clue how to set up wine easily on Mac OS X in a way that it is usable through the cli).
Cu Selur
Old 31st July 2013, 11:41   #1714  |  Link
Music Fan
Ok, there will be perhaps a x265 encoder someday.
What means cq and pipe ?
Old 31st July 2013, 11:43   #1715  |  Link
Selur
Selur's Avatar
cq = constant quantizer
pipe = accepting input via standard input (see: http://en.wikipedia.org/wiki/Pipeline_%28Unix%29)
Old 31st July 2013, 12:13   #1716  |  Link
Music Fan
Ok, I don't understand much about that stuff but it does not matter.
Old 31st July 2013, 12:19   #1717  |  Link
Selur
Selur's Avatar
with only cq: you can't specify a bit rate or file size
without pipe: you can't feed the encoder without creating temporal files (or may be created named pipes under Windows, which I never got working properly)
-> will add support to x265 once it gets more mature
Old 31st July 2013, 12:26   #1718  |  Link
Music Fan
Not cool, astonishing for a so "advanced" codec.
By temporal files you mean for example a picture decoded by a frameserver like avisynth which couldn't be used with h265 ?
Old 31st July 2013, 12:28   #1719  |  Link
Selur
Selur's Avatar
Yes, atm. you can't feed x265 with avs2yuv/mencoder/ffmpeg or similar tools which decode stuff and output the decoded content to the standard output.
Old 31st July 2013, 12:44   #1720  |  Link
Music Fan
Amazing, this makes 2 huge limitations for a tool supposed to be more mature than h264. I guess it's not definitive.
