Old 12th January 2024, 19:09   #3761  |  Link
Selur
Selur's Avatar
2024.01.12.1:
*fixed*
  • Vapoursynth: Letterbox not working
  • Synth: TIVTC frame rate/count calculation
  • Vapoursynth: sRestore default 25fps when frate not set
  • Vapoursynth: merge&masked filtering at the same time
  • Analyse: dts-hd detection
  • Torch: remove DDColor when not installed.
  • Audio: update audioQueue
  • Vapoursynth: frame props checks
  • Video: do not use file cache while during job processing svt-av1 progress
  • Jobs: delaycut on reencode needs output name update to avvoid confllicts
  • Vapoursynth: QTGMCFilter useEZDenoise UI
*changed*
  • Tags: 'und' language handling
  • Torch: RIFE v4.14 support
  • Audio: do not add 'downsampleTrueHDtoAC3' when input is an .mkv file
  • Container: mkv header compression handling</li>
  • Torch: support other network types than ESRGAN by name in VSGAN
  • Audio: add option to set 'default=true' in AudioQueue
  • Container: mp4 subtitle tagging; set empty title to empty string
  • Video: adjusted svtav1 defaults
  • Container: add warning for avi and interlace; stream vs container tag mismatch due to ffmpeg
*added*
  • Vapoursynth: vsTDecimateFilter
  • Automation: 'und' language handling
-> downloads: http://www.selur.de/downloads
Cu Selur
Old 19th February 2024, 14:23   #3762  |  Link
weaker
Titan V not recognized
Hi Selur,
thank you for Hybrid!
Upon startup, Hybrid 2024.01.12.1 tells me "No card found that's supported by nvenc, the CUDA encoding library. -> Removing CUDA based encoding support. Card name was compared against: https://developer.nvidia.com/cuda-gpus"
However, the Titan V card I use is listed on the given nVidia-Website (with compute capabilities v7.0). On my PC the nvidia-smi tool also lists CUDA version 12.3 installed, driver 546.33 and I definitely used CUDA-acceleration (and nvenc) in the past.
Probably just a bug
Best,
weaker
weaker is offline   Reply With Quote
Old 19th February 2024, 16:55   #3763  |  Link
Selur
Selur's Avatar
2024.02.19.1:
*fixed*
  • Avisynth: YUY2 -> YUV422PX for high bit depth input
  • Vapoursynth: FillDrops ui fix
  • Vapoursynth: DotKill interlaced handling
  • Vapoursynth: fix crop&letterbox preview for 422 content
  • Video: x264 crash with 'always create stats file'
  • ui: svt-av1: wrong ui element spinbox vs combobox
  • synth: fixed bug in CustomSynthScriptLoader
  • Vapoursynth: QTGMC-DeNoise with FilterQueue
  • Vapoursynth: FilterQueue and YAHR and FineDeHalo
  • Vapoursynth: vsChromaNR Distance setting
  • Vapoursynth: TemporalDeGrain2 loading fftw (Linux)
  • Avisynth: (32bit) Spline100&Spline144
*changed*
  • synth: cropPreview handling
  • filtering: Deinterlacer none => force scan type overwrite to 'progressive'
  • ffmpeg: don't use zscale to set matrix
  • Vapoursynth: adjust, so that progressive 4:2:2 does allow uneven resolutions
  • Vapoursynth: added LevelsLumaRangeSignaling to vsSmooth and vsLimiter
  • mux: MP4Box can handle eac3 nowadays -> not forcing ffmpeg for muxing
  • linux: ~/.config/hybrid as folder-path to search for misc.ini
  • Vapoursynth: disabled anything related to KNLMeansCL and vs-placebo (i.e. GLSL) (Linux)
*added*
  • torch: CodeFormer supports background resize
  • mux: always set mkv ColorSignaling option
  • subtitle: 'cut by chapter/time'-option *experimental*
  • Video: svt-av1 custom addition
Cu Selur
Ps.: @weaker: I need to know the exact name Hybrid names in it's log file to add your card to the list. (Hybrid is probably expecting 'GeForce GTX TITAN V', which was how it was reported a while back,..)
Old 19th February 2024, 18:58   #3764  |  Link
Selur
Selur's Avatar
2024.02.19.2:
*fixed*
  • Ui: double initialization of vsUseGLSLCAS
*changed*
  • Vapoursynth: enable KNLMeansCL related filters again (Linux)
  • Vapoursynth: search GLSL folder in filter path
Cu Selur
Old 21st February 2024, 16:24   #3765  |  Link
Selur
Selur's Avatar
2024.02.21.1:
*fixed*
  • ffmpeg: missing whitespace before '-color_primaries'
  • tool: Linux package using wrong fdkaac source
Cu Selur
Old 22nd February 2024, 00:31   #3766  |  Link
locotus
Using Hybrid last couple of versions:
Adding delay to audio or subtitles after conversion is over, Mkvtoolnix reported this problem and do not mux the file:
Color range parameters: not given in the form <TID>:n (argument was '0:18446744073709551615').
File seems to be Ok, can be muxed with other tools.
locotus is offline   Reply With Quote
Old 22nd February 2024, 04:51   #3767  |  Link
Selur
Selur's Avatar
@locotus: without a debug output, it's hard to know who to reproduce, I fixed another bug with mkv muxing, which might also help with yout problem if not, please share proper details ( see: https://www.selur.de/support), so I can reproduce and fix the problem.
@all:
2024.02.22.1:
*fixed*
  • ffmpeg: removed unnecessary/wrong ticks around some color spaces in ffmpeg call
  • ffmpeg: wrong color space due to height vs width mixup on untagged content
  • Mux: mkv muxing on passthrough
Cu Selur
Old 23rd February 2024, 05:10   #3768  |  Link
Selur
Selur's Avatar
2024.02.23.1:
*fixed*
  • filter view: crop only got applied to filtered half not both views, which causes issues on resize and aspect ration changes
  • Vapoursynth: ignore 'Compare all' when 'Compare View' is enabled
    ent
Cu Selur
Old 23rd February 2024, 22:00   #3769  |  Link
locotus
After finishing remuxing the allready converted files, I noticed that the audio
conversion added 21ms to all audios even if I didn't set that value. Perhaps
this may be part of the mux problem in Mkvtoolnix.
Sorry, I don't have any other file to convert up to now.
Old 23rd February 2024, 22:11   #3770  |  Link
Selur
Selur's Avatar
there should be no audio conversion during remuxing,...
-> not enought details to understand or reproduce
Old 26th February 2024, 13:58   #3771  |  Link
weaker
Nvidia titan v
Hi Selur,
sorry for the late reply. The card is reported as "NVIDIA TITAN V" in the Hybrid logfile. I think the card wasn't marketed as GTX at any time, as the Volta chip is basically the first RTX-like chip.
Best,
weaker
Old 26th February 2024, 17:01   #3772  |  Link
Selur
Selur's Avatar
Send you a link to a dev version which should detect your card.
Cu Selur
Old 29th February 2024, 01:48   #3773  |  Link
ReinerSchweinlin
Originally Posted by weaker View Post
Hi Selur,
Keep in mind, that Volta Video Encoding wasn´t very good back then - if it works for you - fine. But the turing and later encoders are much better. Or recent quicksync would be a cheaper option if you are in for HW-Encoding.
All other stuff about the Titan V is very nice Would love to get my hands on one (not for gaming, of course... compute stuff)
Old 3rd March 2024, 19:37   #3774  |  Link
Selur
Selur's Avatar
2024.03.03.1:
*fixed*
  • Avisynth: (32bit) SplineResize100/144 calls
  • Vapoursynth: custom section hinting accidentally required '# # ...' instead of '# ...'
  • Vapoursynth: allow lowering frame rate with rife
  • Vapoursynth: detect '2020 non .. ' as '2020cl'
  • Vapoursynth: crop in compare view
  • NoXSynth: fix subtitle embedding by changing local.conf handling
  • ui: subtitle controls enabled, even when no subititles are available
*added*
  • Subtitle: Support embedding subtitle when QSVEncC/NVEncC with 'only use encoder' is used.
  • Torch: added DeOldify through vs-deoldify
*changed*
  • Muxing/Extraction: Force FFmpeg for dts/dts-hd audio when dealing with mp4 containers.
  • Subtitle: Subtitle language passthrough handling.
  • Input: Support Gray8 input images.
Cu Selur
Old 10th March 2024, 13:24   #3775  |  Link
Selur
Selur's Avatar
2024.03.10.1:
*fixed*
  • FFmpeg: fixed color transfer signaling
  • Vapoursynth: GMFSS_fortuna model model index
  • Jobs: minimize command line glitch
  • Analysis: YUV jpeg handling
*added*
  • Vapoursynth: add custom CropView pad color
*changed*
Cu Selur
Old 18th March 2024, 07:42   #3776  |  Link
Selur
Selur's Avatar
2024.03.18.1:
*fixed*
  • UI: 'alwaysOnTop' caused Window to disappear
  • Vapoursynth: TFMBob fps calculation
  • Vapoursynth: CodeFormer in CompareView with 'undo upscale' disabled.
*changed*
  • Vapoursynth: updated RIFE models
  • Vapoursynth/Torch: update vs-deoldify
Cu Selur
Old 26th March 2024, 10:19   #3777  |  Link
Selur
Selur's Avatar
2024.03.26.1:
*fixed*
  • Vapoursynth: settings used for DeOldify
  • Vapoursynth: update to RIFE r9mod17
  • Vapoursynth: updated (mlrt)RIFE models
*changed*
Cu Selur
Old 6th April 2024, 09:35   #3778  |  Link
Selur
Selur's Avatar
2024.04.06.1:
*fixed*
  • Vapoursynth: VIVTC 'fix combed with deinterlacer'
  • Analysis: sox volume analysis
  • Audio: delaycut problems
  • Muxing: Crash with video pass-through
  • x264: disable 'adjust letterbox to crop' when Blu-ray/AVCHD restriction is enabled
*changed*
  • Vapoursynth: BasicVSR++ added 'wanted width'
  • Vapoursynth: adjusted to vsDeOldify v3.0.1
  • Video: x265 adjusted to v3.6
Cu Selur
Ps.: also updated torch-addon
