31st August 2017, 01:32 | #22 | Link |
Original analog TV (NTSC, PAL, SECAM) was interlaced to provide more fluid motion within the constraints of the bandwidth allocated to each over the air channel (which was the only way most people could view video at home until the late 1970s). When home video recording equipment became available, that constraint actually got worse, because the "engineering tradeoffs" between cost and usability reduced that analog bandwidth even more. This was true regardless of the system: Beta, VHS, 8mm all had similar constraints.
So when TV went from analog to digital, why was interlacing still used, and in fact, used a LOT? Same problem: engineering constraints. For those not familiar with that term, the more common way to say it is that you can't put ten pounds of stuff in a five pound bag. The OTA frequency allocation is precisely what it was back in 1948. Digital did not change the laws of physics, and more frequency allocation is out of the question because the electromagnetic spectrum has a finite energy spectrum available for broadcasting. Even when it comes to delivery by streaming, Blu-Ray, etc., similar constraints come into play. For instance, computer speeds stalled out over a decade ago, and we are not likely to see any faster CPUs for a long time. We are way down the learning curve on video compression (I was very much involved with this back in the early 1990s) and you aren't going to be able to get high quality video into smaller containers. While many systems can satisfactorily play 60 fps progressive material, not all satellite and cable channels can carry it. The OP seems to think that we can just keep adding resolution and go to higher framerates, but in fact, with the technology we have today and the infrastructure that is in place to carry digital video and audio, even 4K is barely making it to most screens. There is no OTA 4K, and DirecTV and cable has almost no live 4K. Most 4K programming is a download then watch affair. Finally, true interlacing, where the alternate lines are displayed 1/60 (or 1/50) of a second apart, actually works extraordinarily well and looks just fine. It is only when the display can't handle interlacing natively and only when the deinterlacing is botched that we have a problem. Most deinterlacing built into modern displays works amazingly well: I am very critical and have not once watched my 5-year-old LCD big screen and thought, "wow, I can see deinterlacing artifacts." So, deinterlacing lets you get the fluidity of 50 or 60 events per second, but at 1/2 the bandwidth (more or less) that would be require to get 50 or 60 complete frames per second. |
31st August 2017, 05:08 | #24 | Link | |
EDIT: I seem to recall that sample(pixel) signal for PAL TV was something like 30MHz, so if new system has 100,000,000 scanlines then might be about vertically (100,000,000 / ~625) 160,000 times greater, and making assumption that display is about 160,000 times wider, then 160,000 * 160,000 = 2.56 *10^10 * 30MHz = 7.68 * 10^17 = 7,680,000,000,000,000,000 Hz. Anybody know at what frequency X-Rays start ? (C/Wavelength, 300,000,000/Wavelength of XRAY) XRays start at about 10 nano meters, so, 300,000,000/1.0*10^-8 = 30,000,000,000,000,000 Hz So, would be well into XRays, or maybe even beyond that, (whats above XRAYS ?) Numbers above are probably riddled with errors, but probably not that ridiculous. Me guessin' not possible even beyond this century. (unless you watch from behind 6 inches of leaded glass). EDIT: My brother is an X-RAY engineer, maybe I ask him (specializing in TV, ie monitors in MRI scanners etc)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 31st August 2017 at 05:56. |
31st August 2017, 06:01 | #25 | Link | |
Even if your distinction was accurate, which it isn't, in the real world what's possible is usually limited to what's practical so they often amount to much the same thing. Last edited by hello_hello; 31st August 2017 at 06:18. |
31st August 2017, 06:05 | #26 | Link | |
Ionizing radiation in CRTs If you build a circuit to drive the scanning lines faster, the x-ray level will increase dramatically. I can't even begin to calculate how much power would be required. If any of you have ever driven by one of the big nuclear accelerators, like SLAC at Stanford or the big cyclotron outside of Chicago, you get some idea of how much energy it takes to deflect particles (electrons in this case). You also have to build an electronic circuit capable of scanning that many lines in a fraction of a second. The quote Scotty from Star Trek: " We can't even do that in the twenty-third century." Last edited by johnmeyer; 31st August 2017 at 06:10. Reason: typo |
31st August 2017, 06:10 | #27 | Link |
A bit of trivia (at least for me).
Where I am, the ABC (Australian equivalent of the BBC) have used the same logo (or variations of it) since the 1960s. Until now I'd been completely oblivious as to it's origins. I stumbled on this while reading other broadcast related pages. You can learn something every day..... https://en.wikipedia.org/wiki/Austra...ous_curve_logo https://en.wikipedia.org/wiki/Lissajous_curve |
31st August 2017, 06:22 | #29 | Link |
Arh well, no change there then.
31st August 2017, 08:04 | #30 | Link |
Thank you all for a very informative discussion.
In my op I was specifically referring to Blu-ray technology which was designed / Intended for High Definition Video Content, And have been recently frustrated to find that 2 Blu-Ray boxsets of Tv Shows (I recently brought) produced for The BBC in the UK contained some older seasons that are clearly upscaled ports of the standard definition DVD versions of the series while the latest seasons are in full HD 1080i/p. Now HD Capable displays have been around for a good decade now, so I wanted to understand why some tv networks are lagging so far behind in production / filming technology at least for Blu-ray. As far as ota broadcasting goes, HD content can always be down scaled to fit into broadcasting limitations, but as has been pointed out, the cost of upgrading / replacing legacy equipment for smaller tv networks is prohibitive. |
31st August 2017, 10:31 | #31 | Link | |||
Formerly davidh*****
Arguably the need for a deinterlacer is onerous, but they were needed and made, and they are quite good these days. When the UK started shifting to digital broadcasts, everyone still had CRTs would require interlaced signals, so no point changing things then. As flat screen TVs came out, they needed to support interlacing. HD specs are old, so interlacing was still part of it, and it's supported by new TVs anyway so there was no good reason to stop using it. Quote:
The BBC had only just started experimenting with HD when Doctor Who restarted. They shot Torchwood in HD partly as an experiment, and as a result some of the first season episodes are a dark blurry mess because they didn't know exactly what they were doing. Effects for Doctor Who would also have been prohibitively expensive in HD back then - Torchwood's were more limited. Last edited by wonkey_monkey; 31st August 2017 at 10:41. |
31st August 2017, 18:40 | #32 | Link | |
Obviously not. Seems the first four season were SD. Do they put disclaimers on the Bluray packaging? After reading your post I consulted Google and did some more reading: https://en.wikipedia.org/wiki/List_o...leases#Blu-ray The 1996 telemovie received a Blu-ray release on September 19, 2016. Curiously, despite being shot entirely on film, the Blu-ray release is simply an HD upscale of the 480p broadcast copy How pissed would you be if you'd paid good money for that? |
31st August 2017, 18:50 | #33 | Link |
There are channels that use 720p50 or 1080p50. On DVB-T2 in Germany I think not a single channel uses interlacing. HEVC interlacing is inefficient.
If you look through some older posts on this forum you may also find such result with x264. You still save bandwidth in the encoding chain and power on encode/decode but in terms of DVB bandwidth interlacing is not good anymore. Think about it: throwing away lines is a very stupid way of compression (as is chroma sub-sampling). It shouldn't be surprising for AVC, HEVC or other modern lossy compression schemes to surpass it. |
31st August 2017, 19:58 | #34 | Link |
Life's clearer in 4K UHD
Too bad that the french 819-line system never took off in the analogue TV world
1st September 2017, 04:12 | #35 | Link |
SD on Blu Ray
I payed over £100 to import "Merlin Complete Series Blu-Ray" from Amazon.com (as it was not availlable in UK) only to find that the first 3 Seasons are SD upscales of questionable quality.
So yeah I was pissed. And no they don't tell you in the pakaging or description that they are upscales. |
1st September 2017, 11:07 | #36 | Link |
Yep- common practice, specially these days when they expect you to do Blu-ray almost for "free". They use any existing master even if it was done ages ago and it's not good enough to use as Blu-ray source.
No one cares anymore, all what counts is sell numbers. Spoken with my friend who is in BD/UHD BD industry and UHD is doing terribly bad. After initial not bad start now almost no one (except few big places in the whole world) doing UHD projects. When he told me what studios offer for authoring UHD+BD+DVD I'm not surprised- it just doesn't make sense from authoring facility business point. Now it's all in hands of big places which are factories- only numbers count, so don't expect any attention to details or polished transfers. 10 years ago there were many smaller authoring houses in London, today there is none. My old company left BD+DVD business few year ago and even then it was already barely profitable. Shame as Netflix with its sub 20Mbit UHD encodes is far from delivering high-end quality experience at home. Last edited by kolak; 1st September 2017 at 11:09. |
2nd September 2017, 20:54 | #39 | Link | ||
2nd September 2017, 22:20 | #40 | Link |
"Covered", but not as "ideal" as native progressive . 1) Progressive > MBAFF > PAFF in terms of encoding efficiency or quality at a given bitrate . 2) It's not really an issue with BD playback, and even less so with "50Hz" area equipment, but there is potential for deinterlacing progressive content depending on the playback setup. It's been known to happen with "29.97p" encoded as fields with software (MBAFF or PAFF triggers deinterlace instead of content based detection for weave or 2:2 pulldown removal) |
