3rd October 2020, 03:27 | #261 | Link |
any idea of porting BlindPP to new plugin with HBD? or if we can replace it with something else that give at least similar if not 100% identical output? I tried with deblock and aside from the parameters are not similar I didn't get to make the output the same or similar
I need BlindPP since some scripts use it like FunkyDeBlock and SoftSharpen
See My Avisynth Stuff |
12th October 2020, 03:29 | #262 | Link |
is it possible to have http://avisynth.nl/index.php/IT add edeint parameter like TDeint and tfm do? since there are some Japanese sources only work better with IT and the internal deinterlace is not that good
there are https://github.com/HomeOfVapourSynth...VapourSynth-IT to backport if updating original avs one is hard
3rd February 2021, 19:09 | #263 | Link |
Are there any image stabilizer plugins available yet? I read a question about VDub DeShaker today, which may not yet be available for VDub2 x64, and looking through the Wiki page for AviSynth+ x64 plugins, I could not find anything related to DePan or Stab ...
3rd February 2021, 22:02 | #264 | Link | |
Here's a full list of plugins that are available in x64: http://avisynth.nl/index.php/Category:Plugins_x64 Deshaker is available in x64, although I've have not tried it with VDub2. |
6th March 2021, 13:51 | #265 | Link | ||
I did update some old posts with this Reply (note the colors)
note: the ones that has "vs" in their names because they are not same as old avs one (Missing things from avs old one or different parameters)
See My Avisynth Stuff Last edited by real.finder; 12th March 2021 at 20:54. |
6th March 2021, 18:07 | #267 | Link |
Pig on the wing
What functionalities of Dither you are looking for? It already has the 16bit hack implemented, but it could be that the functionality can be achieved by some other tool.
6th March 2021, 20:44 | #270 | Link | |
Pig on the wing
http://avisynth.nl/index.php/Avsresize
6th March 2021, 23:36 | #271 | Link |
z_ConvertFormat is good, but it's not a full replace for dither tools, there are https://github.com/EleonoreMizo/fmtconv as dither tools vs port, so it's better to back port it than update the old dither tools
edit: even fmtconv can't be a full replacement for dither tools, since the functions in dither tools has additional features like soft and maxts in Dither_add_grain16 (addgrainc alternative) and fmtconv don't has Dither_add_grain16 alternative edit: https://forum.doom9.org/showthread.p...71#post1937771
See My Avisynth Stuff Last edited by real.finder; 12th March 2021 at 21:01. |
7th March 2021, 06:39 | #272 | Link |
Good day to all.
Has anyone found Convolution3D for Windows 64-bit? I know MipSmooth exists, but it works a little differently and slower. |
10th March 2021, 11:05 | #274 | Link |
That was indeed the homepage of the author once. But it vanished. The AviSynth Wiki links to a WebArchive of this domain for the 32-bit version.
I guess you can simulate such a generic plugin with MaskTools etc. but an optimized plugin will probably be more efficient, especially with a variety of color spaces... |
10th March 2021, 13:40 | #275 | Link | |
I found the source code on another site, but I don’t know what to do with it. I am not a software developer. Last edited by Arx1meD; 10th March 2021 at 13:45. |
10th March 2021, 14:46 | #276 | Link |
After looking the code:
From coder's point of view its internal asm is incompatible with x64 (e.g. using 32 bit registers for pointers). Instead of hacking that it would need a SIMD intrinsic rewrite: asm{} block syntax is not valid for x64. And one should use SSE2 instead of MMX. Surely it needs some hours of working time. Webarchive source: http://web.archive.org/web/201301180...yv12-beta5.zip |
11th March 2021, 08:22 | #279 | Link | |
Really, the last sentence was for you: "Surely it needs some hours of working time." The rest is just a note for those (incl. me) who are considering touching the plugin. Interesting and not so hard task, but when someone starts working on it, please note it here and I'll then not spend time on that. Last edited by pinterf; 11th March 2021 at 08:24. |
11th March 2021, 08:58 | #280 | Link |
Looking into the description (Convolution3d.txt) it is not that straightforward doing it with Expr.
Unfortunately there is no C version - so at least the code has to be reverse-engineered if it's doing the same as stated in the description. So strange that old coders are starting immediately with coding assembler. A huge contrast to present coding standards where there must be a working C prototype to understand and simulate the basic behaviour even if it is optimized later for a specific processor and thus the code written in C won't not run at all. (until someone recognizes that the compiler sometimes generate quicker code than the hand-written assembler and drop old assembler routines) |
