9th July 2013, 21:30 | #242 | Link | |
I'd certainly be interested in re-doing the tests if someone has better settings for either x264 or vp9 to try out. As for --cpu-used=4, I've tried that and --threads=4 but to no avail, vpxenc only used one of my cores, of course I make sure to run 4 simultaneous encodings when doing tests so as to make use of my full cpu capacity, but I've never been able to have one encoding use more than 1 core. Is there some configuration option necessary when compiling vpx? |
9th July 2013, 22:32 | #244 | Link |
BadFrame good comparasions there.
And i totally agree, i am impressed with how good VP9 looks, especially on low bitrate (under 1k). But above 1k bitrate, it really polishes the picture compared to X264, which can barely show the picture correctly more or less. |
9th July 2013, 22:50 | #245 | Link | |
http://www.sendspace.com/file/embffb And yes, I was thinking about doing tests using the hm reference encoder, but if you do it instead then that's just fine by me |
9th July 2013, 22:55 | #247 | Link |
BadFrame
thx. I am not familiar with reference HEVC encoder. I want to try Strongene HEVC latest beta version. |
9th July 2013, 22:58 | #248 | Link |
Videogame is probably alot more complex with movement in terms of small details compared to Bluray.
At least in that source ( a dark scene with some effects from shooting etc). And itīs very good to see how it performs in Dark Scenes, as that is where every encoder "Fails" to put it simple. |
9th July 2013, 23:00 | #249 | Link | |
At 2000 bits the difference wasn't that profound though, in my opinon, although I think VP9 still clearly won. I'd like to do some high definition animation tests on my Akira bluray, I just gotta figure out how to decrypt it. |
9th July 2013, 23:03 | #250 | Link |
zerowalker
You may try this video sample. (660mb) Have dark, static, dynamic scenes, some film grain, and very high quality. Code:
Format : AVC Format profile : High@L4.0 Duration : 2mn 7s Bit rate : 43.4 Mbps Width : 1 920 pixels Height : 1 080 pixels Stream size : 660 MiB (99%) |
9th July 2013, 23:05 | #251 | Link | |
9th July 2013, 23:06 | #252 | Link |
Yes indeed, at high bitrates, the only Real difference was that x264 wasnīt able to keep the image "accurate", it tried it best to keep the bits at the right places, but you can clearly see that it doesnīt do to well.
While VP9 have alot more balance, and is able to produce a much more detailed and accurate image. Though, the difference isnīt Day and Night, but itīs still there. And thinking that VP9 will be better and better makes this very interesting! |
10th July 2013, 04:41 | #255 | Link |
Is there any configuration to use the vp9 to get the max PSNR using the fixed QP coding? I want to do a comparison between the HEVC HM and the vp9 reference software.
The Next Generation Internet Video Codec project.[/url]. |
11th July 2013, 08:32 | #257 | Link |
Well letīs try to keep it towards VP9. Comparing VP9 with HEVC is a good thing though, they should be compared as they are combating about the "throne".
But i would like to know, why canīt i make a .webm file with VP9? mkvtoolnix doesnīt allow this for some reason, i thought the VP9 in Webm was a standard for a while now, or has it been changing alot, making them wait? |
11th July 2013, 13:55 | #259 | Link | |
Did vp9 made it into the main ffmpeg branch? |
11th July 2013, 13:58 | #260 | Link |
Probably, would like to see it though, but as there is no decoder to play the videos, it doesnīt really matter at this time.
From when i last checked, No. ffmpeg seems to go after the git version 1.2.0 instead of Master for some reason. |
google, ngov, vp8, vp9, vpx, webm |
