17th April 2011, 18:50 | #9481 | Link | |
The Black Reaper
Not 100% sure though. |
17th April 2011, 21:41 | #9482 | Link | |
Well, benjyv, you can try "Urusoft Subtitle workshop" for editing / conversion of subtitle files and / or try remuxing using YAMB if you wanna keep the source subtitle format (drag-drop all the resources you wanna include, if it is supported : YAMB will accept). Last edited by puplone; 17th April 2011 at 21:50. |
19th April 2011, 06:04 | #9484 | Link |
HI Atak !!
I've already asked you , but I need to ask again 'cuz I didn't get any answer : Where is the option for changing B-Pyramid - Normal. Now is setted only b-pyramid none!! Also I must change some other settings like : Adaptive Quantizers strength , M.E. Range , M.E. Algorithm , Psy-RD strength , a.s.o. If you wanna talk about details of these parameters ,I'm waiting a PM from you or a discussion here !! |
20th April 2011, 10:32 | #9488 | Link | |
Posts: n/a
Probably explains why no answer, it's not really worth stating as you obviously haven't tried it .... 7ek |
20th April 2011, 17:44 | #9489 | Link |
Atak, a feature request: in the audio conversion options for .mkv, can you provide an option for converting DTS 1.5mbps streams to legacy DTS 754kbps? That cuts the file size by half--1.5mbps stream can sometimes seem unnecessary for some soundtracks--while still keeping a DTS track. 640kbps ac3 is a perfectly good alternative, but 754kbps DTS would also be a nice option to have, and with EAC3 already in the tools perhaps this, I hope, wouldn't be too difficult to implement.
20th April 2011, 19:48 | #9490 | Link |
This does not make sense because DTS 768 kbps would sound worse than AC3 448 kbps. According to tests DTS 1,5Mbps sounds as good as AC3 640kbps if encoded from lossless format. Also don't forget that re-encoding lossy format to another lossy will cause futher degradation in quality.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th April 2011 at 19:54. |
20th April 2011, 22:08 | #9491 | Link |
Atak,
Is there any way to make the RipBot load this script, or the only way is to load the avs script as input a video? "DirectShowSource("D:\BLU_RAY\A_AVENTURA_PELOS_RECIFES_DE_CO\BDMV\STREAM\00000.m2ts") MCTemporalDenoise(settings="medium" ,gpu=TRUE)" |
21st April 2011, 10:44 | #9493 | Link |
How about new profiles?
"[DXVA] Highest Q 720p" "[DXVA] Highest Q 1080p" It works on my Ati HD-3870. Can u test it out with older cards and newest driver if it plays in MPC-HC DXVA mode. 720p code line: --level 4.1 --vbv-bufsize 50000 --vbv-maxrate 50000 --filter 0,0 --ref 9 --bframes 16 --b-adapt 2 --b-pyramid none --subme 10 --aq-mode 1 --trellis 2 --partitions all --me tesa --keyint 300 --min-keyint 30 --merange 40 1080p code line: --level 4.1 --vbv-bufsize 50000 --vbv-maxrate 50000 --filter 0,0 --ref 4 --bframes 16 --b-adapt 2 --b-pyramid none --subme 10 --aq-mode 1 --trellis 2 --partitions all --me tesa --keyint 300 --min-keyint 30 --merange 60 |
21st April 2011, 11:02 | #9494 | Link |
How can I change some other settings like : Adaptive Quantizers strength , M.E. Range , M.E. Algorithm , Psy-RD strength , a.s.o. ???? How can I attach a .sup file ( after demuxing it , of course) to a movie , without re-encoding ??? I forgot to select it in the begining Hope this time will answer somebody who REALLY knows the true answers !!! ;-) |
21st April 2011, 11:41 | #9495 | Link | ||
http://www.videohelp.com/tools/MKVtoolnix From input add mp4 add audio add subtitles and mux Last edited by hopstiii; 21st April 2011 at 11:53. |
21st April 2011, 12:09 | #9496 | Link |
@hopstiii
Thanks but here we're talking about Ripbot and its specific settings Following your advice I must give up to Ripbot and use classical MeGui...I know very well to use MeGui and do settings there.. Here is the issue ,on Ripbot ;-) |
21st April 2011, 13:59 | #9497 | Link |
Thank you for RipBot264!
Discovered two errors in RipBot264. 1. Not correct expose aspect ratio (720x480-704x480) Source 720x480.avs (1.5 = 15:10) -> 720x480 (1.77 = 16:9) Source 712x480.avs (1.5 = 15:10) -> 712x480 (1.5 = 15:10) OK! Source 704x480.avs (1.5 = 15:10) -> 704x480 (1.77 = 16:9) 2. Not correct determine the fps H264 in avi. If the source x264.avi (x264 23.976fps), RipBot264 defines 25fps. If the source Xvid.avi (Xvid 23.976fps), RipBot264 determine correctly 23.976fps. OK! Sorry for my English (Google Translate) Last edited by star5; 21st April 2011 at 14:02. |
21st April 2011, 16:17 | #9499 | Link |
Atak
Just remembering ... http://forum.doom9.org/showpost.php?...postcount=9466 I have done some encoding of DVD, and I can say that the tool PgcDemux was primordial to the success of all. Without making the demux by PgcDemux or DVD Shrink (Re-author) is impossible to succeed at all. Last edited by jandor; 21st April 2011 at 16:28. |
21st April 2011, 19:01 | #9500 | Link | |
--b-pyramid <string> Keep some B-frames as references [normal] - none: Disabled - strict: Strictly hierarchical pyramid - normal: Non-strict (not Blu-ray compatible) Code:
--aq-strength <float> Reduces blocking and blurring in flat and textured areas. [1.0] Code:
--merange <integer> Maximum motion vector search range [40 for 720p, 60 for 1080p] Code:
--me <string> Integer pixel motion estimation method ["hex"] - dia: diamond search, radius 1 (fast) - hex: hexagonal search, radius 2 - umh: uneven multi-hexagon search - esa: exhaustive search - tesa: hadamard exhaustive search (slow) Code:
--psy-rd Strength of psychovisual optimization ["1.0:0.0"] #1: RD (requires subme>=6) #2: Trellis (requires trellis, experimental) --b-pyramid strict --aq-strength 0 --merange 60 --me umh --psy-rd 1 That will go in code box. Last edited by hopstiii; 21st April 2011 at 19:10. |
