Old 14th March 2024, 15:23   #961  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Originally Posted by kalehrl View Post
Any advice how to create a mask for this kind logo:
I've no idea what "this kind" means.
This image looks like any other random image.
VoodooFX is offline   Reply With Quote
Old 14th March 2024, 16:05   #962  |  Link
kalehrl
I don't known how to describe it. It's very transparent and faint. The whole video file is pretty dark and automask fails to create a proper mask using the default values. Are there any advanced options which may help?
kalehrl is offline   Reply With Quote
Old 14th March 2024, 16:10   #963  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Can you share the video?
Old 14th March 2024, 19:44   #964  |  Link
kalehrl
It's 47 minutes long. How much video do you need? I need to cut it because my upload speed is slow.
EDIT: Link removed.
I hope it's enough.
Old 14th March 2024, 20:21   #965  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Use Analyze=1 or Analyze=2 with NoBorderAt="bottom".
Then for high transparency logos you want to use higher aMix when getting basemask.
Old 14th March 2024, 20:59   #966  |  Link
kalehrl
Thank you. Those extra options did the trick.
One more question. You noticed that the video has 2 logos.
How can I create 2 masks with automask?
Old 14th March 2024, 21:22   #967  |  Link
kedautinh12
Make a mask first, do the second later
Old 14th March 2024, 22:11   #968  |  Link
kalehrl
I did it that way but then I end up with 2 masks which significantly slow down the encoding.
I think having 1 mask with 2 logos will result in faster encoding.
Old 14th March 2024, 22:29   #969  |  Link
HeinrichI
On another episode of the series, where I'm trying to remove the logo, the transparency is better, and the removal works, but at times there is colored noise, how can I reduce it?
HeinrichI is offline   Reply With Quote
Old 14th March 2024, 22:44   #970  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Try these:
Inflate=2, Optimize2=2, dPP=-5
Btw, if resolution is same then you can use these masks on that previous episode too.
Old 14th March 2024, 22:46   #971  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
No, it wouldn't.
Old 15th March 2024, 04:47   #972  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Unfabulous_AutomaskTemp_A2.bmp:
You didn't left enough space at the right side, and other sides have too large borders. This can have negative impact on generation of ebmp masks.
Remove 30 pixels at left.
Add 6 pixels at right.
Remove 16 pixels at top.
Remove 40 pixels at bottom.
Old 8th April 2024, 15:45   #973  |  Link
Floatingshed
I am getting an error message repeatedly, I don't understand.
"Source clip must have at least two frames for alpha computation"
Clip is over 18000 frames...
Floatingshed is offline   Reply With Quote
Old 8th April 2024, 21:58   #974  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Share your full avs script and mask. And cut video sample if possible.
Old 9th April 2024, 14:37   #975  |  Link
Floatingshed
Thanks for the offer of help.
Script, mask and video clip here:
https://wetransfer.com/downloads/bbd...ource=sendgrid
Old 9th April 2024, 18:27   #976  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
You didn't left at least 10 pixels around logo in Loc.
The basemask is not good.
Video quality is crap - you'll have crap deblend result.
delogo, hardsubs, ocr, remove, watermark
