Old 6th February 2022, 15:50   #181  |  Link
sl1pkn07
Pajas Mentales...
Originally Posted by MysteryX View Post
I've installed all the packages I needed from the AUR. Only BM3D_CUDA fails to compile, and... Akarin plugin is the only one missing from the AUR.
BM3D_CUDA gives this
==> Starting build()...
-- The CXX compiler identification is GNU 11.1.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at /usr/share/cmake/Modules/CMakeDetermineCUDACompiler.cmake:179 (message):
  Failed to find nvcc.
  Compiler requires the CUDA toolkit.  Please set the CUDAToolkit_ROOT
  variable.
Call Stack (most recent call first):
  source/CMakeLists.txt:3 (project)
try now
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 6th February 2022, 18:02   #182  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
For BM3D_CUDA, it worked after rebooting. It needs a reboot for cuda package to be detected.
One annoying thing, however, is that it requires a 3GB dependency to compile, and that dependency remains there afterwards.
MysteryX is offline   Reply With Quote
Old 6th February 2022, 18:17   #183  |  Link
sl1pkn07
Pajas Mentales...
you not need reboot. just relogin your user (or run by hand `source /etc/ld.so.conf.d/cuda.conf`). the plugin needs cuda to run. so need keep for runing (for that is setted in depends=() ). arch not separe the package in modules like ubuntu/debian. package all cuda as only one package
and please use the package comments in [AUR] if you have a problem with the packages
greetings
Old 6th March 2022, 19:15   #184  |  Link
Tohno_Neil
I usually manually install VapourSynth plugins and scripts,
and last time get bugs that I can't fix (haf.QTGMC),
until I use the vsrepo,
vsrepo.py install havsfunc ffms2 d2v -t win64 -b "C:\VapourSynth\plugins" -s "C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Lib\site-packages"
vsrepo.py install Bifrost Bilateral "CAS - Contrast Adaptive Sharpening" Cnr2 Curve Damb DCTFilter Deblock DeLogo DFMDerainbow DFTTest degrainmedian DotKill fillborders FieldHint Histogram IT LSMASHSource MCDenoise "Miscfilters (obsolete)" ReadMpls MSmoosh muvsfunc MVTools "MVTools (float)" mvsfunc NRDB Oyster DeblockPP7 Retinex RemoveGrain Scxvid SmoothUV SSIQ TCanny TComb TDeintMod TIVTC TempLinearApproximate TNLMeans vctrans VagueDenoiser VFRToCFR VSFilter VSFilterMod vsTAAmbk AWarpSharp2 xvs Yadifmod ZNEDI3 -t win64 -b "C:\VapourSynth\plugins" -s "C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Lib\site-packages"
Tohno_Neil is offline   Reply With Quote
Old 27th August 2022, 18:43   #185  |  Link
Selur
Selur's Avatar
Please add a comment to vsrepo on github that it's only for Windows. Thanks
