Old 23rd January 2022, 00:50   #521  |  Link
kedautinh12
I think xclean avisynth version still don't finish
Old 23rd January 2022, 02:19   #522  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Oh and I spent a full week to get GPU passthrough to work for my Windows Virtual Machine... this is what I had to go through...
yes xClean Avisynth is what needs to be finished. Also a comparison video I want to produce. Got a long list of things to do...
MysteryX is offline   Reply With Quote
Old 25th January 2022, 16:48   #523  |  Link
real.finder
Originally Posted by Selur View Post
Any news on RIFE incorporation into FrameRateConverter?
don't know if it possible or not but I think most mvtools problems come from bad motion vectors that MAnalyze do, so I wonder if MAnalyze can be updated to use some ideas from RIFE (neural network) to make perfect solution not only for FrameRateConverter but for any thing use MAnalyze like Motion Compensated and Temporal Denoising (like SMDegrain)
See My Avisynth Stuff
Old 25th January 2022, 16:58   #524  |  Link
johnmeyer
Probably not. I say that because I've been watching a lot of "restored" old USA TV shows that were shot on film (e.g., "Perry Mason"). Many of them have been "improved" to show at 60 fps instead of how they were shot (24 fps). Since I've done so much of this work, I instantly see all the artifacts and, even when using professional motion estimation tools, all the artifacts you see when using MVTools are there: broken vertical objects, warping at edges when a foreground objects moves across the screen, and "broken legs" when people walk across the frame at a certain distance from the camera. I also see it on establishing shots when the camera pans up across a tall building that has lots of small windows.
Old 25th January 2022, 21:10   #525  |  Link
real.finder
yes I know it will not be perfect improved
with "perfect solution" I mean as "RIFE incorporation into FrameRateConverter" plus improve mvtools in general
Old 26th May 2022, 02:29   #526  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
Any plans for 10-bit YUV support?
zambelli is offline   Reply With Quote
Old 3rd June 2022, 06:56   #527  |  Link
takla
Interpolating 60 fps from 24 fps is just moronic.
takla is offline   Reply With Quote
Old 4th June 2022, 18:25   #528  |  Link
Selur
Selur's Avatar
Any updates on Vapoursynth&RIFE support? (adding support for RIFE-v4 model and the new skip&skip_threshold might be a good idea)
Old 20th August 2022, 19:32   #529  |  Link
Selur
Selur's Avatar
Any news?
Old 26th August 2022, 19:59   #530  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Updates? Released a few software for Windows/Linux/MacOS
https://sourceforge.net/projects/converter432hz/
https://sourceforge.net/projects/player432hz/
https://sourceforge.net/projects/yangdownloader/
https://sourceforge.net/projects/powerliminals-player/
plus xClean script
Haven't got back to FrameRateConverter yet.
Old 27th August 2022, 08:28   #531  |  Link
Selur
Selur's Avatar
fingers crossed this will change soon, really like the idea of FrameRateConverter using RIFE properly
Old 27th August 2022, 09:38   #532  |  Link
kedautinh12
Yeah, RIFE support avs and vs now. Maybe need new ver of FrameRateConverter using RIFE
Old 27th August 2022, 17:56   #533  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
if RIFE supports AVS, it should be easy to do.
It's porting it to VapourSynth that is more complicated; particularly that the MvTools2 masks are completely different under VapourSynth!
I'm now on Linux and not currently setup for Avisynth development, but if someone wants to do it...
Just edit the frame blending clip like this: run RIFE once or twice before frame blending and voilą!
Could have a parameter "rife" set to -1 for automatic, 0 to disable, 1 or more to manually specify how many passes of doubling frames. We still need frame-blending to reach the exact desired framerate.
Old 28th August 2022, 14:09   #534  |  Link
kedautinh12
Dogway add RIFE to FrameRateConverter now
https://github.com/Dogway/Avisynth-S...verterMIX.avsi
Old 28th August 2022, 15:37   #535  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
How is RIFE working out?
Old 20th September 2022, 13:11   #536  |  Link
Dogway
I did some tests and found that DCT=1, DCTRe=4 and CalcDiff=true (so 'Slowest' preset with DCTRe=4) made improvements for blending and some distortions.
Only tested on one shot but compared to no-RIFE is simply at another level. RIFEAnime stays at 'Slow' preset. Maybe you can check if implementation is correct.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 20th September 2022, 16:22   #537  |  Link
johnmeyer
DCT=1 sometimes (not always) makes improvements in motion estimation artifacts, but at a 5x speed penalty! It is definitely worth testing on each video before proceeding.
Old 20th September 2022, 17:45   #538  |  Link
Dogway
I think RIFE is also very slow so maybe it can be thought as a 'Placebo' preset, despite not being placebo at all.
I will try to run it through some popular clips like the one with the fence or the famous one @zorr used for zopti.
Old 19th March 2024, 02:38   #539  |  Link
takla
Script error: the named argument "str" to StripeMask had the wrong type
FrameRateConverter.avsi, line 219
And
with Dogways FrameRateConverterMIX.avsi I get
Evaluate: operands of "%" must be integers
ExTools.avsi, line 7509
