Old 5th June 2019, 20:52   #201  |  Link
Which version AVS are you using, x86 or x64 ?
Old 5th June 2019, 20:55   #202  |  Link
hfrforever
according to the wiki, FFMS2 should work...
http://avisynth.nl/index.php/FFmpegSource
hfrforever is offline   Reply With Quote
Old 5th June 2019, 21:12   #203  |  Link
Which version avs are you using ? (x86, x64)
Old 5th June 2019, 21:25   #204  |  Link
hfrforever
I also tried the LSMASHVIDEO source, but got similar errors. I also checked the wiki, and FFMS2 should be correct syntax
Old 5th June 2019, 21:25   #205  |  Link
hfrforever
I am using the x86
Old 5th June 2019, 21:26   #206  |  Link
hfrforever
Not really sure why I am using this version...
Old 5th June 2019, 21:52   #207  |  Link
Groucho2004
Originally Posted by hfrforever View Post
I am using the x86
Download this tool, run it, save the info and post that.
Groucho's Avisynth Stuff
Old 5th June 2019, 22:11   #208  |  Link
hfrforever
The installed Avisynth version is a 2.6 Alpha or RC:
C:\WINDOWS\SysWOW64\avisynth.dll
Update to Avisynth 2.6 Release or Avisynth+
Old 5th June 2019, 22:13   #209  |  Link
hfrforever
I am inclined to save the plugins i have, and then uninstall avisynth, and try installing it again.
Old 5th June 2019, 22:16   #210  |  Link
You want latest one, the one you have is quite old:- https://github.com/pinterf/AviSynthPlus/releases
Old 5th June 2019, 22:20   #211  |  Link
hfrforever
[OS/Hardware info]
Operating system: Windows 10 (x64) (Build 18362)
CPU: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz / Haswell (Core i7)
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, FMA3, AVX, AVX2
4 physical cores / 8 logical cores
[Avisynth info]
VersionString: AviSynth 2.60, build:Mar 31 2015 [16:38:54]
VersionNumber: 2.60
File / Product version: 2.6.0.6 / 2.6.0.6
Interface Version: 5
Multi-threading support: No
Avisynth.dll location: C:\WINDOWS\SysWOW64\avisynth.dll
Avisynth.dll time stamp: 2015-03-31, 06:40:58 (UTC)
PluginDir2_5 (HKLM, x86): C:\Program Files (x86)\AviSynth\plugins
[CPP 2.5 Plugins (32 Bit)]
C:\Program Files (x86)\AviSynth\plugins\LSMASHSource.dll [2017-02-25]
[CPP 2.6 Plugins (32 Bit)]
C:\Program Files (x86)\AviSynth\plugins\DirectShowSource.dll [2.6.0.3]
C:\Program Files (x86)\AviSynth\plugins\ffms2.dll [2016-12-29]
C:\Program Files (x86)\AviSynth\plugins\FrameRateConverter.dll [2019-06-05]
C:\Program Files (x86)\AviSynth\plugins\TCPDeliver.dll [2.6.0.7]
[Scripts (AVSI)]
C:\Program Files (x86)\AviSynth\plugins\colors_rgb.avsi [2015-03-30]
C:\Program Files (x86)\AviSynth\plugins\FFMS2.avsi [2015-05-22]
C:\Program Files (x86)\AviSynth\plugins\FrameRateConverter.avsi [2019-06-05]
[Uncategorized DLLs (32 Bit)]
C:\Program Files (x86)\AviSynth\plugins\avcodec-57.dll [57.81.100.0]
C:\Program Files (x86)\AviSynth\plugins\avformat-57.dll [57.66.102.0]
C:\Program Files (x86)\AviSynth\plugins\avresample-3.dll [3.2.0.0]
C:\Program Files (x86)\AviSynth\plugins\avutil-55.dll [55.47.100.0]
C:\Program Files (x86)\AviSynth\plugins\swscale-4.dll [4.3.101.0]
[Uncategorized files]
C:\Program Files (x86)\AviSynth\plugins\ChangeLog.txt [2019-06-05]
C:\Program Files (x86)\AviSynth\plugins\COPYING [2016-10-18]
C:\Program Files (x86)\AviSynth\plugins\ffms2-avisynth.md [2016-10-13]
C:\Program Files (x86)\AviSynth\plugins\ffms2.lib [2016-12-29]
C:\Program Files (x86)\AviSynth\plugins\ffmsindex.exe [2016-12-29]
C:\Program Files (x86)\AviSynth\plugins\LICENSE [2019-06-05]
C:\Program Files (x86)\AviSynth\plugins\README.md [2019-06-05]
[Plugin errors/warnings]
________________________________________________________________________________________________________________________________________
LoadPlugin: unable to load "C:\Program Files (x86)\AviSynth\plugins\LSMASHSource.dll", Module not found. Install missing library?
Dependencies that could not be loaded:
avutil-55.dll
avcodec-57.dll
avformat-57.dll
swscale-4.dll
avresample-3.dll
VCRUNTIME140.dll
Note: Visual Studio 2015/2017 Runtime doesn't seem to be installed
LoadPlugin: unable to load "C:\Program Files (x86)\AviSynth\plugins\FrameRateConverter.dll", Module not found. Install missing library?
VCRUNTIME140.dll
Old 5th June 2019, 22:25   #212  |  Link
Groucho2004
Download the All-In-One MS runtime installer you can find here. It updates all runtimes and uninstalls outdated ones if required.
Old 5th June 2019, 22:36   #213  |  Link
hfrforever
alright I updated to the one you linked and ran the runtime installer. Here is the info from the tool. I tried it again, and get this error https://drive.google.com/open?id=1ue...stbO6BYzbyIRk-
[OS/Hardware info]
[Avisynth info]
VersionString: AviSynth+ 0.1 (r1576, x86)
VersionNumber: 2.60
File / Product version: 2.6.0.5 / 2.6.0.5
Interface Version: 4
Avisynth.dll time stamp: 2014-01-03, 02:14:26 (UTC)
PluginDir2_5 (HKLM, x86): C:\Program Files (x86)\AviSynth+\plugins
PluginDir+ (HKLM, x86): C:\Program Files (x86)\AviSynth+\plugins+
C:\Program Files (x86)\AviSynth+\plugins\LSMASHSource.dll [2017-02-25]
C:\Program Files (x86)\AviSynth+\plugins+\DirectShowSource.dll [2014-01-03]
C:\Program Files (x86)\AviSynth+\plugins+\ImageSeq.dll [2014-01-03]
C:\Program Files (x86)\AviSynth+\plugins+\Shibatch.dll [2014-01-03]
C:\Program Files (x86)\AviSynth+\plugins+\TimeStretch.dll [2014-01-03]
C:\Program Files (x86)\AviSynth+\plugins+\VDubFilter.dll [2014-01-03]
C:\Program Files (x86)\AviSynth+\plugins\DirectShowSource.dll [2.6.0.3]
C:\Program Files (x86)\AviSynth+\plugins\ffms2.dll [2016-12-29]
C:\Program Files (x86)\AviSynth+\plugins\FrameRateConverter.dll [2019-06-05]
C:\Program Files (x86)\AviSynth+\plugins\TCPDeliver.dll [2.6.0.7]
[Scripts (AVSI)]
C:\Program Files (x86)\AviSynth+\plugins+\colors_rgb.avsi [2014-01-03]
C:\Program Files (x86)\AviSynth+\plugins\FFMS2.avsi [2015-05-22]
C:\Program Files (x86)\AviSynth+\plugins\FrameRateConverter.avsi [2019-06-05]
C:\Program Files (x86)\AviSynth+\plugins\avcodec-57.dll [57.81.100.0]
C:\Program Files (x86)\AviSynth+\plugins\avformat-57.dll [57.66.102.0]
C:\Program Files (x86)\AviSynth+\plugins\avresample-3.dll [3.2.0.0]
C:\Program Files (x86)\AviSynth+\plugins\avutil-55.dll [55.47.100.0]
C:\Program Files (x86)\AviSynth+\plugins\swscale-4.dll [4.3.101.0]
C:\Program Files (x86)\AviSynth+\plugins+\colors_rgb.txt [2014-01-03]
C:\Program Files (x86)\AviSynth+\plugins\ChangeLog.txt [2019-06-05]
C:\Program Files (x86)\AviSynth+\plugins\COPYING [2016-10-18]
C:\Program Files (x86)\AviSynth+\plugins\ffms2-avisynth.md [2016-10-13]
C:\Program Files (x86)\AviSynth+\plugins\ffms2.lib [2016-12-29]
C:\Program Files (x86)\AviSynth+\plugins\ffmsindex.exe [2016-12-29]
C:\Program Files (x86)\AviSynth+\plugins\LICENSE [2019-06-05]
C:\Program Files (x86)\AviSynth+\plugins\README.md [2019-06-05]
EDIT:
Here is the script i ran that gave me that error.
ffms2 ("C:\Users\padge\Documents\test video.mp4") # This implicitly assigns clip to a special variable called Last (when not explicitly assigned to anything else)
FrameRateConverter() # defaults FrameRate * 2, both takes and produces clip Last
return Last
Old 5th June 2019, 22:45   #214  |  Link
hfrforever
i am in bad storms rn, and the power just went out. I may be offline until tomorrow. I want to save my computer battery. I will try to check in a few hours.
Old 5th June 2019, 22:46   #215  |  Link
Groucho2004
You need MVTools2. While you're at it, also download some essential plugs you'll probably need sooner or later:
MaskTools2
RGTools
Old 5th June 2019, 22:54   #216  |  Link
Groucho2004
D'oh. Use the link for AVS+ that StainlessS gave you: https://github.com/pinterf/AviSynthPlus/releases
Old 5th June 2019, 23:09   #217  |  Link
You dont need any of these in the plugins directory
C:\Program Files (x86)\AviSynth+\plugins+\colors_rgb.txt [2014-01-03]     # Descriptive only
C:\Program Files (x86)\AviSynth+\plugins\ChangeLog.txt [2019-06-05]      # Changelog for ffms2
C:\Program Files (x86)\AviSynth+\plugins\COPYING [2016-10-18]             # stuff for ffms2
C:\Program Files (x86)\AviSynth+\plugins\ffms2-avisynth.md [2016-10-13] # documentation for ffms2
C:\Program Files (x86)\AviSynth+\plugins\ffms2.lib [2016-12-29]     # Some compiler stuff for ffms2 (developer thingy)
C:\Program Files (x86)\AviSynth+\plugins\ffmsindex.exe [2016-12-29] # for indexing video file outside of avisynth (command line)
C:\Program Files (x86)\AviSynth+\plugins\LICENSE [2019-06-05] # documentation for ffms2
C:\Program Files (x86)\AviSynth+\plugins\README.md [2019-06-05] # documentation for ffms2
Dont just dump everything you find into the plugins directory.
When you have ffms2 and LSmash working then try the previously given multiple source loader (given in post #198)
For anyone else wanting to try the multi-source loader script function, here is a 7zip compressed file (~31MB: AVI_LSMASH_FFMS2_SOURCE.7z):-
http://www.mediafire.com/file/2kuq0f...RCE.7z.7z/file
Above 7zip file using Ultra Compression, so may need latest version 7Zip if yours is old (saved an extra 10MB).
Contains both x86 and x64
FFMS2 (XP compatible [C Filter NOT CPP, but autoloads OK in AVS+ without LoadCPlugin call])
LSmash(NOT XP Compatible, CPP filter)
Multi-Source Script function [ GetSeq() ], tries AVI, both LSmash filters and FFMS. (and dubs audio to video)
Also contains RT_Stats latest, v2.00 Beta 12(used by the multi-source loader script).
EDIT:Also, with DebugView (Google or here:- https://docs.microsoft.com/en-us/sys...oads/debugview)
Can show debugging info from the script function (GetSeq), below succeeds,
00000015    1.08073246  [1384] FFMS2 avs plugin: Initializing...
00000016    1.19320846  [1384] GetSeq: LSMASHVideoSource opened Video
00000017    1.19328237  [1384] GetSeq:   'D:\TEMPLATE\heima_720p_500.mp4'
00000018    1.27220118  [1384] GetSeq: LSMASHAudioSource opened Audio
00000019    1.27224672  [1384] GetSeq:   'D:\TEMPLATE\heima_720p_500.mp4'
EDIT: FFMS2 can fail on some MP4(ISO) files, LSmashVideoSource() is specifically for ISO files.
Function IsISOFileName(String s)  {s=RT_GetFileExtension(s) Return(s==".mov"||s==".mp4"||s==".m4v"||s==".3gp"||s==".3g2"||s==".mj2"||s==".dvb"||s==".dcf"||s==".m21")}
Old 6th June 2019, 02:09   #218  |  Link
hfrforever
Alright, I have ____ min of internet left before my battery backup dies, but even after installing that plugin, It still gives me the same error as above https://drive.google.com/open?id=1ue...stbO6BYzbyIRk-
edit, here is the script i am using. If i have time, i will try the other one as well.
LSmashVideoSource ("C:\Users\padge\Documents\test video.mp4") # This implicitly assigns clip to a special variable called Last (when not explicitly assigned to anything else)
return Last
Old 6th June 2019, 02:16   #219  |  Link
hfrforever
Here is the error I get with your script. https://drive.google.com/open?id=11Q...k-z7dfuvt1JCoG
Old 6th June 2019, 02:29   #220  |  Link
Groucho2004
Run the info tool again and post the log.
