Old 19th September 2016, 17:51   #21  |  Link
brucethemoose
Originally Posted by feisty2 View Post
it should work on cartoon stuff also I guess, but probably not worth it, Vine is pretty slow, and other lower quality but levels faster dehalo filters might be good enough for cartoons since getting cartoonized is one of the last things to worry about on literally cartoon vids
Some toons have more detailed, painted backgrounds that you have to worry about, but that's still true.
In fact, my problem is that Vine isn't strong enough... I've tried tweaking parameters, but it barely puts a dent in big sharpening halos like this:
http://i.cubeupload.com/YAZVwX.png
brucethemoose is offline   Reply With Quote
Old 19th September 2016, 19:30   #22  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
You need to learn that miracles don't happen. And be skeptic about halo removing in general. AFAIR, there has been no method to remove them that wasn't destructive to other parts of video. What you've got is a horrible multi-peaks ringing. No hope to fight it. Better to not cause it.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 19th September 2016, 19:31   #23  |  Link
Nevilne
"you can't expect this halo remover to remove these halos"
Nevilne is offline   Reply With Quote
Old 19th September 2016, 20:21   #24  |  Link
brucethemoose
Unfortunately, that's the raw NTSC DVD rip. Yeah, it's that bad .
And yeah, I know... but there is a compromise somewhere between the Vine settings I've tried and DeHalo_Alpha, I just haven't found it yet.
Old 19th September 2016, 22:44   #25  |  Link
Mystery Keeper
Beyond Kawaii
These multi-peaks? No, you can't. Narrow one peak halos - sure, you can. But expect it to screw up something else.
...desu!
Old 19th September 2016, 23:23   #26  |  Link
feisty2
I'm Siri
feisty2's Avatar
Have you tried to raise "h" and "radius" up like a bit insane, especially "h", like "h=24"
feisty2 is offline   Reply With Quote
Old 20th September 2016, 00:06   #27  |  Link
brucethemoose
Not yet, thanks.
But holy moly... now I'm running this:
 Vine.Dehalo(clip, radius=[8, 4], a=32, h=24, sharp=1.0, sigma=0.6, alpha=0.36, beta=32, cutoff=4, show=False)
And its taking like 8 seconds per 720x480 frame to encode. I'll get back to you when I get results.
Old 20th September 2016, 05:37   #28  |  Link
brucethemoose
24 is way too strong, this is 20 with radius 4,2 (with a straight spline36 scale for reference):
http://www.screenshotcomparison.com/comparison/185123
Look at the guy's eyes, in particular.
I'm messing with it now, and 12-16 is looking better... the higher order halos aren't completely gone, but I might be able to mask them with another filter now.
This is some great code though, thanks feisty2.
Old 20th September 2016, 05:49   #29  |  Link
feisty2
I'm Siri
feisty2's Avatar
Now I think a large "h" is not it, something like "h=8" might be enough already
You need to disable all mask stuff in Vine cuz the halos are roaming VERY far from the exact edges, pointless tryna "mask" them out
Old 20th September 2016, 05:51   #30  |  Link
feisty2
I'm Siri
feisty2's Avatar
I'll add such option(disable mask stuff) after college
Old 20th September 2016, 06:31   #31  |  Link
brucethemoose
Sounds good.
However, if I'm looking at it right, I think the mask is actually reaching WAY out to the halos as it should.
http://u.cubeupload.com/brucethemoos...phavpymask.png
I don't think disabling it would help. There are other scenes with much more intricate painted backgrounds, and it looks like the mask will help preserve those.
EDIT: I could be wrong though, maybe I'm misunderstanding what the mask does...
So for now, what parameters should I adjust for the mask?
Old 20th September 2016, 06:48   #32  |  Link
feisty2
I'm Siri
feisty2's Avatar
radius=[10, None], sigma=1.6, alpha=0.48 works on your first screenshot
I'm on cellphone right now so...
Old 21st September 2016, 03:20   #33  |  Link
brucethemoose
Sorry for not responding earlier, I went down the deinterlacing/IVTC rabbit hole.
What h value did you use?
Old 21st September 2016, 13:28   #34  |  Link
feisty2
I'm Siri
feisty2's Avatar
r5:
new parameter "masking"
Old 21st September 2016, 13:33   #35  |  Link
feisty2
I'm Siri
feisty2's Avatar
@brucethemoose
clp = Vine.Dehalo(clp, h=6, masking=False, cutoff=1, sharp=0.4)
clp = Vine.Dehalo(clp, h=4, masking=False, cutoff=1, sharp=0.6)
clp = Vine.Dehalo(clp, h=2, masking=False, cutoff=1, sharp=0.8)
Old 21st September 2016, 13:40   #36  |  Link
feisty2
I'm Siri
feisty2's Avatar
and of course you can go for a custom mask for this specific vid and protect soft features a bit more
Old 21st September 2016, 18:22   #37  |  Link
brucethemoose
Fantastic, thanks! I'm playing with this now, might upload some before/after screenshots/clips later to show Vine off, as those Avatar DVDs are a DeHalo torture test.
Old 22nd September 2016, 02:48   #38  |  Link
brucethemoose
@brucethemoose
Out of curiosity, why call Dehalo 3 times instead of just increasing h? Does it help with higher order halos or something?
Old 23rd September 2016, 22:22   #39  |  Link
brucethemoose
In certain material, Vine has trouble correctly detecting the actual edges:
Look at the edges of the cards here:
http://www.screenshotcomparison.com/comparison/185510
In that crack between the 2 black lines, it's so bad that the halos themselves are detected as edges, and it ends up blurring the actual edges. The mask and strength settings don't seem to affect that.
Feisty2, I know this is a live-action filter, but could you add an option that gives priority to black lines during edge detection? This would help oversharpened animation dramatically.
Old 24th September 2016, 04:43   #40  |  Link
feisty2
I'm Siri
feisty2's Avatar
there's no edge detection with "masking=False"
you do a halo/edge mask for your specific video on your own
