25th August 2021, 17:04 | #61 | Link |
Professional Code Monkey
Will be fixed in the next build.
25th August 2021, 20:40 | #62 | Link |
It's RC1 time!
Notable changes from test3:
Note that non-source filters that use nfMakeLinear (very few) still work poorly and will need to be manually updated.
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 25th August 2021 at 20:42. |
25th August 2021, 21:49 | #64 | Link | |
Extracting vsedit in the same dir used to work too.
25th August 2021, 23:42 | #65 | Link |
Using that latest API4 R 55 portable RC1 version with latest portable python 3.9 on windows 7, running VSPipe.exe I get:
The program can't start because api-ms-win-core-path-|1-1-0.dll is missing from computer. Try reinstalling the program to fix this problem. Do I need Visual Studio 2019 for portable setup? Last edited by _Al_; 26th August 2021 at 00:00. |
26th August 2021, 00:08 | #66 | Link | |
Useful n00b
26th August 2021, 00:19 | #67 | Link |
1) download https://www.python.org/ftp/python/3....mbed-amd64.zip
2) extract it to for example VS-R55-API4 3) download https://github.com/vapoursynth/vapou...55-API4-RC1.7z 4) extract contents of that archive into VS-R55-API4 (confirm overwrite of some files) 5) copy plugins into VS-R55-API4\vapoursynth64\plugins 6) if you want to add some importable scripts, copy them into VS-R55-API4 or edit python39._pth and add extra line with your scripts location (I'm using ./vs-scripts) 7) if you willing to use some preview application (VapourSynth Editor), there's https://github.com/YomikoR/VapourSyn...od-1-x86_64.7z which works with APIv4 Vapoursynth (extract contents into VS-R55-API4) I believe that's enough to get things working. |
26th August 2021, 00:24 | #68 | Link |
embedded + portable vapoursynth seems to work for me on simple scripts so far (using similar procedure as DJATOM) , but I have same installed python version as the embedded version and it doesn't work with the installed version - "Failed to initialize VSScript"
Is there anyway I can use installed python version with the portable vapoursynth version? |
26th August 2021, 02:23 | #69 | Link | |
VapourSynth-Editor-r19-mod-1 shows no error, preview ok Code:
import vapoursynth as vs core = vs.core clip = core.std.BlankClip(width=1920,height=1080,format=vs.YUV422P8, length=300, color=[16, 128, 128]) #clip = core.std.BlankClip(width=1920,height=1080,format=vs.YUV422P10, length=300, color=[64, 512, 512]) clip = core.std.AssumeFPS(clip, fpsnum=30000, fpsden=1001) clip = core.text.FrameNum(clip) #vs.set_option('alt_output', 1) #vs.set_option('alt_output', 2) clip.set_output() #vs.set_option('alt_output', 1) vs.set_option('alt_output', 2) Core R54 API R4.0 API R3.6 using avfs "PATH\python-3.9.6-embed-amd64\avfs" yuv422_alt1.vpy gives yv16 according to mediainfo (should be YUY2) "PATH\python-3.9.6-embed-amd64\avfs" yuv422_alt2.vpy gives yv16 according to mediainfo (should be UYVY) "PATH\python-3.9.6-embed-amd64\avfs" yuv422p10_alt1.vpy gives p210 according to mediainfo (should be v210) using vspipe to ffmpeg "PATH\python-3.9.6-embed-amd64\vspipe" --y4m yuv422_alt2.vpy - | ffmpeg -f yuv4mpegpipe -i - -an -f null NUL ffmpeg reports Y42B, yuv422p . Normally it should say UYVY , uyvy422 Last edited by poisondeathray; 26th August 2021 at 02:27. |
26th August 2021, 02:50 | #70 | Link | |
Useful n00b
26th August 2021, 03:32 | #72 | Link |
You don't have to do anything when done now
26th August 2021, 09:20 | #73 | Link |
This change in video format id comparison is getting too long?
// api3 if(cpVideoFormat.id == pfRGB24) {} // api4 uint32_t formatId = m_cpVSAPI->queryVideoFormatID(cpVideoFormat.colorFamily, cpVideoFormat.sampleType, cpVideoFormat.bitsPerSample, cpVideoFormat.subSamplingW, cpVideoFormat.subSamplingH, m_pCore); if(formatId == pfRGB24){} Code:
int formatIdFound = m_cpVSAPI->getVideoFormatByID(&cpVideoFormat, pfRGB24, m_pCore); if (formatIdFound != 0) {} Last edited by lansing; 26th August 2021 at 09:28. Reason: update |
26th August 2021, 09:51 | #74 | Link |
The field base enum in the VSConstants4.h is wrong
typedef enum VSFieldBased { VSC_FIELD_PROGRESSIVE = 0, VSC_FIELD_TOP = 1, VSC_FIELD_BOTTOM = 2 } VSFieldBased; |
26th August 2021, 12:08 | #75 | Link | |
26th August 2021, 12:12 | #76 | Link | |
26th August 2021, 14:16 | #77 | Link |
You're right Core R55 API R4.0 API R3.6 But with Core R55, ffmpeg still reports Y42B, yuv422p for the yuv422 alt2 script . Also, avfs now crashes when file is accessed, even a plain BlankClip script (without alt_output options) . It "mounts", but as soon as you touch or access the fake avi, it crashes no helpful error message Calling old avfs with same plain BlankClip script does not crash |
26th August 2021, 18:42 | #78 | Link |
In case anyone's wondering the part of the API in vsscript4.h is not considered stable. I predict that it will be rolled back closer to something along the lines of the old api.
26th August 2021, 21:21 | #80 | Link |
The closest thing is if you manually insert a cache and pass a bunch of arguments to it. But the arguments are quite different in api3 so even that's questionable.
