#721 | Link | |
Software Developer
![]() Join Date: Jun 2005
LameXP v4.05 Alpha-6
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st July 2012 at 00:17. |
#722 | Link | |
Software Developer
LameXP v4.05 Alpha-7
#723 | Link | ||
Software Developer
LameXP v4.05 Alpha-8
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st July 2012 at 22:59. |
#724 | Link | |
Software Developer
LameXP v4.05 Alpha-10
BTW: If you are looking for an Opus-capable player software, you may want to give foobar2000 v1.1.14 beta-1 a try ![]()
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 29th July 2012 at 16:08. |
#725 | Link | |
Software Developer
LameXP v4.05 Alpha-12
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 1st August 2012 at 22:04. |
#726 | Link |
Hey Mulder, I just want to let you know that your latest stable release has a weird bug when you encode to AAC. (At least from MP3). The output file contains both the AAC audio track AND the MP3 track, but they aren't listed as separate audio tracks like different audio languages are. They play at the same time and it is very strange.
If this is already known, then I'm sorry for the spam. Thanks for the awesome program I've been using LameXP for years. Edit: I installed one of the alpha builds and it doesn't have the issue. It's good enough for me, I was just letting you know of it. Last edited by hoboX10; 29th July 2012 at 23:54. |
#727 | Link |
Software Developer
hoboX10, LameXP certainly does not multiplex multiple audio streams into a single file. Also the (default) AAC encoder used by LameXP, Nero AAC, hasn't changed in years and won't do anything like that.
Thus I assume this is actually a playback issue. Your playback software probably assumes that the .MP4 file is a video and loads the .MP3 file as an additional audio track ![]() If you are 100% sure that this is NOT some playback issue, then please create a MediaInfo report (in "text" mode!) from the "problematic" MP4 file (as generated by LameXP) and send the report to me via PM. Furthermore you may want to post your LameXP log: Once the encoding process has finished, don't close the processing window, double-click on one of the items in the list and then copy the text...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 30th July 2012 at 01:17. |
#728 | Link | |
Software Developer
LameXP v4.05 Alpha-13
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th August 2012 at 15:45. |
#729 | Link | |
Software Developer
LameXP v4.05 Beta-1
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 7th August 2012 at 21:33. |
#730 | Link |
Life's clearer in 4K UHD
Well... I had a quick look on the forum but was unable to find a decoder filter for Opus. Can anyone oblige?
#731 | Link | |
Software Developer
I have put up a stand-alone download here: https://code.google.com/p/mulder/dow...2&q=Opus+Tools Of course the easiest way would be using LameXP to decode the Opus files ![]() And, as mentioned before, if you are looking for player software that handles Opus files directly, get the latest Foobar2000. Last but not least, an up-to-date Firefox will handle Opus via HTML 5 <audio> tag.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th August 2012 at 21:27. |
#732 | Link | |
![]() By-the-way... Have you tried muxing .opus files using MKVmerge GUI? It would not work for me!
#733 | Link |
Software Developer
Keep in mind that Opus is still pretty new and has just been standardized
![]() At this point, I don't know of any Opus-enabled players other than Foobar2000 and Firefox. But you can be sure Opus support will be added to VLC, MPlayer and friends soon (if not done yet). Also I would really be surprised if nobody writes a Winamp plug-in and a DirectShow decoder for Opus... [EDIT] As for your question about MKVmerge, I have no idea ![]() As far as I know, storing Opus streams in Matroska containers is supposed to work, but is the specification for that fixed yet? And if so, is it implemented in MKVmerge already?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th August 2012 at 23:44. |
#734 | Link | |
http://www.un4seen.com/forum/?topic=13870.0 And DirectShow players can use DC-Bass Source Mod for OPUS playback: http://reino.degeelebosch.nl |
#735 | Link | |
Software Developer
LameXP v4.05 Beta-2
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 13th August 2012 at 20:19. |
#736 | Link | |
From the changelog of MkvТоMp4 v0.221:
Could this be implemented in LameXP? Cheers manolito //Edit// Looks like oreons promised too much... qaac encoding does not work on my machine without QuickTime or iTunes Last edited by manolito; 8th August 2012 at 19:16. |
#737 | Link |
Software Developer
AFAIK, older versions of QAAC were accessing the Apple AAC encoder through QuickTime (or some component of it), thus an installation of QuickTime was inevitable.
However "since [version] 1.00, qaac directly uses CoreAudioToolbox.dll. Therefore, QuickTime installation is no more required. However, Apple Application Support is required" (source). I think that's all what oreons was referring to! Also note that you can install either iTunes, QuickTime or Safari in order to obtain the required Apple Application Support... QAAC probably will never work without CoreAudioToolbox.dll, for obvious reasons. And installing the Apple Application Support is the only way to get that DLL pus its dependencies. (BTW: I don't know if Apple offers the "AppleApplicationSupport.msi" as a stand-alone download, but you may extract it from the "QuickTimeInstaller.exe" via 7-Zip)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 9th August 2012 at 00:33. |
#738 | Link | |
Software Developer
LameXP v4.05 Beta-3
If you used any of the previous LameXP v4.05 Alpha/Beta versions, then it is highly recommended that you check your %TEMP% directory and clean it up manually, if required...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th August 2012 at 20:23. |
#739 | Link | |
qaac support
Now of course my question again if this could be implemented in LameXP. As far as I can see it only requires 4 DLLs in the program folder. I have no idea about dependencies, but MkvToMp4 comes without an installer, so it cannot be too hard... Cheers manolito |
#740 | Link |
Software Developer
Well, as said before, QAAC will unavoidably require the CoreAudioToolbox.dll, because that is where the Apple AAC encoder is implemented.
Whether you need to run the Apple Application Support installer to get CoreAudioToolbox working, that is a different question ![]() It probably is sufficient to just drop CoreAudioToolbox.dll plus its dependencies (I count at least eight more dependencies!) into the application directory or the System directory, so QAAC can find and load it. But, as we cannot redistribute CoreAudioToolbox.dll (and friends) for legal reasons, the users will have to download the Apple Application Support (or a product that contains it) from the Apple site anyway. And for most users it will be much easier to just let the installer do its job, instead of trying to extract the required DLL's from the setup package manually...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 16th August 2012 at 19:11. |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
