27th April 2008, 08:22 | #62 | Link |
Derek Prestegard IRL
Results for x264.exe v0.58.747 encoded 1442 frames, 58.29 fps, 3905.42 kb/s encoded 1442 frames, 58.67 fps, 3905.42 kb/s encoded 1442 frames, 58.53 fps, 3905.42 kb/s encoded 1442 frames, 58.28 fps, 3905.42 kb/s encoded 1442 frames, 16.41 fps, 3952.85 kb/s encoded 1442 frames, 16.55 fps, 3952.85 kb/s encoded 1442 frames, 16.51 fps, 3952.85 kb/s encoded 1442 frames, 16.50 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 62.41 fps, 3888.35 kb/s encoded 1442 frames, 54.01 fps, 3891.55 kb/s encoded 1442 frames, 62.30 fps, 3889.35 kb/s encoded 1442 frames, 62.48 fps, 3891.55 kb/s encoded 1442 frames, 18.35 fps, 3963.27 kb/s encoded 1442 frames, 18.44 fps, 3963.43 kb/s encoded 1442 frames, 18.45 fps, 3962.44 kb/s encoded 1442 frames, 18.39 fps, 3963.43 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3005.5 MHz (9.0 x 333.9 MHz) FID range 6.0x - 9.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 16 Command Rate 2T Memory Frequency 400.7 MHz (5:6) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 1.263 V Voltage sensor 0 1.30 Volts [0xA2] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 37°C (98°F) [0x25] (SYSTIN) Temperature sensor 1 50°C (121°F) [0x64] (CPUTIN) Temperature sensor 2 125°C (256°F) [0xF9] (AUXTIN) Temperature sensor 0 66°C (150°F) [0x22] (core #0) Temperature sensor 1 67°C (152°F) [0x21] (core #1) Temperature sensor 2 62°C (143°F) [0x26] (core #2) Temperature sensor 3 62°C (143°F) [0x26] (core #3) Temperature sensor 0 63°C (145°F) [0x3F] (GPU Core)
These are all my personal statements, not those of my employer :) |
20th May 2008, 09:27 | #64 | Link |
encoded 1442 frames, 56.97 fps, 3904.67 kb/s encoded 1442 frames, 56.79 fps, 3905.42 kb/s encoded 1442 frames, 56.79 fps, 3905.42 kb/s encoded 1442 frames, 56.90 fps, 3905.42 kb/s encoded 1442 frames, 17.38 fps, 3952.97 kb/s encoded 1442 frames, 17.37 fps, 3952.85 kb/s encoded 1442 frames, 17.31 fps, 3952.85 kb/s encoded 1442 frames, 17.28 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 60.80 fps, 3888.96 kb/s encoded 1442 frames, 60.32 fps, 3888.80 kb/s encoded 1442 frames, 60.32 fps, 3889.26 kb/s encoded 1442 frames, 60.36 fps, 3889.29 kb/s encoded 1442 frames, 19.43 fps, 3962.60 kb/s encoded 1442 frames, 19.46 fps, 3962.84 kb/s encoded 1442 frames, 19.42 fps, 3962.50 kb/s encoded 1442 frames, 19.44 fps, 3962.74 kb/s System Details -------------- Name Intel Xeon E5450 Codename Harpertown Specification Intel(R) Xeon(R) CPU E5450 @ 3.00GHz Core Stepping C0 Technology 45 nm Stock frequency 3000 MHz Core Speed 2992.9 MHz (9.0 x 332.5 MHz) FID range 6.0x - 9.0x Northbridge Intel 5000X rev. 12 Southbridge Intel 6321ESB rev. 09 Memory Frequency 332.5 MHz (1:1) Memory Type FB-DDR2 Memory Size 2044 MBytes Windows Version Microsoft Windows Server 2003 Standard Edition Service Pack 2 (Build 3790) max VID 1.213 V Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 771 LGA (platform ID = 6h) Temperature sensor 0 64°C (147°F) [0x29] (core #0) Temperature sensor 1 60°C (139°F) [0x2D] (core #1) Temperature sensor 2 53°C (127°F) [0x34] (core #2) Temperature sensor 3 49°C (120°F) [0x38] (core #3)
20th May 2008, 09:28 | #65 | Link |
encoded 1442 frames, 59.05 fps, 3904.94 kb/s encoded 1442 frames, 58.97 fps, 3904.94 kb/s encoded 1442 frames, 59.01 fps, 3904.94 kb/s encoded 1442 frames, 58.93 fps, 3904.94 kb/s encoded 1442 frames, 28.79 fps, 3974.08 kb/s encoded 1442 frames, 28.80 fps, 3974.08 kb/s encoded 1442 frames, 28.78 fps, 3974.08 kb/s encoded 1442 frames, 28.61 fps, 3974.08 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 59.23 fps, 3895.56 kb/s encoded 1442 frames, 59.46 fps, 3895.56 kb/s encoded 1442 frames, 59.39 fps, 3894.09 kb/s encoded 1442 frames, 59.01 fps, 3894.78 kb/s encoded 1442 frames, 32.23 fps, 3981.22 kb/s encoded 1442 frames, 32.29 fps, 3981.22 kb/s encoded 1442 frames, 32.30 fps, 3981.53 kb/s encoded 1442 frames, 32.27 fps, 3981.37 kb/s System Details -------------- Name Intel Xeon E5420 Name Intel Xeon E5420 Codename Harpertown Codename Harpertown Specification Intel(R) Xeon(R) CPU E5420 @ 2.50GHz Specification Intel(R) Xeon(R) CPU E5420 @ 2.50GHz Core Stepping C0 Core Stepping C0 Technology 45 nm Technology 45 nm Stock frequency 2500 MHz Stock frequency 2500 MHz Core Speed 2494.0 MHz (7.5 x 332.5 MHz) Core Speed 2494.0 MHz (7.5 x 332.5 MHz) FID range 6.0x - 7.5x FID range 6.0x - 7.5x Northbridge Intel 5000X rev. 12 Southbridge Intel 6321ESB rev. 09 Memory Frequency 332.5 MHz (1:1) Memory Type FB-DDR2 Memory Size 4092 MBytes Windows Version Microsoft Windows Server 2003 Standard Edition Service Pack 2 (Build 3790) max VID 1.225 V max VID 1.225 V Number of processors 2 Number of threads 8 Number of threads 4 (max 4) Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 771 LGA (platform ID = 6h) Package Socket 771 LGA (platform ID = 6h) Temperature sensor 0 42°C (107°F) [0x3F] (core #0) Temperature sensor 1 34°C (93°F) [0x47] (core #1) Temperature sensor 2 46°C (114°F) [0x3B] (core #2) Temperature sensor 3 33°C (91°F) [0x48] (core #3) Temperature sensor 0 52°C (125°F) [0x35] (core #0) Temperature sensor 1 50°C (121°F) [0x37] (core #1) Temperature sensor 2 54°C (129°F) [0x33] (core #2) Temperature sensor 3 54°C (129°F) [0x33] (core #3)
20th May 2008, 10:42 | #66 | Link |
encoded 1442 frames, 49.43 fps, 3905.42 kb/s encoded 1442 frames, 44.05 fps, 3905.42 kb/s encoded 1442 frames, 44.24 fps, 3905.42 kb/s encoded 1442 frames, 44.41 fps, 3905.42 kb/s encoded 1442 frames, 13.76 fps, 3952.85 kb/s encoded 1442 frames, 13.33 fps, 3952.85 kb/s encoded 1442 frames, 13.36 fps, 3952.85 kb/s encoded 1442 frames, 13.40 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 47.11 fps, 3887.61 kb/s encoded 1442 frames, 47.21 fps, 3889.14 kb/s encoded 1442 frames, 47.21 fps, 3889.39 kb/s encoded 1442 frames, 47.23 fps, 3886.55 kb/s encoded 1442 frames, 14.85 fps, 3963.21 kb/s encoded 1442 frames, 14.91 fps, 3962.73 kb/s encoded 1442 frames, 14.87 fps, 3963.57 kb/s encoded 1442 frames, 14.88 fps, 3963.72 kb/s System Details -------------- Name Intel Xeon 5160 Name Intel Xeon 5160 Codename Woodcrest Codename Woodcrest Specification Intel(R) Xeon(R) CPU 5160 @ 3.00GHz Specification Intel(R) Xeon(R) CPU 5160 @ 3.00GHz Core Stepping B2 Core Stepping B2 Technology 65 nm Technology 65 nm Stock frequency 3000 MHz Stock frequency 3000 MHz Core Speed 1980.7 MHz (6.0 x 330.1 MHz) Core Speed 2971.0 MHz (9.0 x 330.1 MHz) FID range 6.0x - 9.0x FID range 6.0x - 9.0x Northbridge Intel 5000V rev. 92 Southbridge Intel 6321ESB rev. 09 Memory Frequency 264.1 MHz (5:4) Memory Type FB-DDR2 Memory Size 1024 MBytes Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) max VID 1.325 V max VID 1.325 V Number of processors 2 Number of threads 4 Number of threads 2 (max 2) Number of threads 2 (max 2) L2 cache 4096 KBytes, 16-way set associative, 64-byte line size L2 cache 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 771 LGA (platform ID = 2h) Package Socket 771 LGA (platform ID = 2h) Temperature sensor 1 83°C (181°F) [0x2] (core #1) Temperature sensor 0 81°C (177°F) [0x4] (core #0) Temperature sensor 1 77°C (170°F) [0x8] (core #1)
20th May 2008, 15:11 | #67 | Link |
Turkey Machine
Goddamn that Woodcrest runs hot!
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
20th May 2008, 16:27 | #68 | Link |
Yeah, I guess either the sensor is borked, or the CPU will soon be (Different core speed on both CPUs seems strange too)
22nd May 2008, 08:07 | #70 | Link |
Mem timings & mem core speed are grayed in CPU-Z. Can I find that information somewhere else ?
22nd May 2008, 20:00 | #71 | Link |
@manao - I don't know of other utils that would work with your 5000 chipset.... just curiously, if you edit the cpuz.ini does it have a "=ON" for the sensor lines? If it does, beyond looking in the BIOS, I dunno
Here is what mine looks like for reference: Code:
[CPU-Z] TextFontName= TextFontSize=14 TextFontColor=000080 LabelFontName= LabelFontSize=14 PCI=ON MaxPCIBus=256 DMI=ON Sensor=ON SMBus=ON |
25th May 2008, 21:11 | #72 | Link | |
26th May 2008, 02:11 | #74 | Link |
heres my "old" QX6700.....
x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 65.50 fps, 3904.94 kb/s encoded 1442 frames, 66.63 fps, 3904.99 kb/s encoded 1442 frames, 68.46 fps, 3904.57 kb/s encoded 1442 frames, 67.96 fps, 3905.73 kb/s encoded 1442 frames, 18.61 fps, 3953.06 kb/s encoded 1442 frames, 19.43 fps, 3953.27 kb/s encoded 1442 frames, 19.33 fps, 3952.94 kb/s encoded 1442 frames, 19.36 fps, 3953.34 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 71.31 fps, 3889.12 kb/s encoded 1442 frames, 73.65 fps, 3888.84 kb/s encoded 1442 frames, 73.65 fps, 3888.18 kb/s encoded 1442 frames, 72.67 fps, 3887.67 kb/s encoded 1442 frames, 21.49 fps, 3962.65 kb/s encoded 1442 frames, 21.48 fps, 3961.68 kb/s encoded 1442 frames, 21.69 fps, 3962.90 kb/s encoded 1442 frames, 21.67 fps, 3963.30 kb/s System Details -------------- Name Intel Core 2 Extreme QX6700 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU @ 2.66GHz Core Stepping B3 Technology 65 nm Stock frequency 2666 MHz Core Speed 1920.2 MHz (6.0 x 320.0 MHz) <--- running at 11x multi = 3500mhz FID range 6.0x - 11.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 384.0 MHz (5:6) Memory Type DDR2 Memory Size 3328 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) max VID 1.350 V Voltage sensor 0 1.43 Volts [0xB3] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 52°C (125°F) [0x34] (SYSTIN) Temperature sensor 1 41°C (105°F) [0x52] (CPUTIN) Temperature sensor 2 125°C (256°F) [0xF9] (AUXTIN) Temperature sensor 0 57°C (134°F) [0x2B] (core #0) Temperature sensor 1 57°C (134°F) [0x2B] (core #1) Temperature sensor 2 51°C (123°F) [0x31] (core #2) Temperature sensor 3 55°C (130°F) [0x2D] (core #3) Temperature sensor 0 39°C (102°F) [0x27] (GPU Core) she still keeps up with the new quadcores out now... i edited the core speed as it was showing C1E speed not the true speed the bench ran at... |
26th May 2008, 15:02 | #76 | Link | |||
I didn't see any Xeon Nocona or Xeon Prestonia in the overview yet so here's a few results on those:
2x Xeon Nocona @ 3.00GHz (HyperThreading enabled): Quote:
27th May 2008, 11:42 | #78 | Link |
New mainboard, new CPU, so new results .
Results for x264.exe v0.58.747 encoded 1442 frames, 56.03 fps, 3905.42 kb/s encoded 1442 frames, 57.82 fps, 3905.42 kb/s encoded 1442 frames, 58.01 fps, 3905.42 kb/s encoded 1442 frames, 57.83 fps, 3905.42 kb/s encoded 1442 frames, 16.74 fps, 3952.85 kb/s encoded 1442 frames, 16.82 fps, 3952.85 kb/s encoded 1442 frames, 16.79 fps, 3952.85 kb/s encoded 1442 frames, 16.76 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 61.04 fps, 3890.76 kb/s encoded 1442 frames, 62.23 fps, 3891.55 kb/s encoded 1442 frames, 60.87 fps, 3889.34 kb/s encoded 1442 frames, 61.36 fps, 3889.14 kb/s encoded 1442 frames, 18.66 fps, 3962.96 kb/s encoded 1442 frames, 18.77 fps, 3963.43 kb/s encoded 1442 frames, 18.74 fps, 3962.63 kb/s encoded 1442 frames, 18.64 fps, 3962.81 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU @ 2.40GHz Core Stepping B3 Technology 65 nm Stock frequency 2400 MHz Core Speed 3105.0 MHz (9.0 x 345.0 MHz) FID range 6.0x - 9.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# 5.0 RAS# to CAS# 4 RAS# Precharge 6 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 431.3 MHz (4:5) Memory Type DDR2 Memory Size 3072 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Server 2003 Enterprise Edition Dodatek Service Pack 2 (Build 3790) max VID 1.300 V Voltage sensor 0 1.31 Volts [0x52] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 45°C (112°F) [0x2D] (TMPIN0) Temperature sensor 1 63°C (145°F) [0x3F] (TMPIN1) Temperature sensor 0 84°C (183°F) [0x10] (core #0) Temperature sensor 1 81°C (177°F) [0x13] (core #1) Temperature sensor 3 78°C (172°F) [0x16] (core #3) Temperature sensor 2 79°C (174°F) [0x15] (core #2) Temperature sensor 0 58°C (136°F) [0x3A] (GPU Core) |
27th May 2008, 19:43 | #79 | Link | |||
Another older model that wasn't in the list yet. I'll see if I can find some more funky systems like this
2x Xeon Irwindale @ 3.60GHz (HyperThreading enabled): Quote:
Found a few more.. results in progress.. Last edited by Platinum; 27th May 2008 at 20:35. |
