#101 | Link | |
QuickSync Decoder author
Is there a 1:1 relation between samples coming in and frames coming out? e.g. is every media sample a single frame, or a frame can be divided into an arbitrary number of samples. This will make mapping time stamps impossible.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
#102 | Link |
In theory, both is possible, to some extend.
In reality, VC1 and H264 are usually always one sample=one frame, MPEG2 might be split over multiple data samples.
#103 | Link |
New version released 0.14
New and improved version. Zip files contains installer documentation, please read.
Download version 0.14 alpha: 32 bit http://www.multiupload.com/LPX2JXB06S 64 bit http://www.multiupload.com/8H7ZPV5XKC Source code http://www.multiupload.com/AXET69LL3P Revision highlights: v1.14: * Created ffdshow installer. Installer will default to enabling the Intel QuickSync decoder on new installations. * More speed optimizations. CPU is at its lowest frequency during playback with very low utilization. 2-3% on desktop and 5-6% on mobile. Mobile lowest frequency is half of desktop (800/1600). * Fixed handling of interlaced content which is encoded as progressive frames. * More robust and faster codec initialization
#104 | Link |
Are you going to merge your code with official builds? I'm asking because there is zero movement at the moment in ffdshow
Only libav is currently being updated. That's all.
#105 | Link | |
![]() I'll contact clsid again and push things forward. BTW, did you try my build? It should improve Avisynth performance when ffdshow is used as a decoder.
#108 | Link |
Hi Eric,
I haven't tested your build yet, but here are a few questions: - How are multiple instances of the decoder handled? I assume the HW can only handle a certain amount of streams at once. Will ffdshow simply fail graph connection for instance N+1, will it fall back to software mode (libavcodec), or will it crash and burn? - This only work on Sandy Bridge, and future similar CPUs? - Does it work if a mobo doesn't use the integrated GPU? Or if disabled in BIOS? Or if no monitor is attached? I can give you SVN access if you want. Then you can commit it when deemed stable and also perform updates and fixes.
MPC-HC 2.6.3 |
#110 | Link | ||
Correct, that’s guarantied. It might work on small core processors in the future (Atom), no promises. The user has the option to use this decoder or not via the standard ffdshow config. Just like other decoders (e.g. wmv9). Quote:
DirectX will not enumerate the IGP if a screen is not connected to it (it enumerate only the displays). Current version needs to have either the IGP connected to a screen or have switchable graphics or Lucid Virtu is installed and configured to bind the media players to the IGP. A VGA dummy can also be used. I’m in the process of enabling the HW acceleration without the above hacks. That would be great! Please send me instructions by mail if there’s any kind of procedures I’m required to follow.
#111 | Link | |
Future HW might (or not) support these stream types. It would help if you pointed me to such streams for testing purposes, or to a guide on how to transcode to these formats.
#112 | Link |
Reading the news in AnandTech really raised my hopes but they were to quickly plunge after I read egur's full post.
Not to say this initiative isn't commendable, but what I (and the rest of the world) would like to see is a true open source port of the SDK available to all OSes. This would enable the ffdshow, mplayer, VLC, you name it guys to build both encoding and decoding code into their projects and really put QuickSync to good use. |
#113 | Link | |
You can find a 10b H264 file at this location: http://dl.dropbox.com/u/15890479/480p_H264.mkv Regards Ganesh |
#114 | Link | |
* Linux has a very basic driver. I'm not aware of a video acceleration API (like DXVA). * Mac OS X driver is developed by Apple not Intel (with Intel support of course and probably full disclosure of Windows driver code). Apple controls the driver API and functionality, because they own the OS (like Microsoft owns D3D & DXVA APIs). Making a cross platform video acceleration SDK without a proper VA API is probably possible but would require bypassing the DXVA API and communicating in an alternative way with the driver. This usually requires a consent from the OS vendor (Microsoft & Apple) - not an easy task. The best solution would be to have an open standard for video acceleration that would be accepted by all OS vendors (like OpenGL, OpenCL). I believe the media SDK will be ported to other OSes in the future, so my code will be a good start point for understanding how to utilize it. My only "Windows" specific code is dealing with the memory GPU allocations, but this can be abstracted by the SDK. Having an open source SDK is not really a must. The Intel Media SDK is free to use and you also have a large company backing it up. The SDK abstracts the HW enough so that the code is future proof.
#115 | Link |
Funny that you would say "VA API"
Linux has a API which is supported by Intel, its called simply "VA API". It was designed by Intel initially, but AFAIK you can get adapters to run hwaccel through VAAPI on other GPUs as well these days.
#116 | Link | |
#117 | Link | |
There's also initial encoding support through libva, but I haven't heard anyone outside Intel having tested it yet. Last edited by nm; 29th September 2011 at 14:09. |
#118 | Link | |
Send me a PM with your SourceForge username and I can give you commit rights.
MPC-HC 2.6.3 |
#119 | Link | |
#120 | Link |
This issue might be not easy to find egur, currently ffdshow-quicksync has a tendency to silently selfdestruct
after a lot of streams continuously loaded in MPC-HC it dies and MPC-HC falls @ the next stream then back to another Decoder ffdshow-quicksync wont load anymore after until MPC-HC is restarted it isn't a specific stream it seems already changing streams fast without unloading them can trigger this, like in MPC-HC drag & drop while another stream is still loaded.Another problem though here is MPC-HC cant cleanly unload dshow filter when a file is closed the filter is still acquired not sure though if that has something todo with ffdshow-quicksync currently braking after a while. Though maybe it's also a memory leak i didn't looked into that yet. http://www.mediafire.com/download.php?ri4sdpjlafxxrry <- hangs (@ the cat) when the lion scene should follow (with both lav splitter and mpc-hc). Btw the 4:2:2 Mpeg-2 Fallback already works perfectly in combination with Lav Video ![]() Only High10, High422 and X264 losless fail
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 1st October 2011 at 02:05. |
| Tags |
| ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player |
| Thread Tools | |
| Display Modes | |
