Old 10th February 2018, 05:45   #1  |  Link
hydra3333
how to use ffmpeg to encode to mp4-avc-HDR-4k
OK, call me stupid.
Googled for a couple of hours, found a plethora of semi-conflicting information, and am still not much clearer on what ffmpeg commandline switches to use to convert (re-encode) a 4K HDR webm video, eg vp9.2, (and other similar samples in various formats from across the web) into
an mp4 container as avc/HDR/4k, presmably profile high10 level 5.1
an mkv container as avc/HDR/4k, presmably profile high10 level 5.1
an mp4 container as hevc/HDR/4k
an mkv container as hevc/HDR/4k
equivalent in quality to the avc
I'd prefer to use ffmpeg rather than x264 and x265 if possible.
Any example commandlines and/or link(s) would be very greatly appreciated.
So far I've seem something like this
ffmpeg_10bit.exe -i <infile.i420.bt2020nc.yuv420p10le.webm> -input-depth 10 -c:a libopus -c:v libx265 -tag:v hvc1 -crf 15 -pix_fmt yuv420p10le -x265-params "colorprim=bt2020:transfer=smpte2084:colormatrix=bt2020nc" -f mp4 -y "outfile.mp4"
and this which I'm fairly sure isn't right
ffmpeg.exe -i <infile.i420.bt2020nc.yuv420p10le.webm> --input-depth 10 -c:a libopus -c:v libx264 --preset slow -crf 15 -no-open-gop -profile high10 -level:v 5.1 -level-idc 5.1 -pix_fmt yuv420p10le -colorprim bt2020 -colormatrix bt2020nc -transfer smpte-st-2084 -x264opts "" -movflags faststart  -f mp4 -y "output.mp4"
Old 10th February 2018, 10:16   #2  |  Link
Selur
Selur's Avatar
at least for x265 you will have to add master-display and max-cll to the command line as parameters
"colorprim=bt2020:transfer=smpte2084:colormatrix=bt2020nc:master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,10)"
and may be ':max-cll=0,0'
don't think there is an option in ffmpeg to passthrough these settings to libx265
Old 10th February 2018, 12:04   #3  |  Link
sneaker_ger
And don't simply copy them from Selur's example. You have to read them from the source. Try MediaInfo to show the values. If that doesn't work try mkvinfo for VP9/WebM, a stream analyzer like ffprobe or Zond for HEVC.
You may need to calculate the values. They are set (stored) differently than they appear in MediaInfo:
http://x265.readthedocs.io/en/defaul...master-display
https://matroska.org/technical/specs/index.html#Colour
HDR in H.264, albeit possible, is uncommon. I would not use it for lack of compatibility. I think x264 does not even implement the mastering display colour volume SEI yet. (You can flag the mkv container, though.)
Old 11th February 2018, 02:46   #4  |  Link
hydra3333
OK, thank you for the information !
I'd mistakenly thought h.264 10bit HDR was now "a thing", so I will avoid that and stick with h.265 HDR.
As you both suggest, I'll start looking into the meanings of master-display and colorprim and max-cll and read these docs
and at the info produced by MediaInfo, mkvinfo and ffprobe.
Thank you, now I have a useful place to start, a lot better than aimless wandering
Old 11th February 2018, 10:44   #5  |  Link
hydra3333
OK, ffprobe seems to show the most info.
From the ffprobe output below, these seem to be the most relevant items which can be "extracted" from an ffprobe output.
Although, I'm not sure where the 2 values for "max-cll=0,0" come from.
Further advice welcomed.
pix_fmt=yuv420p10le
color_range=tv
color_space=bt2020nc
color_transfer=smpte2084 (does this need to be transformed into "smpte-st-2084" ?)
color_primaries=bt2020
red_x=34000/50000  (discard eveything on and after the "/")
red_y=16000/50000  (discard eveything on and after the "/")
green_x=13248/50000 (discard eveything on and after the "/")
green_y=34500/50000 (discard eveything on and after the "/")
blue_x=7500/50000 (discard eveything on and after the "/")
blue_y=3000/50000 (discard eveything on and after the "/")
white_point_x=15634/50000 (discard eveything on and after the "/")
white_point_y=16450/50000 (discard eveything on and after the "/")
min_luminance=50/10000 (discard eveything on and after the "/")
max_luminance=10000000/10000 (discard eveything on and after the "/")
And then maybe plugged into ffmpeg's x265 "-x265-params" like this (not yet attempted)?
ffmpeg.exe
-input-depth 10
-pix_fmt %pix_fmt%
-i "G:\HDTV\0nvencc\vp9_2_HDR10_UHD_4K_Demo.webm"
-i input.vp9.2.webm -an
-c:v libx265 -preset slow -crf 15
-x265-params "colorprim=%color_primaries%
:transfer=%color_transfer%
:colormatrix=%color_space%
:master-display=G(%green_x%,%green_y%)B(%blue_x%,%blue_y%)R(%red_x%,%red_y%)WP(%white_point_x%,%white_point_y%)L(%max_luminance%,%min_luminance%)
:max-cll=0,0:hdr"
-profile:v main10 -level:v 5.1
-crf 18
-output-depth=10
-movflags faststart
-f mp4 -y output.mp4
Here's the ffprobe output to see if someone can point out where the "max-cll=0,0" values come from.
"C:\SOFTWARE\ffmpeg\0-homebuilt-x64\ffprobe.exe" -prefix -unit -pretty -show_streams -i "G:\HDTV\0nvencc\vp9_2_HDR10_UHD_4K_Demo.webm"
[STREAM]
index=0
codec_name=vp9
codec_long_name=Google VP9
profile=Profile 2
codec_type=video
codec_time_base=317/19001
codec_tag_string=[0][0][0][0]
codec_tag=0x0000
width=3840
height=2160
coded_width=3840
coded_height=2160
has_b_frames=0
sample_aspect_ratio=1:1
display_aspect_ratio=16:9
pix_fmt=yuv420p10le
level=-99
color_range=tv
chroma_location=unspecified
field_order=unknown
timecode=N/A
refs=1
id=N/A
r_frame_rate=19001/317
avg_frame_rate=19001/317
time_base=1/1000
start_pts=0
start_time=0:00:00.000000
duration_ts=N/A
duration=N/A
bit_rate=N/A
max_bit_rate=N/A
bits_per_raw_sample=N/A
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
DISPOSITION:default=1
DISPOSITION:dub=0
DISPOSITION:original=0
DISPOSITION:comment=0
DISPOSITION:lyrics=0
DISPOSITION:karaoke=0
DISPOSITION:forced=0
DISPOSITION:hearing_impaired=0
DISPOSITION:visual_impaired=0
DISPOSITION:clean_effects=0
DISPOSITION:attached_pic=0
DISPOSITION:timed_thumbnails=0
TAG:language=eng
[SIDE_DATA]
side_data_type=Mastering display metadata
red_x=34000/50000
red_y=16000/50000
green_x=13248/50000
green_y=34500/50000
blue_x=7500/50000
blue_y=3000/50000
[/SIDE_DATA]
[/STREAM]
ffprobe version N-89991-gdd5208aaf5 Copyright (c) 2007-2018 the FFmpeg developers
  built with gcc 7.3.0 (GCC)
  configuration: --arch=x86_64 --target-os=mingw32
--cross-prefix=/home/u/Desktop/ffmpeg-windows-build-helpers-withOpenCL-master/sandbox/cross_compilers/mingw-w64-x86_64/bin/x86_64-w64-mingw32-
--pkg-config=pkg-config
--pkg-config-flags=--static --enable-gray --enable-version3 --disable-debug --disable-doc --disable-htmlpages
--disable-manpages --disable-podpages --disable-txtpages --disable-w32threads
--enable-nvenc --enable-cuda --enable-cuvid --enable-d3d11va --enable-libsoxr
--enable-fontconfig --enable-libass --enable-libbluray
--enable-iconv --enable-libtwolame --enable-libzvbi --enable-libcaca --enable-libmodplug
--extra-libs=-lstdc++ --extra-libs=-lpng --extra-libs=-loleaut32 --enable-libmp3lame --enable-version3
--enable-zlib --enable-librtmp --enable-libvorbis --enable-libtheora --enable-libspeex
--enable-libopenjpeg --enable-gnutls --enable-libgsm --enable-libfreetype
--enable-libopus --enable-bzlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libvpx --enable-libilbc
--enable-libwavpack --enable-libwebp --enable-libgme --enable-dxva2 --enable-gray --enable-libopenh264 --enable-libmysofa --enable-libflite
--enable-lzma --enable-libsnappy --enable-libzimg --enable-libbs2b --enable-gmp
--enable-libfribidi --enable-cross-compile --enable-pic --extra-libs=-lpsapi
--extra-libs=-lspeexdsp --disable-schannel --extra-cflags=-DLIBTWOLAME_STATIC --extra-cflags=-DMODPLUG_STATIC --extra-cflags=-DCACA_STATIC
--enable-gpl --enable-avisynth --enable-frei0r --enable-filter=frei0r --enable-librubberband
--enable-libvidstab --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid
--enable-amf --enable-avresample --enable-libcdio --extra-cflags='-mtune=generic' --extra-cflags=-O3
--enable-static --disable-shared
--prefix=/home/u/Desktop/ffmpeg-windows-build-helpers-withOpenCL-master/sandbox/cross_compilers/mingw-w64-x86_64/x86_64-w64-mingw32
--enable-nonfree --enable-decklink --enable-libfdk-aac --enable-opencl --enable-runtime-cpudetect
--extra-libs=-lcrypt32 --extra-libs=-lshlwapi --extra-libs=-lstdc++ --extra-libs=-lass
--extra-libs=-lfontconfig --extra-libs=-lexpat --extra-libs=-lfribidi --extra-libs=-lfreetype --extra-libs=-lharfbuzz --extra-libs=-lbz2 --extra-libs=-llzma
--extra-libs=-liconv --extra-libs=-lcdio --extra-libs=-lcdio_paranoia --extra-libs=-lz
--extra-libs=-lpsapi --extra-libs=-lspeexdsp --extra-libs=-lgdi32 --extra-libs=-lwinmm
  libavutil      56.  7.100 / 56.  7.100
  libavcodec     58. 10.100 / 58. 10.100
  libavformat    58.  9.100 / 58.  9.100
  libavdevice    58.  1.100 / 58.  1.100
  libavfilter     7. 11.101 /  7. 11.101
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  0.101 /  5.  0.101
  libswresample   3.  0.101 /  3.  0.101
  libpostproc    55.  0.100 / 55.  0.100
Input #0, matroska,webm, from 'G:\HDTV\0nvencc\vp9_2_HDR10_UHD_4K_Demo.webm':
  Metadata:
    encoder         : google/video-file
  Duration: 00:03:17.61, start: 0.000000, bitrate: 16593 kb/s
    Stream #0:0(eng): Video: vp9 (Profile 2), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160, SAR 1:1 DAR 16:9, 59.94 fps, 59.94 tbr, 1k tbn, 1k tbc (default)
    Side data:
      Mastering Display Metadata, has_primaries:1 has_luminance:1 r(0.6800,0.3200) g(0.2650,0.6900) b(0.1500 0.0600) wp(0.3127, 0.3290) min_luminance=0.005000, max_luminance=1000.000000
edit: also wondering if the profile level needs to be 5.2 given it's 4k 60fps main10 HDR, athough it looks as if 5.1 would suffice ?
Last edited by hydra3333; 11th February 2018 at 10:51. Reason: also asked about profile level
Old 11th February 2018, 10:55   #6  |  Link
Selur
Selur's Avatar
Not each source has max-cll value flags set, your source probably hasn't.
In case it's present MediaInfo reports them as:
Maximum Content Light Level              : 1000 cd/m2
Maximum Frame-Average Light Level        : 400 cd/m2
not sure whether ffprobe reports these at all,...
Old 11th February 2018, 12:58   #7  |  Link
sneaker_ger
For me it's reported directly below the other values.
[SIDE_DATA]
red_x=34000/50000
red_y=16000/50000
green_x=13250/50000
green_y=34500/50000
blue_x=7500/50000
blue_y=3000/50000
white_point_x=15635/50000
min_luminance=1/10000
[/SIDE_DATA]
[SIDE_DATA]
side_data_type=Content light level metadata
max_content=1000
max_average=400
[/SIDE_DATA]
Try to update to latest ffmpeg (git).
Old 11th February 2018, 13:38   #8  |  Link
hydra3333
Thank you. ffprobe was from a build from git as of last night
mediainfo is the latest 17.12 and doesn't show it.
re-trying ffproble from latest git ...
edit: no, not shown anywhere
it must be this.
I wonder what would happen if I added ":max-cll=0,0"
Old 11th February 2018, 13:40   #9  |  Link
sneaker_ger
Then maybe the SEI simply isn't there as Selur suspected. Try different sample.
Old 11th February 2018, 13:52   #10  |  Link
Selur
Selur's Avatar
@sneaker_get: You are right, one has to use '-show_entries side_data' wo see the max_content/average info.
Old 11th February 2018, 14:24   #11  |  Link
hydra3333
it seems not to be there no matter what I try...
Ah. Another sample has it though ...
"C:\SOFTWARE\ffmpeg\0-homebuilt-x64\ffprobe.exe" -prefix -unit -show_streams -report -i "G:\HDTV\0nvencc\Shot_in_Real_HDR_Smpte_2084.webm"
[STREAM]
index=0
codec_name=vp9
profile=Profile 2
codec_type=video
codec_time_base=1/24
codec_tag=0x0000
width=3840
height=2160
coded_width=3840
coded_height=2160
has_b_frames=0
pix_fmt=yuv420p10le
level=-99
color_range=tv
field_order=unknown
timecode=N/A
refs=1
id=N/A
r_frame_rate=24/1
avg_frame_rate=24/1
time_base=1/1000
start_pts=0
start_time=0.000000 s
duration_ts=N/A
duration=N/A
bit_rate=N/A
max_bit_rate=N/A
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
DISPOSITION:dub=0
TAG:language=eng
[SIDE_DATA]
max_content=1550
max_average=520
[/SIDE_DATA]
[SIDE_DATA]
red_x=34000/50000
red_y=15998/50000
green_x=13247/50000
green_y=34498/50000
blue_x=7500/50000
blue_y=2999/50000
white_point_y=16448/50000
min_luminance=49/10000
max_luminance=15500000/10000
[/SIDE_DATA]
[/STREAM]
So ... the $64million question - what to assume and do when it's absent ?
Old 11th February 2018, 14:40   #12  |  Link
Selur
Selur's Avatar
I would probably stick with the default x265 uses (max-cll “1000,400”) or simply not set the value.
--hdr can be used to ensure that max-cll and max-fall values are always signaled (even if 0,0).
source: http://x265.readthedocs.io/en/defaul...notes.html#id8
Old 11th February 2018, 15:47   #13  |  Link
hydra3333
OK. This batch file will probably crack out the values I need and do something if I drag and drop a .webm file onto it.
@echo off
@setlocal ENABLEDELAYEDEXPANSION
@setlocal enableextensions
REM Drop a media file on this, eg a .webm file
set logfile=%~1.log
set ffprobe_inputfile=%~1.ffprobe.log
set outputmp4=%~1.h265.mp4
set nvencc_x64=C:\SOFTWARE\NVEncC\NVEncC64.exe
set ffmpeg_x64=C:\SOFTWARE\ffmpeg\0-homebuilt-x64\built_for_generic_opencl\x64_10bit\ffmpeg.exe
set ffprobe_x64=C:\SOFTWARE\ffmpeg\0-homebuilt-x64\built_for_generic_opencl\x64_10bit\ffprobe.exe
set mp4box_x64=C:\SOFTWARE\ffmpeg\0-homebuilt-x64\built_for_generic_opencl\x64_10bit\MP4Box.exe
set x264_x64=C:\SOFTWARE\ffmpeg\0-homebuilt-x64\built_for_generic_opencl\x64_10bit\x264.exe
set x265_x64=C:\SOFTWARE\ffmpeg\0-homebuilt-x64\built_for_generic_opencl\x64_10bit\x265.exe
set mediainfo_x64=c:\software\mediainfo\mediainfo.exe
set mkvinfo_x64=C:\SOFTWARE\mkvtoolnix\mkvinfo.exe
set muxer_x64=C:\SOFTWARE\ffmpeg\0-homebuilt-x64\muxer.exe
set remuxer_x64=C:\SOFTWARE\ffmpeg\0-homebuilt-x64\remuxer.exe
set rtmpdump_x64=C:\SOFTWARE\ffmpeg\0-homebuilt-x64\rtmpdump.exe
REM probe the file characteristics
if exist "%logfile%" del "%logfile%"
if exist "%ffprobe_inputfile%" del "%ffprobe_inputfile%"
@echo on
"%ffprobe_x64%" -prefix -unit -show_streams -report -i "%~1" > "%ffprobe_inputfile%" 2>&1
@echo off
REM get the characteristics we are interested in into DOS variables
@echo off
REM set defaults first
set vmax_average=1000"
set vmax_content=400"
set vwidth=
set vheight=
set vcoded_width=
set vcoded_height=
set vhas_b_frames=
set vsample_aspect_ratio=
set vdisplay_aspect_ratio=
set vpix_fmt=
set vlevel=
set vcolor_range=
set vcolor_space=
set vcolor_transfer=
set vcolor_primaries=
set vr_frame_rate=
set vavg_frame_rate=
set vside_data_type=
set vmax_content=
set vmax_average=
set vred_x=
set vred_y=
set vgreen_x=
set vgreen_y=
set vblue_x=
set vblue_y=
set vwhite_point_x=
set vwhite_point_y=
set vmin_luminance=
set vmax_luminance=
@echo off
for /f "tokens=1,2 delims==" %%a in (' find "=" ^< "%ffprobe_inputfile%" ') do (
   set "var="
   for %%c in (%%~a) do set "var=!var!,%%~c"
   set var=!var:~1!
   set "val="
   for %%d in (%%~b) do set "val=!val!,%%~d"
   set val=!val:~1!
   REM @echo on
   REM echo .!var!.=.!val!.
   IF "!var!" == "width" set v!var!=!val!
   IF "!var!" == "height" set v!var!=!val!
   IF "!var!" == "coded_width" set v!var!=!val!
   IF "!var!" == "coded_height" set v!var!=!val!
   IF "!var!" == "has_b_frames" set v!var!=!val!
   IF "!var!" == "sample_aspect_ratio" set v!var!=!val!
   IF "!var!" == "display_aspect_ratio" set v!var!=!val!
   IF "!var!" == "pix_fmt" set v!var!=!val!
   IF "!var!" == "level" set v!var!=!val!
   IF "!var!" == "color_range" set v!var!=!val!
   IF "!var!" == "color_space" set v!var!=!val!
   IF "!var!" == "color_transfer" set v!var!=!val!
   IF "!var!" == "color_primaries" set v!var!=!val!
   IF "!var!" == "r_frame_rate" set v!var!=!val!
   IF "!var!" == "avg_frame_rate" set v!var!=!val!
   IF "!var!" == "max_content" set v!var!=!val!
   IF "!var!" == "max_average" set v!var!=!val!
   IF "!var!" == "side_data_type" set v!var!=!val!
   IF "!var!" == "red_x" set v!var!=!val!
   IF "!var!" == "red_y" set v!var!=!val!
   IF "!var!" == "green_x" set v!var!=!val!
   IF "!var!" == "green_y" set v!var!=!val!
   IF "!var!" == "blue_x" set v!var!=!val!
   IF "!var!" == "blue_y" set v!var!=!val!
   IF "!var!" == "white_point_x" set v!var!=!val!
   IF "!var!" == "white_point_y" set v!var!=!val!
   IF "!var!" == "min_luminance" set v!var!=!val!
   IF "!var!" == "max_luminance" set v!var!=!val!
   REM @echo off
REM split off trailing "/" etc from some of them
for /f "tokens=1,2 delims=/" %%a in ("%vwidth%") do (set vwidth=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vheight%") do (set vheight=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vcoded_width%") do (set vcoded_width=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vcoded_height%") do (set vcoded_height=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vhas_b_frames%") do (set vhas_b_frames=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vsample_aspect_ratio%") do (set vsample_aspect_ratio=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vdisplay_aspect_ratio%") do (set vdisplay_aspect_ratio=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vpix_fmt%") do (set vpix_fmt=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vlevel%") do (set vlevel=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vcolor_range%") do (set vcolor_range=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vcolor_space%") do (set vcolor_space=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vcolor_transfer%") do (set vcolor_transfer=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vcolor_primaries%") do (set vcolor_primaries=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vr_frame_rate%") do (set vr_frame_rate=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vavg_frame_rate%") do (set vavg_frame_rate=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vmax_content%") do (set vmax_content=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vmax_average%") do (set vmax_average=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vside_data_type%") do (set vside_data_type=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vred_x%") do (set vred_x=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vred_y%") do (set vred_y=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vgreen_x%") do (set vgreen_x=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vgreen_y%") do (set vgreen_y=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vblue_x%") do (set vblue_x=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vblue_y%") do (set vblue_y=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vwhite_point_x%") do (set vwhite_point_x=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vwhite_point_y%") do (set vwhite_point_y=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vmin_luminance%") do (set vmin_luminance=%%a)
for /f "tokens=1,2 delims=/" %%a in ("%vmax_luminance%") do (set vmax_luminance=%%a)
REM not transforms
IF /I "%vcolor_range%" == "tv" set vcolor_range=limited
IF /I NOT "%vcolor_range%" == "limited" set vcolor_range=full
REM
echo vwidth=%vwidth%
echo vheight=%vheight%
echo vcoded_width=%vcoded_width%
echo vcoded_height=%vcoded_height%
echo vhas_b_frames=%vhas_b_frames%
echo vsample_aspect_ratio=%vsample_aspect_ratio%
echo vdisplay_aspect_ratio=%vdisplay_aspect_ratio%
echo vpix_fmt=%vpix_fmt%
echo vlevel=%vlevel%
echo vcolor_range=%vcolor_range%
echo vcolor_space=%vcolor_space%
echo vcolor_transfer=%vcolor_transfer%
echo vcolor_primaries=%vcolor_primaries%
echo vr_frame_rate=%vr_frame_rate%
echo vavg_frame_rate=%vavg_frame_rate%
echo vmax_content=%vmax_content%
echo vmax_average=%vmax_average%
echo vside_data_type=%vside_data_type%
echo vred_x=%vred_x%
echo vred_y=%vred_y%
echo vgreen_x=%vgreen_x%
echo vgreen_y=%vgreen_y%
echo vblue_x=%vblue_x%
echo vblue_y=%vblue_y%
echo vwhite_point_x=%vwhite_point_x%
echo vwhite_point_y=%vwhite_point_y%
echo vmin_luminance=%vmin_luminance%
echo vmax_luminance=%vmax_luminance%
rem
@ECHO ON
"%ffmpeg_x64%" -hide_banner -i "%~1" -an -c:v libx265 -pix_fmt "%vpix_fmt%" -preset ultrafast -x265-params "profile=main10:level-idc=5.1:crf=15:no-open-gop=1:aq-mode=1:range=%vcolor_range%:colorprim=%vcolor_primaries%:transfer=%vcolor_transfer%:colormatrix=%vcolor_space%:master-display=G(%vgreen_x%,%vgreen_y%)B(%vblue_x%,%blue_y%)R(%vred_x%,%vred_y%)WP(%vwhite_point_x%,%vwhite_point_y%)L(%vmax_luminance%,%vmin_luminance%):max-cll=%vmax_content%,%vmax_average%:hdr" -profile:v main10 -level:v 5.1 -crf 15 -movflags faststart -f mp4 -y "%outputmp4%"
"%ffprobe_x64%" -prefix -unit -show_streams -report -i "%outputmp4%" > "%outputmp4%.ffprobe.log" 2>&1
pause
exit
OK, now worth a try I guess.
PS appreciate the links.
Old 13th February 2018, 14:37   #14  |  Link
hydra3333
Well, so much for that. ffprobe on the resulting mp4 said
pix_fmt=yuv420p10le
level=150
color_range=tv
color_space=unknown
color_transfer=unknown
color_primaries=unknown
whilst the original .webm said
pix_fmt=yuv420p10le
level=-99
color_range=tv
I guess I'll need to look at the ffmpeg commandline to see what options go with codec libx265
Old 13th February 2018, 18:07   #15  |  Link
sneaker_ger
Also with
-x265-params "colorprim=9:transfer=16:colormatrix=9" (etc.)
Old 14th February 2018, 11:03   #16  |  Link
hydra3333
Thank you. I got a tad "brute forcey" with it and this seemed to work, transferring the input file (eg vp9.2) 4k/HDR 10-bit colour characteristics over to the output file when transcoding into h.265 ...
Its a slow as a wet whistle even with ultrafast preset
@echo off
set logfile=%~1.log
set outputwebm=%~1.h265.webm
@echo on
@echo off
@echo off
set vwidth=
set vheight=
set vcoded_width=
set vcoded_height=
set vhas_b_frames=
set vpix_fmt=
set vlevel=
set vcolor_range=
set vcolor_space=
set vr_frame_rate=
set vmax_content=
set vmax_average=
set vred_x=
set vred_y=
set vgreen_x=
set vgreen_y=
set vblue_x=
set vblue_y=
set vwhite_point_x=
set vwhite_point_y=
set vmin_luminance=
set vmax_luminance=
@echo off
   set "var="
   set var=!var:~1!
   set "val="
   set val=!val:~1!
   REM @echo on
   REM @echo off
REM not transforms
REM IF /I "%vcolor_range%" == "tv" set vcolor_range=limited
REM IF /I NOT "%vcolor_range%" == "limited" set vcolor_range=full
REM
rem
@ECHO ON
set ffpreset=medium
"%ffmpeg_x64%" -hide_banner -i "%~1" -an -c:v libx265 -pix_fmt "%vpix_fmt%" -preset %ffpreset% -color_trc %vcolor_transfer% -color_primaries %vcolor_primaries% -colorspace %vcolor_space% -color_range %vcolor_range% -x265-params "profile=main10:level-idc=5.1:crf=15:no-open-gop=1:aq-mode=1:range=%vcolor_range%:colorprim=%vcolor_primaries%:transfer=%vcolor_transfer%:colormatrix=%vcolor_space%:master-display=G(%vgreen_x%,%vgreen_y%)B(%vblue_x%,%blue_y%)R(%vred_x%,%vred_y%)WP(%vwhite_point_x%,%vwhite_point_y%)L(%vmax_luminance%,%vmin_luminance%):max-cll=%vmax_content%,%vmax_average%:hdr" -profile:v main10 -level:v 5.1 -crf 15 -movflags faststart -f mp4 -y "%outputwebm%"
"%ffprobe_x64%" -prefix -unit -show_streams -report -i "%outputwebm%" > "%outputwebm%.ffprobe.log" 2>&1
"%ffmpeg_x64%" -hide_banner -i "%~1" -an -c:v libx265 -pix_fmt "%vpix_fmt%" -preset %ffpreset% -color_trc %vcolor_transfer% -color_primaries %vcolor_primaries% -colorspace %vcolor_space% -color_range %vcolor_range% -x265-params "profile=main10:level-idc=5.1:crf=15:no-open-gop=1:aq-mode=1:range=%vcolor_range%:colorprim=%vcolor_primaries%:transfer=%vcolor_transfer%:colormatrix=%vcolor_space%:master-display=G(%vgreen_x%,%vgreen_y%)B(%vblue_x%,%blue_y%)R(%vred_x%,%vred_y%)WP(%vwhite_point_x%,%vwhite_point_y%)L(%vmax_luminance%,%vmin_luminance%):max-cll=%vmax_content%,%vmax_average%:hdr" -profile:v main10 -level:v 5.1 -crf 15 -movflags faststart -f mp4 -y "%outputmp4%"
pause
exit
Old 16th February 2018, 11:40   #17  |  Link
hydra3333
Seeking advice about the error below piping 4k hdr from ffmpeg.exe into x265.exe (where the video characteristics are not known in advance, they are deduced from parsing output from ffprobe).
G:\HDTV\0nvencc\hdr>"C:\SOFTWARE\ffmpeg\0-homebuilt-x64\built_for_generic_opencl\x64_10bit\ffmpeg.exe" -i "G:\HDTV\0nvencc\hdr\3.Real_4K_HDR_60fps_-_Wipe_of_SDR_vs_HDR_UHD_Chromecast_Ultra.webm" -an -strict -1 -pix_fmt yuv420p10le -f yuv4mpegpipe -   |
"C:\SOFTWARE\ffmpeg\0-homebuilt-x64\built_for_generic_opencl\x64_10bit\x265.exe" --input - --y4m --output "G:\HDTV\0nvencc\hdr\3.Real_4K_HDR_60fps_-_Wipe_of_SDR_vs_HDR_UHD_Chromecast_Ultra.webm.h265" --preset medium  --output-depth 10 --profile main10 --level-idc 5.1 --open-gop --crf 18 --crf-min 5 --crf-max 40 --aq-mode 1 --range tv --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(13247,34499)B(7500,2999)R(34000,15999)WP(15634,16449)L(40000000,99)" --max-cll="4000,300" --hdr --info --hrd   1>>"G:\HDTV\0nvencc\hdr\3.Real_4K_HDR_60fps_-_Wipe_of_SDR_vs_HDR_UHD_Chromecast_Ultra.webm.log" 2>&1
ffmpeg version N-89991-gdd5208aaf5 Copyright (c) 2000-2018 the FFmpeg developers
  configuration: <snip too long>
Input #0, matroska,webm, from 'G:\HDTV\0nvencc\hdr\3.Real_4K_HDR_60fps_-_Wipe_of_SDR_vs_HDR_UHD_Chromecast_Ultra.webm':
  Metadata:
    encoder         : google
  Duration: 00:02:36.06, start: 0.000000, bitrate: 16895 kb/s
    Side data:
      Content Light Level Metadata, MaxCLL=4000, MaxFALL=300
      Mastering Display Metadata, has_primaries:1 has_luminance:1 r(0.6800,0.3200) g(0.2649,0.6900) b(0.1500 0.0600) wp(0.3127, 0.3290) min_luminance=0.009900, max_luminance=4000.000000
Stream mapping:
  Stream #0:0 -> #0:0 (vp9 (native) -> wrapped_avframe (native))
Press [q] to stop, [?] for help
[yuv4mpegpipe @ 000001b3a4a0cf40] Warning: generating non standard YUV stream. Mjpegtools will not work.
Output #0, yuv4mpegpipe, to 'pipe:':
  Metadata:
    encoder         : Lavf58.9.100
    Stream #0:0(eng): Video: wrapped_avframe, yuv420p10le, 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, 200 kb/s, 59.94 fps, 59.94 tbn, 59.94 tbc (default)
    Metadata:
      encoder         : Lavc58.10.100 wrapped_avframe
    Side data:
av_interleaved_write_frame(): Invalid argument
Error writing trailer of pipe:: Invalid argument
frame=    1 fps=0.0 q=-0.0 Lsize=   24300kB time=00:00:00.01 bitrate=11932275.5kbits/s speed=0.17x
video:1kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 4642301.000000%
Conversion failed!
Old 16th February 2018, 13:49   #18  |  Link
sneaker_ger
--range <full|limited>
Please read the log next time.
Old 16th February 2018, 17:57   #19  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
you have --max-cll="4000,300"
shouldn't it be --max-cll "4000,300" ? without the equal sign?
Old 17th February 2018, 01:25   #20  |  Link
hydra3333
Yes. Thank you both. Serves me right for tinkering with 2 different tools at the same time with different commandlines
