1st March 2005, 23:33 | #2021 | Link |
I dunno if Gabest will ever read this, or if anyone else would ever implement it, but I have a feature request regardless.
It would be great if there were a place where you could set the size of a playback buffer. MPC would render frames into this buffer as fast as it possibly can, trying to keep the buffer full at all times, then they would simply be pulled from the buffer and displayed as necessary. Also it would fill the buffer immediately upon loading or seeking in a file, and begin playing once the buffer is filled. Theoretically, this would greatly improve performance for videos that cant normally be played back without dropping frames. In practice, I dont know if this would really work, as im not a programmer. Seems like it would though. It really sucks when you cant watch a video without reencoding it because your processor isnt fast enough |
2nd March 2005, 11:07 | #2022 | Link | |
https://sourceforge.net/tracker/inde...03&atid=565649 Last edited by spectra; 2nd March 2005 at 11:16. |
2nd March 2005, 11:32 | #2023 | Link | |
Seriously, the time to write and debug such an optimization, which is easier said than done, far exceeds the cost of a new mobo and CPU.
Reclusive fart. Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers |
2nd March 2005, 13:08 | #2024 | Link | |
Video card could have something to do with this as well. Last edited by fewtch; 2nd March 2005 at 13:13. |
2nd March 2005, 17:29 | #2026 | Link | ||
2nd March 2005, 19:30 | #2028 | Link | |
Life's clearer in 4K UHD
Re: full screen doesn't work
Shame there's no support for reading Nero's subtitles in .MP4... Maybe next time! Cheers
2nd March 2005, 19:32 | #2029 | Link | |
My pc doesnt have much trouble playing most normal HD resolution content encoded with standard xvid settings. However, if there is particularly high motion, there would be some definate jerkiness, or especially if I decided to encode with CPU guzzling features like Qpel. I haven't messed around with H.264, but I would assume that it requires more horsepower than xvid to play back. With todays cpus hitting a barrier in clock speed, all of this factors into a need for more efficient playback. |
3rd March 2005, 02:17 | #2030 | Link | |
李姗倩 Lǐ Shān Qiàn
3rd March 2005, 03:24 | #2031 | Link |
Well if you recall a few pages back I updated the DX SDK used and the filesize dropped. Guess that could be it?
My 03.03 build as far as I can tell is basically the same as the offical 6.8.4.3. The changes to the cvs were made after, but they seem to be included in the sf build. Oh yeah, libfaad2 and libdirac are still newer in mine. Oh yeah, there were also some linkage settings that weren't enabled by default that I enabled which result in a slightly smaller filesize. Something about discarding refs.... not at home right now so I can't check. |
4th March 2005, 10:32 | #2034 | Link | |
gone
Re: Re: full screen doesn't work
4th March 2005, 11:30 | #2035 | Link | |
Sufficed to say, MPC is not the "lite" little media player it once was... maybe it's time it had it's own set of of optional Mpeg4 and .MP4 filters! Cheers
4th March 2005, 12:08 | #2036 | Link |
I installed the latest version of MPC and the lock back buffer option seems to have solved the tearing problem in VMR9 renderless mode. It doesn't work very well with the interlaced clips I have tested though. I tried a 1920*1080i mpeg2 clip with three diffenrent mpeg2 decoders and the deinterlacing didn't work with any of them. This is in VMR9 renderless mode. I also get a thick white line at the bottom of the picture.
4th March 2005, 14:25 | #2037 | Link | |
e.g. in Haali's Matroska parser you can manually define the Input buffer size. Cu
I 'm ripping waves!...nothing else! \m/ |
4th March 2005, 14:42 | #2038 | Link | |
retired
4th March 2005, 14:43 | #2039 | Link |
this can be done on the connection between renderer and output of decoder. I think Crystal Player (forgot name) does it; and it works well for cutting down player CPU requirements by about 30%. Fortunately most recent CPUs are nowadays quite fast - and if you need speed over anything, try vlc or mplayer - they both have MUCH lower CPU requirements and are quite usable. Unfortunately for me, no SSA/ASS support...
media player classic |
