6th May 2010, 22:31 | #21 | Link |
Remove it with Unlocker tool. Then add the new file.
Or if you would disable the thumbnailing in Haali options then the file will should not be in use anymore after a reboot. That would allow you to replace it as well. Or reboot and just don't visit any folder with videos inside.
MPC-HC 2.2.1 |
8th May 2010, 20:15 | #22 | Link |
契約者
Hi. I'm not sure if this is issue with splitter or maybe this have something to do with divx tech preview but I decided to post here first.
I'm using latest haali splitter on win7 32bit. When I have some linked mkv files, they work as they should but after accessing them, they become locked by explorer.exe and can't be deleted or modified so I need to use unlocker on them. Can anyone confirm? |
18th May 2010, 09:23 | #24 | Link |
I'm not sure if this has already been reported but Haali will not load a MKV with more than a specified number of tracks. I have a video with 43 tracks (40 subs) and it won't load. MPC-HC's splitter works, however.
Here's a sample: http://www.mediafire.com/?jowimwy4rkg Last edited by jasonwc; 18th May 2010 at 09:27. |
18th May 2010, 12:30 | #25 | Link |
The max that Haali supports is 32 if I remember correctly.
MPC-HC 2.2.1 |
18th May 2010, 22:18 | #26 | Link | |
18th May 2010, 23:33 | #28 | Link |
BTW i believe i should repeat this comparison also on this thread:
http://forum.doom9.org/showthread.ph...97#post1382497 Here are the mkv samples: DTSHD-MA: http://www.mediafire.com/?tmufzougmjt THD: http://www.mediafire.com/?5rjhgj1wyzk (includes only thd not ac3 core) |
19th May 2010, 23:43 | #29 | Link |
new haali fixes vc-1 in transport stream
http://haali.su/mkv/
20th May 2010, 05:58 | #31 | Link | |
The Mask Developer of The FilmMachine An easy to use, wizard-like, AVI/MP4/MOV/RMVB/MKV to DVD conversion utility |
23rd May 2010, 23:48 | #33 | Link | |
27th May 2010, 18:03 | #34 | Link |
The splitter seems to not link matroska files if opened using AviSynth or Direct264. (see this thread.)
30th May 2010, 12:08 | #35 | Link |
So these two issues are still present in Version 1.10.175.0 (19/05/2010)? If so, I still can't use as I don't want Haali to be my avi splitter...
(Installer) The installer enables all splitters regardless of what's been chosen during setup. (Installer) The uninstaller deletes the files without unregistering them first. Last edited by andybkma; 30th May 2010 at 12:20. |
1st June 2010, 03:03 | #37 | Link | |
When i disabled some options while installing, i could easily switch to Haali or Gabest in MPC-HC. I think i should go back to previous version since i haven't seen any progress in the latest Haali. Or maybe i'm wrong. Last edited by rica; 1st June 2010 at 03:27. |
1st June 2010, 23:12 | #38 | Link |
Anyone notice the issue where HMS causes corruption while splitting M2TS files? I've seen it happen twice now on totally different systems while encoding with x264. I can definitely rule out x264 because the corruption is not aligned to macroblocks. The only thing the two systems have in common is that both were updated to the latest Haali Media Splitter.
Examples screenshots after encoding: http://stfcc.org/pics/i/9db2a8e99c32...570ce345f1.png & http://stfcc.org/pics/i/be6efb42e598...22912fd10e.png Example encode: http://stfcc.org/misc/x264.r1602.mkv (disregard filename) I tried to narrow it down with Dark Shikari but the only thing that we could establish is that it wasn't x264, though it only seemed to happen with certain x264 settings. Time to roll back to the only good version.. again. |
6th June 2010, 11:56 | #39 | Link |
I have winxp 64bit edition, and Im having real trouble getting the shell extension in windows explorer part to work correctly, i have tried all of the following versions: 1.9.42.1, 1.9.63.13, and even the latest version, is shell extension completely gone on these versions?
1.9.42.1 worked fine with shell extension in winxp 32 bit edition, but on the 64bit edition it just doesnt seem to work, is there any manual way or workaround to get it working properly? |
10th June 2010, 15:52 | #40 | Link |
Haali's installer forgets to add this to registry for .webm. Without that you won't be able to open .webm via DirectShowSource()
[HKEY_CLASSES_ROOT\Wow6432Node\Media Type\Extensions\.webm] "Source Filter"="{55DA30FC-F16B-49FC-BAA5-AE59FC65F82D}" Code:
[HKEY_CLASSES_ROOT\Media Type\Extensions\.webm] "Source Filter"="{55DA30FC-F16B-49FC-BAA5-AE59FC65F82D}"
