16th June 2010, 17:20 | #1881 | Link |
Same result with 2.9.9 (the newest old version I have kicking around). I'll send him an email and bring this to his attention. Thanks again for your help!
16th June 2010, 17:27 | #1882 | Link | |
http://www.videohelp.com/tools/MKVto...sions#download
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
16th June 2010, 17:41 | #1883 | Link |
Thanks! I'll grab the latest 3.x version but I suspect it won't change much. 2.9.9 had the exact same problem. I've sent an email to Mosu to see if he has time to look at this issue. I know it affects a lot of people because I've seen various posts the last few months in both ffdshow threads and all attributed the issue to Haali. It's possible that it's a Haali issue but where it works with MakeMKV output I think it warrants a closer look. I'm really hoping this problem can be found and squashed as it'd be very beneficial to everyone.
16th June 2010, 17:44 | #1884 | Link |
MKVToolNix author
You can download all recent releases from http://www.bunkus.org/videotools/mkvtoolnix/win32/ and even older ones from the "old" subdirectory.
Then: I don't have the means to play back DTS-HD, and I don't have time to look into playback issues at the moment. Especially if everything's pointing to Haali's splitter. Please contact him for support.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
16th June 2010, 18:00 | #1886 | Link | |
http://forum.doom9.org/showthread.ph...81#post1405881
16th June 2010, 18:09 | #1887 | Link | |
16th June 2010, 18:22 | #1888 | Link | |
16th June 2010, 18:30 | #1889 | Link |
I honestly don't know. I sent him an email so we have to wait and see what he says. For myself I'll probably just redo the DTS-HD MA MKV's I'm having issues with using MakeMKV from my originals and call it good. Time consuming for sure, but, at least I know that works. That doesn't help everyone else, though, so, we'll see what happens. I'm also really concerned that Haali isn't splitting TS or M2TS files on my machine. I've got it set up in both 32 bit land using WMP and 64 bit land using MPC-HC. Neither of them play any audio or attempt to load Haali at all when I play a TS or M2TS file. This is not a good thing IMO.
16th June 2010, 23:43 | #1890 | Link |
I can confirm SamuriHL's findings. Haali + MakeMKV mkv + FFDShow plays fine with Bitstreaming for DTS(MA). Haali + MKVMerge mkv + FFDShow stutters like crazy with DTS(MA). Also, SamuriHL is able to get PGS subs in mkvs working with FFDShow but unfortunately I cannot. I tested this with WMP, MPC HC, and SageTV.
For now I will just stick with FFDSHow + MPC Matroska Splitter as that seems to yield the most reliable results.
16th June 2010, 23:46 | #1891 | Link |
Thanks for testing! Very much appreciated. Still not sure why you can't get the PGS subs to work. I have no problem with that. They show up fine on the Haali menu and I can select between them with ease. I don't blame you for sticking with the MPC splitter. I would if I didn't care about PGS subs and WMP support. I need to get this working with Haali somehow.
16th June 2010, 23:57 | #1892 | Link | |
- Install latest Haali - ffdshow dxva video configuration: Subtitles is checked in the tree on the left. Make sure all the formats are checked. Make sure embedded subtitles and subtitles files checked - MPC-HC configuration: Playback, uncheck auto-load subtitles Internal filters make sure matroska is unchecked External filters add ffdshow dxva video decoder, ffdshow audio decoder, and ffdshow subtitle filter and set all to prefer. Play MKV in either WMP or MPC HC and see if PGS subs work. I have no problem selecting the subtitles but nothing appears. In fact, this method kills all subtitles from working (IDX/SUB as well).
17th June 2010, 00:14 | #1893 | Link |
Yea, I have no problem with subs when I do that. Not sure what's up with your configuration. When you right click on the ffdshow dxva video icon, is the subtitle option checked?
17th June 2010, 00:19 | #1894 | Link | |
17th June 2010, 00:22 | #1895 | Link |
AHA! I know what the issue is. Go back into ffdshow dxva video settings and under the hardware acceleration section, turn on post processing.
17th June 2010, 00:25 | #1896 | Link |
Brilliant, it is working now
17th June 2010, 00:28 | #1897 | Link |
That's my fault. I forgot that setting. I wish ffdshow had an "enable all crap to get MKV + subs + dxva + bitstreaming working" button.
17th June 2010, 00:34 | #1898 | Link |
LOL, the "enable crap" feature!!!
17th June 2010, 00:45 | #1899 | Link |
Well, doesn't it make sense? We know what options should be set by default to make everything work. I want one button to set it all. I don't care what they call it. LOL! And yes, I know, I know...I could just export the settings. I'm lazy!
17th June 2010, 06:53 | #1900 | Link |
Are you guys trying MKVMerge from the CL or the GUI?....I'm wondering if only the GUI doesn't support PGS Subs.
Also on files made with MakeMKV can you set the subs default to off but then play forced subs automatically if they are present?...These are things I've struggled with on my GUI when I convert the subs to .IDX. In most cases I only want to see forced subs by default although it would be nice to have non-forced present in the file. I also don't want to be bothered to turn them off. I also don't want to turn them on if only forced subs are present...Does that make sense? Mike
Another EAC3to GUI Plus Last edited by MikeEby; 17th June 2010 at 07:08. |
