20th November 2008, 20:22 | #3042 | Link | |
20th November 2008, 20:25 | #3043 | Link |
yeah, i do! thats why i use ripbot, because its the simplest way to shrink data to fit on a 25gb bd-r
and if im not tooooooo confused, ive already seen bitrates on bluray which are over 90mbsp! (King Kong on bluray i guess) |
20th November 2008, 20:27 | #3044 | Link | |
90MBps/8=11.25 MB/s 11.25 MB/s * 10800 s (3h movie) = 119 GB
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th November 2008 at 20:32. |
20th November 2008, 20:29 | #3045 | Link | |
so in generell, im right with my assumption that the bitrate shown in my ps3 is according to the bitrate i choose in the profile (4.0 or 4.1) - right?!?!? |
20th November 2008, 21:12 | #3049 | Link |
this is my first try at using ripbot but it's not working on my system. i am using vista 64.
i uninstalled K-lite codec pack first, then installed ripbot. i kept all the default options during install. everything installs OK. when i click on the ripbot link on my desktop, an error pops up: [ Failed to get data for 'mjpg' ] then it loads ripbot. The Add link is available, so I click on that and the Encoding Settings window pops up. The only option I can select at this point is the [...] button for Video. So I choose a file, then across the bottom I see a notice "Please wait, demuxing audio" then "Please wait, gathering information". Once that message dissapears, nothing else happens. i can't choose any options in this window, it's frozen. The only button that works is the Abort button. i can close the window but that's it. i've tried various video files, ripbot acts the same. tried uninstalling it and reinstalling, no change. any idea what the problem is here?? |
20th November 2008, 21:23 | #3050 | Link |
im using vista 64bit business - and works well...
perhaps there are rests left in your registy which k-lite left back. try this http://download.chip.eu/en/TuneUp-Utilities-2008_30881.html uninstall ripbot, run registry cleaner in the tuneup utilities, reboot, and reinstall ripbot - should work this way... |
20th November 2008, 21:55 | #3051 | Link | |
20th November 2008, 22:12 | #3053 | Link |
I dont care so should you
??? Is the installed version causing problems???
My Installer's || |
20th November 2008, 22:33 | #3054 | Link | |
we were talkin about bitrates and which are usefull and which not. obviously its an "authors thing" which bitrates you use and which not. at my point of view it offers a better result when you use level 4.1 instead of level 4.0 for bluray output because peaks will often tear the 20mbps-line... BUT, its an author-thing! |
20th November 2008, 22:38 | #3055 | Link | |
20th November 2008, 22:40 | #3056 | Link |
OK ;-) I C Trixtie little hobbits... The installer has just been updated... It now works Download and enjoy...
Please for the love of it all get rid of the Codec Packs....
My Installer's || Last edited by Ajax_Undone; 20th November 2008 at 23:18. |
20th November 2008, 22:48 | #3057 | Link | |
edit: forgot to say thanks for the tip. Last edited by os10; 20th November 2008 at 22:50. |
20th November 2008, 23:23 | #3059 | Link | |
1080p at 100fps?!?!?!?!? What do you do exactly???!?!?!?
20th November 2008, 23:25 | #3060 | Link | |
ive already seen a lot of bluray movies which have bitrates far over 50mbps which offers level4.1 or how do you explain the existance of a level5.1.... and once again: these borders of 20,50 or 90 mbps are only peaks, not konstant bitrates! |
