Old 8th September 2008, 16:10   #1  |  Link
Ranguvar
Ranguvar's Avatar
Workaround for 8e6 R3000 pattern-based filtering
I wasn't sure whether this discussion would be fine here, but I read and re-read the rules and can't really find anything about this, so I'll give it a shot.
My school is now using the 8e6 R3000 Enterprise network filtering software. The bane of my existence. Previously, blacklists were how the filters worked, which could easily be circumvented by using unknown HTTP proxies, or VNC/proxy to my home PC.
Now, they employ filtering based on patterns. Info here, here, and here (Google can find more).
I'm wondering if anyone has any ideas about getting around this. I don't know what I'd do if the Doom9 forum got blocked
I am quite noobish to advanced networking, but I can learn.
Thanks, and I hope this discussion is considered OK - I think it will, considering that it doesn't even break the law, which is grey area for a ton of other stuff on this forum
I would rather not use any workarounds that require social engineering, or any sort of intrusive hacks... it wouldn't be worth it. This is mostly just so I can surf freely, and for the challenge. I'm not malicious.
Ranguvar is offline   Reply With Quote
Old 8th September 2008, 16:52   #2  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
ssh tunnel to your home computer.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 8th September 2008, 20:00   #3  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
or any encrypted connection (even VPN...) to your home computer and a gateway/proxy...
Old 8th September 2008, 20:12   #4  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Maybe http://pici.picidae.net/ could help you. AFAIK it even breaks the Great Chinese Firewall
It works by only transferring images instead of Text/HTML code. All URL's will be obfuscated. It seems the Doom9 forum works, not too great though...
Old 8th September 2008, 20:17   #5  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
fantastic
Old 8th September 2008, 21:58   #6  |  Link
Ranguvar
Ranguvar's Avatar
Unfortunately, the site is blocked. Besides that, I think they may detect the obfuscated URL; they did that before.
I'm also worried about a VPN or SSH connection, but I'll try it.
Thanks!
Old 8th September 2008, 22:06   #7  |  Link
LoRd_MuldeR
Software Developer
Even if the original site got blocked, other servers may arise. The software is available for free, any PHP capable server can run it.
If they manage to detect the obfuscated URL's, then the obfuscation mechanism can be changed. Yes, it's the usual "cat and mouse" game ...
Old 9th September 2008, 03:22   #8  |  Link
Ranguvar
Ranguvar's Avatar
Does anyone have a good guide for setting up a free VPN proxy to my home computer? Windows. Looked around, but all I can find are pay-for services, and Linux tutorials.
Old 9th September 2008, 03:56   #9  |  Link
LoRd_MuldeR
Software Developer
Not sure if this is what you need, but you may want to give Hamachi a try. Very easy to use...
Old 9th September 2008, 15:54   #10  |  Link
Ranguvar
Ranguvar's Avatar
Unfortunately, Hamachi cannot install without admin rights. I'll try installing on my home PC and copying the files, but if that doesn't work, I'll need to find a new admin hack, as they fixed all the old ones... I find it funny that if I had never been around, they would actually have worse security I always find holes and then they patch them (won't discuss exactly because I don't want to worry the mods).
Old 9th September 2008, 18:06   #11  |  Link
LoRd_MuldeR
Software Developer
Hamachi needs to install it's own Network Adapter (Network Driver). It think the same applies to all VPN solution. So Admin rights will be needed to get VPN working...
Old 10th September 2008, 04:29   #12  |  Link
Ranguvar
Ranguvar's Avatar
I think I found a new way in.... muhahaha
Now to see if the way in, and then Hamachi, will work.
Old 10th September 2008, 09:32   #13  |  Link
Shinigami-Sama
Solaris: burnt by the Sun
Shinigami-Sama's Avatar
try firefox with tor and/foxyproxy or installed/built in?
theres a couple floating around
and even if its on executible blacklist, you can always compile it with couple differences...
Originally Posted by benjust View Post
interlacing and telecining should have been but a memory long ago.. unfortunately still just another bizarre weapon in the industries war on image quality.
Shinigami-Sama is offline   Reply With Quote
Old 10th September 2008, 11:15   #14  |  Link
Ranguvar
Ranguvar's Avatar
Neither work because of the pattern blocking. Tried it already. But thanks.
8e6, pattern, proxy, r3000, workaround
