13th March 2022, 06:26 | #101 | Link | ||
Formally known as .......
Check this...https://www.mediafire.com/file/rskh2...30802.mkv/file it's a different source, but that's the problem !!! This is a typical RipBot script:- Code:
#Custom LoadPlugin("%AVISYNTHPLUGINS%\ffms\ffms_latest\x64\ffms2.dll") LoadPlugin("%AVISYNTHPLUGINS%\GRunT\grunt.dll") LoadPlugin("%AVISYNTHPLUGINS%\RgbAdapt\RgbAdapt_x64.dll") LoadPlugin("%AVISYNTHPLUGINS%\RT_Stats\RT_Stats_x64.dll") Import("%AVISYNTHPLUGINS%\scripts\extras\RGBAdapt_Awb_Process.avs") video=RGBAdapt_AWB_Process(video) Quote:
I'd post this on the RipBot forum, but I'm 99% sure it won't get address, as RipBot is dying a slow & painful death |
13th March 2022, 06:30 | #102 | Link |
When you load a working avs into ripbot, it will generate a getinfo.avs and job.avs script in the temp folder . It uses Import("script.avs") . That's why it works 100% as is (not 99.99% fail). It's just using avisynth as a frameserver.
Check your temp files. You can check RipBot264.ini for the location, or edit the location The problem is you have a buggy avisynth setup |
13th March 2022, 06:34 | #103 | Link | |
That is just an avs script.
You should try VDub2 or AVSpmod. It seems easier than RipBot. I think the problem is on your end, not anything with said tools. |
13th March 2022, 06:38 | #104 | Link | |
#MT #VideoSource LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\lsmash\LSMASHSource.dll") video=LWLibavVideoSource("G:\Filter test\nobody 2021 2160p no filters 1080p.mkv",cachefile="F:\Temp\RipBot264temp\job3\nobody 2021 2160p no filters 1080p.mkv.lwi") #Deinterlace #Decimate #Crop #Downscale #Tonemap #Levels #Colours #Denoise #Custom LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\ffms\ffms_latest\x64\ffms2.dll") LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\GRunT\grunt.dll") LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\RgbAdapt\RgbAdapt_x64.dll") LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\RT_Stats\RT_Stats_x64.dll") Import("C:\RipBot264v1.26.1\Tools\AviSynth plugins\scripts\extras\RGBAdapt_Awb_Process.avs") video=RGBAdapt_AWB_Process(video) #Prefetch #After_Prefetch_Denoise #After_Prefetch_Custom #Sharpen #Upscale #Borders #Subtitles #AudioSource Import("F:\Temp\RipBot264temp\job3\job3_a1.avs") #Triming #AVSameLength #ColorSpace #Return WriteFile("F:\Temp\RipBot264temp\job3\info.txt","Framecount") WriteFile("F:\Temp\RipBot264temp\job3\info.txt","Framerate") WriteFile("F:\Temp\RipBot264temp\job3\info.txt","AudioRate") WriteFile("F:\Temp\RipBot264temp\job3\info.txt","AudioChannels") WriteFile("F:\Temp\RipBot264temp\job3\info.txt","AudioLength") WriteFile("F:\Temp\RipBot264temp\job3\info.txt","Width") WriteFile("F:\Temp\RipBot264temp\job3\info.txt","Height") WriteFile("F:\Temp\RipBot264temp\job3\info.txt","PixelType") Trim(0,-1)DE] Code:
#MT #PREFETCH_LIMIT=32 #VideoSource LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\lsmash\LSMASHSource.dll") video=LWLibavVideoSource("G:\Filter test\nobody 2021 2160p no filters 1080p.mkv",cachefile="F:\Temp\RipBot264temp\job3\nobody 2021 2160p no filters 1080p.mkv.lwi") #Deinterlace #Decimate #Crop #Downscale #Tonemap #Levels #Colours #Denoise #Custom LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\ffms\ffms_latest\x64\ffms2.dll") LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\GRunT\grunt.dll") LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\RgbAdapt\RgbAdapt_x64.dll") LoadPlugin("C:\RipBot264v1.26.1\Tools\AviSynth plugins\RT_Stats\RT_Stats_x64.dll") Import("C:\RipBot264v1.26.1\Tools\AviSynth plugins\scripts\extras\RGBAdapt_Awb_Process.avs") video=RGBAdapt_AWB_Process(video) #Prefetch video=Prefetch(video,16) #After_Prefetch_Denoise #After_Prefetch_Custom #Sharpen #Upscale #Borders #Subtitles #AudioSource Import("F:\Temp\RipBot264temp\job3\job3_a1.avs") #Triming #AVSameLength #ColorSpace #Return I'll have to test on other PC's !!! |
13th March 2022, 06:45 | #105 | Link | |
13th March 2022, 06:46 | #106 | Link | |
13th March 2022, 06:49 | #107 | Link |
I haven't used ripbot in about 6-7 years, but I just downloaded it today and I know how it works. And it worked ok for 3 people.
The flashing has nothing to do with ripbot itself. It might have to do with the plugins in your referenced ripbot folder , but you claim they are current I imported a script, not a video . This is my ripbot job (I edited out the # lines and changed to "PATH") Code:
video=Import("PATH\awb.avs") return video I used LSmash, but it doesn't matter ffms2 works too, I checked Code:
LoadPlugin("PATH\RgbAdapt_x64.dll") LoadPlugin("PATH\RT_Stats_x64.dll") Import("PATH\RGBAdapt_Awb_Process v 2021 sept 32 64 bits function.avs") LWLibavVideoSource("PATH\untreated video.mkv") AWB_Func() The Import means if you have a working awb.avs script, it will work in ripbot too. The ripbot script is referencing another script (ie. it's frameserving a script). I bet that Reel.Deel's and Benard's looks like this too Last edited by poisondeathray; 13th March 2022 at 06:54. |
13th March 2022, 06:54 | #109 | Link | |
I'm about to try it on another PC, and will report back shortly... UPDATE:-OK, this is interesting, so on another PC running Windows 11, when I try to run AVSMeter within RipBot, I get this :- Code:
RGBAdapt_Awb_Process: Input video colorspace must be YV12 or RGB32 First time I've seen that, with AWB !!! Another Update:- edited line 15, still does the same blinking, so I'm going to give up on this filter. Last edited by TDS; 13th March 2022 at 07:10. |
13th March 2022, 07:39 | #111 | Link | |
13th March 2022, 07:50 | #112 | Link | |
However, I have just learnt something about RipBot that I have never used before, and that's that I can import a script (.avs) and not just a video, however, importing any of the RipBot scripts, or the ones I've added, throw up all sorts of errors, mainly to where the .avs & .dlls are located, so I will have to try the script that you (and others) have provided, and see if I can get something happening. As for "feeding unsupported colorspace to AWB", these errors came up using that "untreated video.mkv"....I'm just getting more & more confused, and my old brain can't get itself around it. |
13th March 2022, 07:59 | #114 | Link | ||
Happy reading and good luck |
13th March 2022, 10:00 | #115 | Link | |
So not to bite off more than I can chew, would this be a way to be able to use Vapoursynth with RipBot ?? I have been steered in a direction I didn't know existed..... |
13th March 2022, 10:20 | #116 | Link | |
You'd have to edit the script EVERY time you added a new encoding job... Whereas the way it's done in RipBot, the script isn't file name specific, so you can load in ANY file name you want, and then add the desired script later in the Job setup procedure.... If I can figure out how to do it this way, I will then try and get it to work the "RipBot" way..... |
13th March 2022, 12:31 | #117 | Link |
@ Bernardd, @ poisondeathray, @ Reel.Deel, and others...
SUCCESS I want to thank you guy's for your help with this problem, and apologize for my ignorance / inexperience at this sort of thing. Up 'til today, I have only known one way to get a script to work in RipBot, but now I know another way, especially with "stubborn" scripts, and the good thing is, I can then use any of the other Custom Filters on top of the imported type, like AWB So I can now AWB & denoise, degrain, etc, etc all at once. Now one thing that I have noticed is that importing AWB.avs in, the audio track isn't processed, or am I missing something, again ??? (Can always add it later, I guess) My test script :- Code:
LoadPlugin("D:\AWB\GRunT\grunt.dll") LoadPlugin("D:\AWB\RgbAdapt\RgbAdapt_x64.dll") LoadPlugin("D:\AWB\RT_Stats\RT_Stats_x64.dll") Import("D:\AWB\RGBAdapt_Awb_Process.avs") LoadPlugin("D:\AWB\FFMS\ffms2.dll") ffms2("D:\AWB\nobody.mkv") AWB_Func() |
13th March 2022, 13:20 | #118 | Link |
Big Bit Savings Now !
Append
va=last() aa=LWLibavAudioSource("D:\AWB\nobody.mkv") AudioDub(va,aa)
13th March 2022, 13:50 | #119 | Link | |
(D:\AWB\AWB new.avs, line 7) (C:\Temp\RipBot264temp\job1\getinfo.avs, line 2) Thanks, tho. |
