Old 21st April 2014, 15:50   #1  |  Link
zee944
DTS-HD 5.1 decode, edit, and re-encode
I have a lossless(?) DTS-HD 5.1 track. I'd like to do the following things:
1. Decode to 6 separate WAVs.
2. Edit the waves in an audio editor, such as GoldWave.
3. Re-encode it the very same way, as a lossless DTS-HD track, and with the same volume levels and dynamics inside. In short, it has to sound the same as before.
Is it possible? How can I do it?
Thank you for any help in advance!
zee944 is offline   Reply With Quote
Old 21st April 2014, 16:55   #2  |  Link
Video Dude
Senior Member
You can use eac3to to decode to wav, but there is no free DTS-HD MA encoder. The encoder available from DTS is very expensive and not marketed for consumers.
After you edit you can output to pcm 5.1 and that would retain the lossless quality. There are free AC3 encoders available and even low cost products that can output AC3. Many people can't hear the difference between AC3 640 kbps and lossless unless they have a golden ear or really high end equipment.
Video Dude is offline   Reply With Quote
Old 22nd April 2014, 10:39   #3  |  Link
zee944
I've read something in this thread that I have to have the appropriate filters to decode the DTS-HD Master lossless, otherwise I can only decode it in lossy format with eac3to. Is it true?
Can I use that PCM 5.1 for a Blu-ray or in an MKV container?
Old 22nd April 2014, 20:31   #4  |  Link
Asmodian
Yes (you need Arcsoft's decoder)
Compress the PCM to a 5.1 flac instead of DTS-HD (also lossless and smaller than DTS-HD).
Old 22nd April 2014, 20:37   #5  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
There's also a free 'lossy' DTS encoder available, which offers bit-rates much higher than AC3's 640Kbps
Old 22nd April 2014, 20:50   #6  |  Link
nevcairiel
Did anyone ever conclusively determine if those higher bitrates are really "better", or it just compresses worse?
Of course DTS will say they are better, and Dolby will say the opposite.
Old 22nd April 2014, 21:16   #7  |  Link
SeeMoreDigital
Funny you should mention that... I've recently carried out some of my own tests and I personally don't believe that 96/24 DTS sounds any better than DTS-CD.
But I do think that when encoding from a lossless PCM source, the free DTS (DCAenc) encoder at 768Kbps sounds fuller than the free AC3 (Aften) encoder at 640Kbps.
Cheers
Old 23rd April 2014, 07:25   #8  |  Link
zee944
Thanks for the responses.
1. Does every player that plays DTS-HD plays 5.1 flac as well?
2. If the answer is yes, why don't the official releases use 5.1 flac?
Old 23rd April 2014, 08:18   #9  |  Link
nevcairiel
Not every player. But not every player can play full DTS-HD either, and only plays the lossy DTS core instead.
You should focus on the players you are planning to play it on, though. =)
Old 23rd April 2014, 09:20   #10  |  Link
SeeMoreDigital
Over the years I've had several hardware Blu-ray players. Three of them could play FLAC files but only one of them supported 5.1 channel playback (Oppo BDP-103).
Some surround sound amplifiers also support FLAC files via USB pen-drive and/or via a network connection. But not all of them support 5.1 channel playback, only stereo...
Old 23rd April 2014, 18:46   #11  |  Link
zee944
I'll have to figure out what format to use then. Too bad there is no DTS-HD MA encoder available.
I've successfully decoded the DTS-HD MA track with eac3to and ArcSoft DVD Decoder. One thing I noticed: the output WAVs are 24-bit. Is this good for me if I want the best quality possible? I've read somewhere the waves inside the DTS are 64-bit.
Old 23rd April 2014, 18:48   #12  |  Link
nevcairiel
DTS-HD MA is usually either 16-bit or 24-bit, lossy DTS is usually decoded to 32-bit or 64-bit floating point, but that doesn't mean its "better".
Old 24th April 2014, 20:55   #13  |  Link
rik1138
If you have the means to post the WAVs somewhere, I can compress them back to DTS-HD MA if you want...
rik1138 is offline   Reply With Quote
Old 25th April 2014, 07:31   #14  |  Link
zee944
Thank you for the offer! What encoder do you have?
Old 26th April 2014, 06:38   #15  |  Link
rik1138
DTS's... I think it's the only one out there.
http://www.dts.com/professionals/aud.../overview.aspx
decode, dts-hd, re-encode
