Old 9th February 2012, 15:54   #1  |  Link
zoeliu
How to extract IDR frames from H.264 elementary bitstream?
Here is what I did:
Given an H.264 elementary bitstream, use a parser to extract all the SPS/PPS/IDR nalus (judging from nal_unit_type 7/8/5), add starting code 0x00000001 at the beginning of each nalu, and write to a file.
The result however cannot be decoded correctly. What am I missing here? Great thanks!
zoeliu is offline   Reply With Quote
Old 10th February 2012, 08:22   #2  |  Link
Dust Signs
The start code is 0x000001, not 0x00000001. I assume that this is the problem. However, two questions:
* What error do you get exactly when trying to decode the stream?
* Did you escape 0x000001 sequences within the NALUs to 0x00000001 (unlikely that they appear, but nonetheless possible)?
Best regards
Dust Signs
The number you dialed is imaginary. Please turn your phone by 90° and try again
Dust Signs is offline   Reply With Quote
h.264 ext of frames, h.264/avc
